Official Power Sound Audio Thread - Page 438 - AVS Forum
post #13111 of 13122 Old Today, 04:57 PM
drwinlied's Avatar
Quoted: 17 Post(s)
first impressions with the XV15se's. meh. I haven't yet ran audyssey or gotten into any calibration/setup with them to reach their full potential. I just wanted to hook them up and see what the difference would be from the dual Dayton 1200's.
I don't really get that visceral feel I was hoping for. The gain on subs is about 2 o'clock; AVR -8.5db; crossovers on front stage 80hz; LPF to LFE 120 (it goes up to 210hz!). I will say that the XV's definitely provide more content, lower, and don't sound bloated or droning. They have a richness to them that the daytons could never match. They are clearly a better speaker than the lil 1200's
Right now i have them in the front of the room, flanking the tv/avr. One in each corner. Given their size, I may end up going wireless with them and moving them back by the couches, as they could be used as endtables lol. That would undoubtedly give viewers a more involved experience.
But yeah, I need to do some setup and view some LFE heavy movies to see what's really going on. I guess I had my hopes up too high, given the price difference between these and the Daytons. Again, these sound much better than the Daytons but they don't seem to hit as hard (yet). At roughly thirteen times the cost of the Daytons...I was hoping for more right out of the box.
Like I said though, I need a proper setup and some more testing. I know there is more out there, but I'm skeptical at just how much.
My back is very messed up right now, so moving these things isn't going to happen until that's better. Hopefully soon.
There are some things that concern me about the subs, however. The pots on the crossover knob (on both subs) are a bit scratchy towards max/min. I didn't adjust while the sub was on, but feeling scratchy pots on a new piece of hardware seems odd to me. Also, one of the subs didn't turn on right away. I had to toggle from off-on-auto-on at which point it made a slight "fizz" noise and turned on (green light is go!).
All of this may be nothing, I'm just reporting my experience so far.
drwinlied is online now
post #13112 of 13122 Old Today, 05:07 PM
ahblaza's Avatar
Quoted: 52 Post(s)
Liked: 117
Originally Posted by Alan P View Post
OK, I can forgive you for not messing with REW yet (it can be intimidating at first), but you have no excuse for not at least running Audyssey!
How can you make judgment on what your system is capable of if it's not calibrated??
Reversing the phase on just 2 subs should have had an effect on SPL.
BTW, you did not gain match at the MLP...that is known as level matching.
I'm sorry for the error, I do know the difference between gain and level matching, like I said I'm out of my mind right now and just can't get into anything. I will try at least running Audyssey. It's just right now I've sold all of my main speakers and I'm using some Pioneer monitors until I can get the PSA speakers. I've never liked the results of Audyssey in the past but then again I really haven't given it a chance. Alan, should I use the procedure you outlined for dialing in two subs in your post earlier since my four are stacked? TIA
j_nordi
ahblaza is online now
post #13113 of 13122 Old Today, 06:29 PM
drwinlied's Avatar
Quoted: 17 Post(s)
here's the beastly xv next to the lil dayton 1200. Sorry for the potato quality picture
post #13114 of 13122 Old Today, 06:55 PM
jbrown15's Avatar
Quoted: 316 Post(s)
Liked: 735
Why are you running your AVR at -8.5?
My Gear:
JTR Noesis 228HT (LCR)
Axiom Audio QS8 surrounds
Sherbourn PA 7-350
Pioneer VSX-21TXH
JVC RS45
Falcon Screens FVHD105
Dual PSA XS30's (gone but not forgotten)
jbrown15 is online now
post #13115 of 13122 Old Today, 06:58 PM
ahblaza's Avatar
Quoted: 52 Post(s)
Liked: 117
Well, since your subs are stacked (you basically have dual subs, not quads - same as me ) and you've determined that is the best placement (don't need to sub crawl), all subs are up front so you *probably don't need to mess with phase...as long as you've got your sub trims in the correct range, there really is nothing more to do except move on to REW.
One thing maybe - how did you set the gain on your 4 subs? Did you gain match them before stacking? If not, this might help you out a bit. If you level matched them at the MLP, their output is probably slightly different. Not a big deal, but if you want to eeek out as much performance as possible.....
*My situation is probably very rare, but I have to reverse the phase on the 2 top subs in my stacks to get max SPL at the MLP. Those 2 subs must be wired out of phase internally, I haven't opened them up yet to fix it. Might be worth a try to reverse the phase on 1 in each stack and see if your SPL increases....you've got an SPL meter, right?
