SVS PB12-Plus or HSU VTF-3 MK4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 11-14-2011, 11:56 AM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
FYI,
I have an open area where living, dinning & kitchen are with under 3K cubic feet.
I was going to go with HSU VTF-3 but then found the SVS PB12-Plus.
A bit of hard time deciding between the both. My primary usage will be movies.
Note: I would probably prefer sealed subs either the SB13-Plus or the HSU ULS 15 due to smaller sizes but my understanding are that ported subs are better ?
Any advice is greatly appreciated.
Thanks in advance.
Fronts: Sanders Sound M10d, Sanders Magtech Amp. Surround: B&W CM1, 2x JL Audio F112, Integra DHC-80.3, Emotiva XPA-5, OPPO 93 & HTPC
spike9876 is offline
post #2 of 35 Old 11-14-2011, 01:31 PM
HTSteve's Avatar
I know people that have both and both are extemely satisfied.
There is a $500 price delta between these two units. For me, I would purchase the SVS. They have an exemplary reputation and the product just plain performs.
I wish I had known about SVS when I was purchasing my Sub. I have a Def Tech TL-15+ and I have never wanted more output and my media room >6K cubic feet.
With that said, I believe the SVS will go lower at a higher output level, but you pay for it - though a very reasonable price.
Maybe two (2) HSU subs would be better than one SVS. Someone with more knowledge that me could cover that topic.
HTSteve is offline
post #3 of 35 Old 11-14-2011, 01:44 PM
spyboy's Avatar
Liked: 48
Originally Posted by spike9876 View Post
FYI,
Thanks in advance.
If I was in your position I would wait until the Outlaw LFM-1EX goes on sale again for $550 delivered and buy 2 of them (for less than the price of one PB-12 Plus).
http://www.outlawaudio.com/products/lfmEX.html
The EX was designed by Dr. Hsu....
spyboy is offline
post #4 of 35 Old 11-14-2011, 01:49 PM
its phillip's Avatar
Quoted: 68 Post(s)
Liked: 121
I would get the PB12-Plus.
its phillip is offline
post #5 of 35 Old 11-14-2011, 02:00 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Yes, I am leaning towards the SVS... but I'm a bit concerned with the sizes of these ported subs... I can already imagine my wife complaining...
Yes, I also thought about 2 subs... but due to space limitation... that's out of the question for now
post #6 of 35 Old 11-14-2011, 02:49 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
The better comparison, it seems to me, would be the PB12-Plus and the VTF-15H. If you can only get away with one sub (with the wife), save a little money over the PB12-Plus and get the VTF-15H. It has more output than the ULS 15.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #7 of 35 Old 11-14-2011, 03:03 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Yes, I suppose if I'm considering the SVS PB12 then I should also consider the VTF 15. So are you saying that VTF 15 is better than SB12 ?
post #8 of 35 Old 11-14-2011, 03:58 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Below are the sub dimensions:
21.5"(h) x 17.0"(w) x 25.0"(d) VTF-3 MK4 (90 lbs)
25.0"(h) x 18.0"(w) x 26.0"(d) VTF-15H (123 lbs)
22.0"(h) x 19.75"(w) x 25-1/8” (d) PB12-Plus (127 lbs)
The height for the VTF-15H is tremendous... Does anyone use their subs as an end table ?
Edit:
I do want the best sub I can get but maybe I should start to consider the below:
18.875"(h) x 18"(w) x 19.25"(d) ULS 15
17-7/8"(h) x 17-3/8(w) x 17-3/8" (d) SB13-Plus
post #9 of 35 Old 11-14-2011, 04:17 PM
kesando's Avatar
Liked: 31
The PB12nsd is more comparable to the VTF3-mk4 while the Plus is comparable to the VTF15
I two like the idea of dual Outlaw LFM-1 EX's (if you don't plan to add another large sub later) but if you don't want to wait for a sale, a pair of Rythmik FV12's may also be worth a look
http://rythmikaudio.com/FV12.html
kesando is offline
post #10 of 35 Old 11-14-2011, 04:36 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
Between the VTF3 and the PB12 Plus, go for the PB12 Plus, there is a reason it is so much more expensive. The VTF15h is like a compromise between the two, it has the output of a PB12 Plus, but not the deep frequency extension, whereas the VTF3 has similar deep frequency extension, but not quite the output of either. To be honest though, I think you'll be happy with any of them, they are all very good subs.
shadyJ is offline
post #11 of 35 Old 11-14-2011, 05:24 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
VTF15 is really out of the question... just too big.
I really do like the PB12 Plus and again that's where I'm leaning towards...
post #12 of 35 Old 11-14-2011, 05:33 PM
Robert760's Avatar
The vtf15 is not that big I had a dual set. Thier not that great either in the low end in loud output.
