Official Power Sound Audio Thread - Page 73 - AVS Forum
post #2161 of 12878 Old 04-09-2013, 09:16 PM
stm69's Avatar
stm69 is offline
post #2162 of 12878 Old 04-09-2013, 09:35 PM
Prime316's Avatar
Liked: 112
Originally Posted by stm69 View Post
Ok there's loving your sub and then there's loving your sub. That's tmi.biggrin.gif
Projector: Benq W1070 1080p 2D/3D
Screen: 120" Elite fixed frame
AVR: Onkyo TX-NR809
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Sonos-Play 5 and Play 3
Sony Playstation 4
Microsoft Xbox One
Prime316 is offline
post #2163 of 12878 Old 04-09-2013, 09:40 PM
stm69's Avatar
In all seriousness, I am probably going to see if I can flip them on their sides and remove the feet to get them a bit shorter. That's still 6.5 feet side to side though, yow!
stm69 is offline
post #2164 of 12878 Old 04-09-2013, 10:08 PM
Prime316's Avatar
Liked: 112
I believe I recall Tom saying that quite a few people do that. I look forward to seeing them set up as part of your home theater.
AVR: Onkyo TX-NR809
Sony Playstation 4
Microsoft Xbox One
Prime316 is offline
post #2165 of 12878 Old 04-10-2013, 01:57 PM
buxfan's Avatar
@prime316 we can get a collection going to buy you a real bed. biggrin.gif seriously though I have been dying to see an XV30 in a home setting to get a true idea.Thanks for posting your pics up. I have been wrestling back and forth on whether to get two V15's or one 30 (then maybe a 2nd one around XMAS time if needed, but I doubt it) my room is 12 X 25 9 ft. ceiling. my listening will be about 70% movies and 30 for music. let me know after you have listened to your system with the V30 which way you suggest I should go. I also looked at your other equipment. you have the Klipsch RF-62ii which are rated at 500W max just like my polk audio RTI A9's. the only difference in my system is that I plan on using a 2nd pair of A9's as rears. I am nervous after reading too many online posts that say an avr like the ones I am contemplating such as pioneer elite SC-68, Yamaha 3010 aventage, or onkyo 3009 (a little scared off this one for many reported hdmi board issues- not model specific, onkyo in general) that say 500W speakers can't be pushed nearly well enough without a dedicated Amp especially four of them. what is your take?
buxfan is offline
post #2166 of 12878 Old 04-10-2013, 02:09 PM
SaviorMachine's Avatar
Liked: 86
A loudspeaker's maximum power handling spec really doesn't tell you much about the kind of amplifier that you should use to drive it. I'm not an expert but per my understanding, you should really be looking at the sensitivity and especially the nominal and minimum impedance.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #2167 of 12878 Old 04-10-2013, 02:20 PM
basshead81's Avatar
Liked: 1330
the a9's need a power amp no questions asked. the a7's are borderline...will a reciever power them sure, but not to thier capability. the xv30 is the size of 2 xv15's put together=huge!
basshead81 is offline
post #2168 of 12878 Old 04-10-2013, 02:22 PM
buxfan's Avatar
@saviormachine, unfortunately I do not know nearly enough about electronics, sound specs, etc... to even begin to understand what I am reading when I see the numbers and analysis that everybody else here knows. I guess that I was sick the day that this stuff was taught in school. kidding rolleyes.gif
buxfan is offline
post #2169 of 12878 Old 04-10-2013, 02:24 PM
Saturn94's Avatar
Quoted: 13 Post(s)
Liked: 356
I know this wasn't directed at me, but a speaker's power handling spec will not tell you how much power you need, only their max handling capacity (short term). The spec you want to look for is sensitivity. I see your speakers are rated 90db by Polk, which is fairly efficient. I also noticed they are 8ohm speakers, so should be an easy load on the amp. You should have no trouble driving all four of your Polks with the AVRs you mentioned.
I use to own a pair of ADS speakers that were rated 90db efficient. I had no trouble driving them with a integrated amp rated only 35 watts! I later upgraded to a 100 watt amp and could drive them cleanly way louder than I could ever stand (and would also cause permanent hearing damage!).
Btw, if you are using a sub to handle bass duties, your main speakers will draw alot less power than running full range (bass reproduction sucks up the most power). With subs handling the bass, those AVRs will hardly break a sweat.
Saturn94 is online now
post #2170 of 12878 Old 04-10-2013, 02:32 PM
buxfan's Avatar
by no means is that an underhanded request for anybody to try and teach me this stuff. everybody here has more important things to do for sure. I just hope to get steered enough in the right direction to piece together a decent system.
buxfan is offline
post #2171 of 12878 Old 04-10-2013, 02:34 PM
buxfan's Avatar
Saturn94, that would entail setting the speakers to small correct?
buxfan is offline
post #2172 of 12878 Old 04-10-2013, 02:35 PM
Saturn94's Avatar
Quoted: 13 Post(s)
Liked: 356
Yes.
post #2173 of 12878 Old 04-10-2013, 02:48 PM
buxfan's Avatar
seems kind of funny to set large tower speakers as small. but I can understand the principal of why this so. thank you
Add: of those 3 receivers I listed does anybody have a definitive best choice? I am searching for best video (including upscaling) least amount of drop off in power beyond the mains. those are the two most important qualities.
buxfan is offline
post #2174 of 12878 Old 04-10-2013, 03:02 PM
BeeMan458's Avatar
Liked: 801
Agreeing with you, our mains have two each, 10" woofers so we're setting a pair of mains, with four ten inch woofers to small. As I'm sure you understand, Large vs Small is another way of saying, with, or without a subwoofer. biggrin.gif
BeeMan458 is offline
post #2175 of 12878 Old 04-10-2013, 03:08 PM
buxfan's Avatar
Si senor. reading these forums I saw one of the funniest posts ever IMO. somebody had posted up- my neighbors 3 favorite movies.
