Official Power Sound Audio Thread - Page 395 - AVS Forum
post #11821 of 13332 Old 05-29-2014, 06:56 PM
mercury's Avatar
Liked: 99
Originally Posted by ahblaza View Post
Hey Merc, just curious, from your pic I noticed your mains are several inches back from your entertainment center, I mean the front baffles of your speakers are recessed in relation to the front of the ET center. Is that an illusion or am I crazy. Doesn't that affect the your dispersion pattern? You can tell me to go to Hello but I always thought the mains should be pulled out and in front of that ET center edge. I'm sorry this has nothing to do with your sub placement, I'm just a stickler for things, like I said it could be an illusion. Please no offense intended. Being in this hobby for a long time I was always taught to try and have nothing in between your mains if possible. In 99% of peoples homes this is impossible. I don't know why I'm rambling like this, sorry, like I said I'm not trying to tell you how to do anything, just noticed your mains behind the front edge of ET center. smile.gif
Cheers Jeff
trust me no problem-..
im constantly shifting and moving things. it's probably more of a aesthetic thing then anything else....
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #11822 of 13332 Old 05-29-2014, 07:25 PM
ahblaza's Avatar
Quoted: 92 Post(s)
Liked: 130
Aesthetically speaking, your place and setup is very attractive, everything is in place and looks good. I'm glad you didn't take my comment the wrong way. I'm never satisfied with things in my LR, I'm trying to have a stereo rig and combo Ht setup as well and that can be difficult to have dedicated HT and stereo rigs in the same space. tongue.gif
Cheers Jeff
mercury likes this.
j_nordi
ahblaza is offline
post #11823 of 13332 Old 05-29-2014, 11:38 PM
mijotter's Avatar
Liked: 58
Finally Got REW up and running with the CS UMIK-1.
That nasty dive bomb around 80 has me wondering if it has something to with my crossover being set to 80hz or is it just a null?
Overall how does it look to you guys. I think I know what i'm looking at and it looks like i'm pretty flat down to 13hz which is cool even though to get anything that low i'd have to really up the db.
mijotter is offline
post #11824 of 13332 Old 05-30-2014, 03:42 AM
bear123's Avatar
Quoted: 149 Post(s)
Liked: 661
Fix your scale...45-105 dB and 10-200 Hz.  You should have 5 dB increments on the Y scale(dB)
I agree with Brian Fineberg..stick with no smoothing while trying to dial things in.  It will hide little nulls that you can fix with placement/phase/distance adjustments.  If you smooth them, you won't see them.
Looks great 0-60.....but yeah gotta fix that 60-100 null.  Time for duals............the reason to fix your scale is that the null is much worse than your graph makes it appear....almost 20 dB but the scale is making it look smaller.
Have you experimented with crossover to see if it affects the null....try 80,90,100, then also try setting the crossover on the sub itself along with the avr.
ahblaza likes this.
AVR:       Yamaha RXV-375
Display:  Panasonic  TH-50PC77U
LCR:       Hsu HB1.2  HC1.2
Sub:       (2) PSA XV15se
Blu Ray:  Sony BDP-S5100
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #11825 of 13332 Old 05-30-2014, 04:26 AM
basshead81's Avatar
Liked: 1370
Exactly as I suspected...you have a major null killing your mid-bass. The problem is sub placement in relation to the listening position. Either move the sub, lp, or add another sub to smooth out that null.
ahblaza likes this.
basshead81 is offline
post #11826 of 13332 Old 05-30-2014, 04:36 AM
Brian Fineberg's Avatar
Quoted: 38 Post(s)
Liked: 451
I really don't think that's a null
That looks like it's the natural roll off of having an 80 x over
You are a candidate for the sub distance tweak. At your xover your sub and mains are slightly canceling each other out.
Bump up both subs by 1ft at a time and re measure. Up to 6 ft. If that doesn't work decrease the distance by 1 ft at a time. (MKe sure you write down the original distances to revert to)
Make sure you measure with REW after each change
D Bone and ahblaza like this.
Panasonic 65VT30 | Denon x4000 | Emotiva XPA-5 | Emotiva XSP-1 | Emotiva DC-1 | PSB imagine B's |PSB image c5 | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp
my HT gallery: http://www.blu-ray.com/community/gallery.php?u=240707
Brian Fineberg is offline
post #11827 of 13332 Old 05-30-2014, 05:37 AM
flydeep's Avatar
Liked: 37
Just as what Brian said, more liklely the xover value. I would suggest a quick check you can do to determine whether this is the xover effect - increase the xover to a much higher value, say 150Hz and see whether that null value is moving. Could help you identify whether it is coming from xover or something else before doing additional tweaking.
ahblaza likes this.