Robert760 is offline
post #13 of 35 Old 11-14-2011, 06:23 PM
Elfather's Avatar
SVS all day.
Elfather is offline
post #14 of 35 Old 11-14-2011, 07:55 PM
dimetera413's Avatar
Go with the SVS. It's output at 20hz is incredible.
dimetera413 is offline
post #15 of 35 Old 11-15-2011, 09:40 AM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
This maybe a silliy question but do movies generally go down to 20hz ?
post #16 of 35 Old 11-15-2011, 04:50 PM
Quoted: 68 Post(s)
Liked: 121
http://www.avsforum.com/avs-vb/showthread.php?t=1333462
post #17 of 35 Old 11-15-2011, 05:22 PM
Lets just say that having the opportunity to go to 20hz when it's required and doing so with force is better than not getting to 20hz at all.
post #18 of 35 Old 11-15-2011, 07:20 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Well I finally made the plunge and ordered a PB12-Plus. I can already hear my wife telling me to return this sub due to the size but once it's here it's not going back
I know it makes no difference but also ordered an XLR cable, I just preferr an XLR vs RCA connection. Plus it only cost $16 plus shipping.
post #19 of 35 Old 11-15-2011, 09:59 PM
Elfather's Avatar
Great choice. Congrats.
Elfather is offline
post #20 of 35 Old 11-23-2011, 06:13 AM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Update:
OK, I got the PB12-Plus in and it is huge.
No complaints on my side but I'm just getting too much grief from wife due to its size. I have gotten an ultimatum... either the sub goes or she goes... lol
She is being sarcastic but unfortunately, It will be likely that I will need to return this sub and get possibly the SVS SB13-Plus instead.
The problem is that I no longer have original packaging and I will get charged by SVS for a box and delivery... and then shipping costs back to them... Probably looking at about $350 just to return sub.
I thought about selling on Audiogon for local pickup and save on shipping costs but probably not worth it.
post #21 of 35 Old 11-23-2011, 06:40 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Update:
That's a shame. Is the SB-13 THAT much smaller? You're right you may be better off attempting to sell on the 'gon or craiglist. How long do you have to return it?
Gorilla83 is offline
post #22 of 35 Old 11-23-2011, 06:54 AM
kesando's Avatar
Liked: 31
tell the wife how much it will cost to take it back
kesando is offline
post #23 of 35 Old 11-23-2011, 06:56 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I thought you were so happy with the low end output you bought two?
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #24 of 35 Old 11-23-2011, 07:58 AM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
I do have 45 days to return sub... I'm located in NYC area, I didn't think it was worth it... but I do have some time... so I may first attempt to sell either on 'gon or craiglist.
post #25 of 35 Old 11-23-2011, 08:09 AM
drewTT's Avatar
Quoted: 803 Post(s)
Liked: 823
Have you tried setting it as an "end table"? It looks less imposing this way.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | roon
drewTT is offline
post #26 of 35 Old 11-23-2011, 08:33 AM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
Yes, I've already made this suggestion... Replacing one of my end tables was a good suggestion I had already made but its a no go.
Although I agree that sub is too big for my living room, maybe with time my wife would accept it but I highly doubt it.
post #27 of 35 Old 11-23-2011, 11:50 AM
cel4145's Avatar
Liked: 3002
You jumped in size quite a bit from the ASW10CM. But big 12" ported subs do look smaller once you get used to them.
In the meantime, try demoing some of the 4 1/2 or 5 star movies from The New Master List of BASS in Movies with Frequency Charts. Maybe you'll both agree that the PB-12 Plus significantly improves the HT experience over your ASW10CM. That might get you part of the way out of the dog house
cel4145 is offline
post #28 of 35 Old 11-23-2011, 12:20 PM
spyboy's Avatar
Liked: 48
Any chance she would ease up if you bought her some jewelry?
spyboy is offline
post #29 of 35 Old 11-23-2011, 12:23 PM - Thread Starter
spike9876's Avatar
Quoted: 42 Post(s)
LOL, You got that right.
My ASW10CM is a mini sub compared to the 12" ported sub.
It's really not a question about how much better it sounds... I played a movies yesterday... Definitely a much improvement over the ASW10CM its just the space.
It's true over time, you do get used to the size so I'm hoping for this to happen but in reality I doubt it will happen. I still have a couple of weeks before I need to return... so lets see
post #30 of 35 Old 11-23-2011, 03:25 PM
Dude, grow a pair and tell her it's something you've worked for and deserve. It's your house too. I have a wife who isn't crazy about audio equipment but she knows that it's a passion I have and it makes me happy. I hate her spending money on worthless Coach purses but I know it makes her happy so I don't give her any guff about it. I'm rooting for ya!
Hsu Vtf2 Mk4