1. 1,000,000,000 EXPLOSIONS
2. BUNCH OF ARMY GUYS YELLING
3. SUBWOOFER "THE MOVIE"
that was too funny...
buxfan is offline
post #2176 of 12878 Old 04-10-2013, 03:09 PM
Liked: 86
Well, it isn't really, since most processors that perform bass management allow the user to choose Large or Full Range mains along with a subwoofer that duplicates the bass from the mains at a specified crossover frequency, a mode that's sometimes called Double Bass. Opinions vary on whether this mode should actually be used, but it exists and some people use it.
post #2177 of 12878 Old 04-10-2013, 03:19 PM
Prime316's Avatar
Liked: 112
@buxfan
I only know about issues with Onkyo's receivers because I read about them here. I have owned two and not had an issue...knock on wood. My 809 drives all 5 of my speakers quite easily.
AVR: Onkyo TX-NR809
Sony Playstation 4
Microsoft Xbox One
Prime316 is offline
post #2178 of 12878 Old 04-10-2013, 03:48 PM
bowmah's Avatar
Originally Posted by SaviorMachine View Post
Well on the one hand, every sub I'd ever owned was vented, so there was simple curiosity. On the other hand, I keep my theater in a pretty small room that seems to offer a ton of low-frequency gain, so the potential is there for me to use a quality sealed sub to reach very low frequencies.
Hey, since you have experience with SVS. Which SVS sub do you think is on par with the XV-15 performance wise?
bowmah is offline
post #2179 of 12878 Old 04-10-2013, 05:36 PM
Brian Fineberg's Avatar
Quoted: 34 Post(s)
Liked: 451
I have experience as well. I would say the pb12+
Panasonic 65VT30 | Denon x4000 | Emotiva XPA-5 | Emotiva XSP-1 | Emotiva DC-1 | PSB imagine B's |PSB image c5 | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp
my HT gallery: http://www.blu-ray.com/community/gallery.php?u=240707
Brian Fineberg is online now
post #2180 of 12878 Old 04-10-2013, 05:45 PM
buxfan's Avatar
I realized long afterwards, but it was almost definitely improper forum etiquette to change the main topic thread of PSA subs (which I will be buying for sure) I should have sent a PM instead. sorry about the error.
buxfan is offline
post #2181 of 12878 Old 04-10-2013, 08:38 PM
Liked: 86
Well, I only want to comment on the SVS and PSA subs I've owned, which are the PC12-NSD and the XS15. However, measurements at Audioholics and Data-Bass make me think that Fineberg may be on to something.
post #2182 of 12878 Old 04-10-2013, 10:44 PM
bowmah's Avatar
I envy you and Fineberg. Well, that's not totally true. I envy all PSA owners here!
bowmah is offline
post #2183 of 12878 Old 04-11-2013, 02:03 AM
Quoted: 34 Post(s)
Liked: 451
post #2184 of 12878 Old 04-11-2013, 05:38 AM
tboe77's Avatar
Quoted: 16 Post(s)
Liked: 112
Pretty impressive for the XV15, considering the respective price points of the 2 subs!
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS3, Sony BDP-S6200, Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
post #2185 of 12878 Old 04-12-2013, 11:29 AM
eujin209's Avatar
Been having my XV30 for about a week now. The only thing I have to say is that it's ridiculous! In a good way, Lol biggrin.gif
Don't mind my gear. Had to take the baseboard out to fit it in that cubby. Its a perfect fit and sounds great!
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
eujin209 is offline
post #2186 of 12878 Old 04-12-2013, 11:38 AM
GusGus748s's Avatar
Quoted: 22 Post(s)
Liked: 592
I hate houses with openings like yours. I would take that wall down and make it flat.
Media Server: UnRaid Server: 15TB of storage and growing :).
http://www.avsforum.com/lists/display/view/id/8599
Home Theater Set Up:
http://www.avsforum.com/lists/display/view/id/8597
GusGus748s is offline
post #2187 of 12878 Old 04-12-2013, 11:43 AM
lewdogg's Avatar
Is the rear port being blocked by placing it in that area??? Couldn't that cause damage to the sub?
lewdogg is offline
post #2188 of 12878 Old 04-12-2013, 11:49 AM
GrooveRite's Avatar
I also think to my unprofessional knowledge that it would make the bass directional being 'holed' up in there, no?!?! Sub should be out in the open rather than 'holed' up.
Gamertag: BaneAssassin
PSN: BaneAssassin
GrooveRite is offline
post #2189 of 12878 Old 04-12-2013, 11:55 AM
jjl4004's Avatar
jjl4004 is offline
post #2190 of 12878 Old 04-12-2013, 12:08 PM
pretsam's Avatar
Liked: 27
How much of a gap is there from the port to that wall? It should be at least 4-6"
Congrats!
pretsam is offline
Xs30 , Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Denon Avr 3313ci Receiver , Denon Avr 4520ci Receiver , Power Sound Audio , Xv15 , Power Sound Audio Triax , Room Equilizer Wizard Rew , Denon Avr X4000 7 2 Channel Home Theater Receiver