Fronts: KEF Q900's, KEF 600c, Rear: Mirage OMD-15's, SW: PSA triple XS30se+miniDSP
AVR: Denon 3313CI, Amp: Emotiva XPA-5
Sources: HTPC (Jriver Media Center), Logitech Squeezebox Touch, PS3, Xbox 360,
TV: Sony KDL-55W900A
Unraid Server with 30TB+
flydeep is offline
post #11828 of 13332 Old 05-30-2014, 07:34 AM
mercury's Avatar
Liked: 99
My new subs have landed.. Thanks for the quick ship Tom.. Time to rush home set them up and hope the wife doesn't notice lol
Mike Butny and ahblaza like this.
Denon 4520*
Squeezbox*
mercury is offline
post #11829 of 13332 Old 05-30-2014, 08:04 AM
Mike Butny's Avatar
Quoted: 13 Post(s)
Liked: 56
I got a quick question, If your Processor/ Receiver has Audyssey XT32 is there still a need to get involved with REW? or will Audyssey XT 32 auto correct all major flaws?
Mike Butny is offline
post #11830 of 13332 Old 05-30-2014, 08:06 AM
bear123's Avatar
Quoted: 149 Post(s)
Liked: 661
I doubt that is a crossover issue entirely. The graph is scaled wrong. That small dip is 20 dB.
AVR:       Yamaha RXV-375
Sub:       (2) PSA XV15se
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #11831 of 13332 Old 05-30-2014, 08:07 AM
bear123's Avatar
Quoted: 149 Post(s)
Liked: 661
Audu
Audysey cannot fix a 20 dB null. Only measuring and fixing placement can do that
AVR:       Yamaha RXV-375
Sub:       (2) PSA XV15se
Apple TV
Harmony 650
miniDSP
bear123 is offline
post #11832 of 13332 Old 05-30-2014, 08:34 AM
basshead81's Avatar
Liked: 1370
A natural roll off of having a 80hz crossover would not dip 20db and come back up then roll back off. The graph is not scaled correctly...look at it closely, its a 20db null from 65-95hz. That is a deep valley my friend. smile.gif
I do agree that tweaking the distance setting is worth a shot since this cancellation is happening around the cross over region.
post #11833 of 13332 Old 05-30-2014, 08:34 AM
Hopinater's Avatar
Liked: 503
I agree. REW can't fix it but it will let you know what you need to fix with proper placement. Without REW you may not even know what you're missing because you will never know you have a major null or void.
Hopinater is offline
post #11834 of 13332 Old 05-30-2014, 09:38 AM
Quoted: 38 Post(s)
Liked: 451
If the mains are canceling out the sub then it will 100% be 20db and maybe more. It depends on how narrow it is.
It's one of two things (IMHO and not a null)
1) canceling of the waves
2) the x over needs to go up to 90 or 100
But that is my hunch. I am probably wrong lol
post #11835 of 13332 Old 05-30-2014, 09:58 AM
climber07's Avatar
Quoted: 56 Post(s)
Liked: 959
That's what was happening with my setup. Adjusting the phase on the subs slightly, using a meter, may fill that null band and bring the phase cancellation down below the main's crossover point.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Samsung UN55C8000 3D LED TV - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One...
climber07 is online now
post #11836 of 13332 Old 05-30-2014, 10:02 AM
derrickdj1's Avatar
Quoted: 70 Post(s)
Liked: 140
Klipsch RF 7 based HT 7.4, Pioneer SC 35, Acurus Five 200 amp, Chase SS 18.2(2), VS 18.1(2), Samsung BDP F 7500, Asus/My Book Live HPC 4 TB
Yaquin VK 2100 amp, McIntosh XR 5 speakers, Samsung BDP F 7500
derrickdj1 is offline
post #11837 of 13332 Old 05-30-2014, 10:45 AM
mercury's Avatar
Liked: 99
Ok.... first off apologize as i'm sure the forum is sick of looking at pics of my LR.... lol
anyhow-. XS15se's are in and all set-up.
as to break my wife in easy i'v choosen these spots for set-up.smile.gif one is hidden behind the chaire at the door. the other two spots she's already used too....... first thoughts. these are dinky compared to the 30's .... that said.. , the LR is now full of bass that's for sure- eek.gif
Brian Fineberg likes this.
