Anti Mode - New Product for EQ - AVS Forum
post #1 of 16 Old 11-14-2011, 02:50 PM - Thread Starter
bsoko2's Avatar
Liked: 56
The Anti Mode is coming out with a new sub or main EQ sometime in the 1st Qtr of 2012. More info http://www.dspeaker.com/.
bsoko2 is online now
post #2 of 16 Old 11-14-2011, 02:54 PM
Tom Bley's Avatar
So this is for speakers, sub or both? Nevermind, seems it's for stereo setups.
Tom Bley is offline
post #3 of 16 Old 11-14-2011, 02:58 PM
pbc
pbc's Avatar
Liked: 30
Seems to imply for "stereo speakers" or "dual subs" from the press release (I was confused as well).
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #4 of 16 Old 11-14-2011, 03:10 PM - Thread Starter
bsoko2's Avatar
Liked: 56
From the flyer, it does mains and subs.
post #5 of 16 Old 11-14-2011, 04:18 PM
jackbuzz's Avatar
MSRP $1200
jackbuzz is offline
post #6 of 16 Old 04-23-2012, 04:14 PM - Thread Starter
bsoko2's Avatar
Liked: 56
My Dual Core shipped today and from Finland and UPS saaid that I will get it on Wedneday, 25th. Fast shipping! Dual Core Manual for those that wonder what it does AntiMode20DualCoreEng09.pdf
post #7 of 16 Old 04-23-2012, 04:43 PM
hometheatergeek's Avatar
Liked: 31
Originally Posted by bsoko2 View Post
My Dual Core shipped today and from Finland and UPS saaid that I will get it on Wedneday, 25th. Fast shipping! Dual Core Manual for those that wonder what it does http://www.dspeaker.com/fileadmin/da...lCoreEng09.pdf
Looking forward to your review.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #8 of 16 Old 04-23-2012, 10:28 PM
Mupi's Avatar
Liked: 26
Automatic correction only up to 500Hz? Then why call it full range. It only allows manual correction over 500Hz and in that case the automatic correction is disabled. I would rather get the Onkyo NR818 as it has XT32 and MSRP is same. I would presume the XT32 would do full range correction of the main L&R.
Sure the dual core 2.0 has a screen but the limitation up to 500Hz is the deal breaker for me.
Mupi is offline
post #9 of 16 Old 04-23-2012, 11:34 PM
a1bert's Avatar
It is not, where did you read that? You can do your own things on top of the automatic Anti-Mode calibration.
a1bert is offline
post #10 of 16 Old 04-24-2012, 12:15 AM - Thread Starter
bsoko2's Avatar
Liked: 56
Look at the manual for the Dual Core, I put the link in my post #6 and you can see what you are doing on the screen.
post #11 of 16 Old 04-24-2012, 03:51 PM
Mupi's Avatar
Liked: 26
I thought I read in the manual that to do manual correction the automatic correction should be disabled?
If it does automatic correction up to 500Hz and allows manual tweaking using PEQ from 500Hz onwards, then it is better than X32. But then I wont have any correction if I am using a sub. Looks like I will have to keep my old Antomode for the sub and use the new one for main L&R from say 80hz to 500Hz and apply manual tweaking (PEQ) on top of that. Still better than XT32 as I can do the tweaking of the mid range, which is where I like to cut some DB as I like a laid back sound. The fundamental frequency of the human voice is much lower and that would be made flat by the automatic correction. So I still may not get a laid back sound by tweaking from 500 to 2000Hz.
I may be better off using the old Antimode for the bass as I am doing now and just use the manual EQ on the pre-pro/AVR (Denon 3310) as I am doing now. When I spend $1200, I like to have all the options I need. This idea of 2ch correction without sub option does not appeal very much to me. I have to read the manual thoroughly to make sure I have the options I need.
Mupi is offline
post #12 of 16 Old 04-25-2012, 09:58 PM - Thread Starter
bsoko2's Avatar
Liked: 56
Got my Anti Mode Dual Core today and set it up with my 3 Submersives. Once I got it dialed in, Holy Crap! Is it worth the $$$$, should be a few hundred cheaper but I'm Ok as I got in on the early buy. It set a nice flat freg across the board and then I tweaked it and added a house curve from 15 to 50 hz. It is simple to set on the screen on the front of the unit and just click the lift bar and it does it all for you. Menu driven with not alot of brain work. Got back that nasty intense bass that we all love instead of the boring flat. It is a keeper. Hope some of the HT mag guys get one to test and write about.
post #13 of 16 Old 04-25-2012, 10:20 PM
batt50's Avatar
i was waiting for this. i figured it was gonna rock. i have a few questions:
did you connect all 3 subM's to the anti mode?
how long did it take to set up?
and finally, would you say it's easier to use than the sms-1?
thanks
batt50 is offline
post #14 of 16 Old 04-26-2012, 09:30 AM
sputter1's Avatar
Liked: 41
Can you show us any graphs? before and after type stuff.
sputter1 is offline
post #15 of 16 Old 04-26-2012, 01:37 PM - Thread Starter
bsoko2's Avatar
Liked: 56
thanks
I have the first Submersive behind the TV in the middle of the front wall, the other 2 Submersives are on the L & R of the seat against the L & R wall. this way I got 2 groups with the sub gains set the same. It took about 10 minutes all together for setup. This is the Anti Mode and is very easy to use, fully automatic and all you do is make choices in the menu for final SQ.
post #16 of 16 Old 04-26-2012, 01:39 PM - Thread Starter
bsoko2's Avatar
Liked: 56
Go to this thread http://www.avsforum.com/avs-vb/showt...1392947&page=2
User Tag List