Alan, if I were to gain match each sub prior to stacking should I turn each XV15SE on it's side and measure the driver output for each sub that way with mic same distance from each of the four drivers in the center of my room placing each sub in the same location as the first as described in the gain matching post which is in your post, the guy who has the three submersives? TIA
j_nordi
post #13116 of 13122 Old Today, 06:58 PM
Kini62's Avatar
Quoted: 64 Post(s)
Liked: 308
If you are running an AVR with Audyssey, bump up the trim in the AVR 5dbs or so. Most report that Audyssey sets the sub channel on the conservative side.
They may or may not work in the same spots you had your Daytons, but that should be a good starting point.
So bump up the sub trim put a bass heavy movie or 10 in or stream some youtube bass test tracks and crank it up. They should pretty much blast you out of the room, unless your room is really large.
As for the auto on, there can be some variation in how sensitive that is from amp to amp.
The first amp in my PC12 Plus was not very sensitive at all to auto on, so much so I just left it on all the time. Well that amp went bad and the replacement amp works much better even though they are the "same" amp.
Tom monitors this thread but it still wouldn't hurt to call or email with any concerns.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #13117 of 13122 Old Today, 07:01 PM
drwinlied's Avatar
Quoted: 17 Post(s)
that's simply where audyssey put the level at with the daytons. Like I said, i didn't touch any settings. The daytons tended to get a bit overzealous running at -6 or higher for tv so I just left the settings as they where. I'd kick them to around -2 for movies/games.
Again, these are just my initial impressions and I did say I haven't messed with any settings/calibrations yet. I think these XV's will be a massive improvement when dialed in. Quick report is all, as they say, garbage in, garbage out =P
post #13118 of 13122 Old Today, 07:12 PM
drwinlied's Avatar
Quoted: 17 Post(s)
Yeah, no concerns yet. Like i said, just initial impressions with a quick n dirty, RTR setup.
Regarding the "auto on"...I turned the sub from OFF to ON and it didn't turn on. I then went from ON to AUTO and back to ON (waiting about 5 seconds per stage). It finally turned on after those steps, but it fizzed. Static fizz, not soda fizz...I always leave my subs ON and never in AUTO. Those daytons had some issues knowing when to turn on.
Again, I'll do a proper audyssey and bump the levels up +5ish from where audyssey puts it.
post #13119 of 13122 Old Today, 07:25 PM
flydeep's Avatar
Liked: 34
If you have trouble with auto on, use a splitter to use both the channels L and R on the sub. I have 3 xs30se plugged in this way and all of them turn on automatically when the subs sense a bass signal.
As other users have pointed, calibration makes a huge difference. Try jacking up the sw level on average by about 6-8 dB. Sit back and be ready to jump and reduce the sw level when needed.
Fronts: KEF Q900's, KEF 600c, Rear: Mirage OMD-15's, SW: PSA triple XS30se+miniDSP
AVR: Denon 3313CI, Amp: Emotiva XPA-5
Sources: HTPC (Jriver Media Center), Logitech Squeezebox Touch, PS3, Xbox 360,
TV: Sony KDL-55W900A
Unraid Server with 30TB+
flydeep is online now
post #13120 of 13122 Old Today, 07:38 PM
basshead81's Avatar
Liked: 1345
Any sub will have auto on issues with the avr sub trim set -8.5. That initial setting is fine, but you need to manually bump it up in the -3-0 range. That will put your sub running 5-6db hot which is about right being audyssey tends to set the sub channel low.
Btw I have a dayton sub1200, it is not on the same planet as a XV15se that is properly calibrated and setup.
basshead81 is offline
post #13121 of 13122 Old Today, 07:39 PM
drwinlied's Avatar
Quoted: 17 Post(s)
I do use splitters for R/L. The daytons were on 24/7 simply because they struggled with reliable auto on/off functionality. I wasn't thinking about auto-anything when turning them on...i was just trying to turn them on when the oddity happened.
post #13122 of 13122 Old Today, 07:50 PM
drwinlied's Avatar
Quoted: 17 Post(s)
I had ran audyssey numerous times with the daytons. I used to run the daytons much hotter than -8.5 and they still weren't reliable on auto. I just left them on after the first month of tinkering. like i said before, they got a little overbearing for tv.
yeah, i did say the xv's are the superior speaker...and i just need to setup/calibrate.
I like the XV's and i'm going to like them more in the future, i'm sure. I don't like scratchy pots or strange noises from amps. I just wanted to give some quick "out of the box" info.
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