Denon 4520*
Squeezbox*
mercury is offline
post #11838 of 13332 Old 05-30-2014, 10:51 AM
Alan P's Avatar
Quoted: 285 Post(s)
Liked: 188
Good job on "hiding" your new acquisitions....she'll hardly even notice!!
So, how's it sound????
Alan P is online now
post #11839 of 13332 Old 05-30-2014, 10:51 AM
Quoted: 38 Post(s)
Liked: 451
Awesome!!
post #11840 of 13332 Old 05-30-2014, 10:52 AM
mijotter's Avatar
Liked: 58
By changing the XO in the AVR(MCACC) will I hve to run a recalibration at all?
mijotter is offline
post #11841 of 13332 Old 05-30-2014, 10:52 AM
Alan P's Avatar
Quoted: 285 Post(s)
Liked: 188
Nevermind.......
post #11842 of 13332 Old 05-30-2014, 10:53 AM
Alan P's Avatar
Quoted: 285 Post(s)
Liked: 188
Nope. But, if you change it on the sub(s) you should.
post #11843 of 13332 Old 05-30-2014, 10:54 AM
climber07's Avatar
Quoted: 56 Post(s)
Liked: 959
No.
post #11844 of 13332 Old 05-30-2014, 10:54 AM
Mike Butny's Avatar
Quoted: 13 Post(s)
Liked: 56
If we do not hear from you tomorrow, would that mean she " found " them? lol.
post #11845 of 13332 Old 05-30-2014, 10:58 AM
Mike Butny's Avatar
Quoted: 13 Post(s)
Liked: 56
Originally Posted by bear123 View Post
Audu
I got a quick question, If your Processor/ Receiver has Audyssey XT32 is there still a need to get involved with REW? or will Audyssey XT 32 auto correct all major flaws?[/quote
I thought that might be the answer, just wanted confirmation. Thanks for the info.
post #11846 of 13332 Old 05-30-2014, 11:04 AM
mercury's Avatar
Liked: 99
Ya probably... lol
they sound like my house is gonna cave in-. remember my LR is only 20 x 17 with 8 feet ceilings. bass I love you defiently sounds better. i had some bottoming out on reference. now that could be the added subs or a better XT32 set-up. either way. nothing bottoms out. the bass seems to go so low and loud all rattling stops. if thats possible.. i now feel the bass inside my body. weird really and hard to explain. makes my body tingle. lol
i like the seperation of the 30 and 15 on the one side. seems to fill the room better. to my ear... with just the 30's my strongest bass came behind the door(corner spl meter). not so now. seems more spread out. I like.
Denon 4520*
Squeezbox*
mercury is offline
post #11847 of 13332 Old 05-30-2014, 11:10 AM
Mike Butny's Avatar
Quoted: 13 Post(s)
Liked: 56
Ya probably... lol
i like the seperation of the 30 and 15 on the one side. seems to fill the room better. to my ear... with just the 30's my strungest bass came behind the door(corner). not so now. seems more spread out. I like.
Congrats!!!!!! I bet they sound awesome. If / when she finds them just use the old saying " They had a special, buy one get the 2nd at half price".
post #11848 of 13332 Old 05-30-2014, 11:17 AM
mercury's Avatar
Liked: 99
I have to say for anyone on the fence. I really love the texter of these subs. they can take a beating that's for sure-.smile.gif
Denon 4520*
Squeezbox*
mercury is offline
post #11849 of 13332 Old 05-30-2014, 11:18 AM
mercury's Avatar
Liked: 99
it's her birthday weekend. lol
I should have asked Tom V to send along a mug. i could have served her wine in it when she gets home from work. now that would have been priceless.!!!!
ps.... Tom ill give your adress up in a second, lol
Mike Butny likes this.
Denon 4520*
Squeezbox*
mercury is offline
post #11850 of 13332 Old 05-30-2014, 12:00 PM
JT78681's Avatar
Quoted: 104 Post(s)
Liked: 132
It's the little ones you gotta watch out for. "Float like a butterfly sting like a bee"
mercury likes this.
Receiver - Denon 1713
Speakers - Infinity P363's, PC351, P153's
Subs - Rythmik FV15HP's
JT78681 is online now
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
