Downward vs Forward facing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 11-29-2011, 08:56 PM - Thread Starter
alrha's Avatar
I have a Martin Logan Dynamo which can either fire downward (wood floors) or forward.
Any particular pros/cons to factor into the decision?
Pioneer Elite SC-57
Playstation3 (Slim 320GB)
Samsung SMT-C5320 (Cablevision box)
4x Mirage OMD-5
1x Mirage OMD-C1
1x Martin Logan Dynamo 500 SW
2x Mirage OmniSat V2 (Kitchen)
alrha is offline
post #2 of 21 Old 11-29-2011, 11:47 PM
Anamorphic's Avatar
I have always felt that there's a tad bit more detail and tactile feel available from front firing subs. I've had plenty of both designs (and several others including open baffle), and have always preferred front firing over floor firing.
"I don't care if he's Mohamed "I'm Hard" Bruce Lee!" - Brick Top Polford: Snatch
Anamorphic is offline
post #3 of 21 Old 11-30-2011, 04:34 AM
jackbuzz's Avatar
If the sub is near-field then it could give give you a more tactile feel with front firing (the air hitting you or the chair), across the room doubtful that there would be much if any difference.
Since you can why not try it both ways. If sub is set for down firing simply lay it on its side, if not you will have to pull driver.
Maybe possible to set it on blocks at corners if it is set for front firing to try down firing.
jackbuzz is offline
post #4 of 21 Old 11-30-2011, 04:56 AM
Anamorphic's Avatar
Well if it's any conciliation to you, none of my setups ever had the sub near-field. And the added detail has always been more noticeable than anything. Granted, it's not a night and day difference, but it's enough that I can hear, and prefer.
post #5 of 21 Old 11-30-2011, 05:16 AM
jackbuzz's Avatar
Originally Posted by Anamorphic View Post
Well if it's any conciliation to you, none of my setups ever had the sub near-field. And the added detail as always been more noticeable than anything. Granted, it's not a night and day difference, but it's enough that I can hear, and prefer.
I wasn't arguing with what you hear, in fact I was going to present the possibilities of different set-ups carpet/tile/hardwood in the corner or not, how sub is facing, etc... but thought I would just make a general statement that most would probably agree with. Since the OP has the option of trying both ways he can decide for himself what works best.
EDIT: Insert and how that might affect the sound of the 2 types of subs after etc...
jackbuzz is offline
post #6 of 21 Old 11-30-2011, 05:36 AM
KidHorn's Avatar
Quoted: 1486 Post(s)
Liked: 979
I prefer front firing also. Mainly because my subs always have to be buried somewhere (WAF) and with front firing, I can aim the sound into the clear.
KidHorn is offline
post #7 of 21 Old 11-30-2011, 05:37 AM
Ericthemidget's Avatar
I presently have a front firing SVS sub and am adding a down firing HSU sub to the mix. Will this present a problem?
Ericthemidget is offline
post #8 of 21 Old 11-30-2011, 05:44 AM
KidHorn's Avatar
Liked: 979
I wouldn't say a problem, but probably not optimal. Using identical subs is typically preferred so you get the same frequency response from each. I think you should be more concerned with using 2 different subs than whether or not the drivers are pointed at 90 degrees relative to each other.
KidHorn is offline
post #9 of 21 Old 11-30-2011, 05:49 AM
The SVS I own is 10" which they no longer make.
post #10 of 21 Old 11-30-2011, 06:19 AM
Anamorphic's Avatar
No arguing from me.
I wouldn't exactly say there's any type of problem from using two or more different subs. It's just that the tuning of all of them to blend together properly is a lot more intense and involved. It can be done.
post #11 of 21 Old 11-30-2011, 11:18 AM
KidHorn's Avatar
Liked: 979
OK, then you have no option. So you can't be kicking yourself. I wouldn't worry about having non matching subs. I'm sure it will sound awesome.
KidHorn is offline
post #12 of 21 Old 11-30-2011, 11:26 AM - Thread Starter
alrha's Avatar
i think i find the forward facing to be a little more refined than the downward firing. I was just wondering because I remember when i got it, having that downward firing option was considered a beneficial feature for hardwood floors, but i think there is really very little difference with a preference to forward if any.
Pioneer Elite SC-57
4x Mirage OMD-5
1x Mirage OMD-C1
alrha is offline
post #13 of 21 Old 11-30-2011, 11:27 AM
scorpionfish's Avatar
Do you have little kids? Downfiring keeps the driver away from exploring hands/feet/bubble mowers.
scorpionfish is offline
post #14 of 21 Old 11-30-2011, 11:50 AM - Thread Starter
alrha's Avatar
ha, i do have 3 little ones (all boys) - i always keep the screens on for protection (has some hard plastic in the frame to keep it firm)
Pioneer Elite SC-57
4x Mirage OMD-5
1x Mirage OMD-C1
alrha is offline
post #15 of 21 Old 11-30-2011, 12:51 PM
jaramill's Avatar
Quoted: 14 Post(s)
Hey "alrah", I too just bought an HTS and for the speaker part of it, I went ML. (Electro-motion series - ESLs for left, right, C2 for center). Sub-woofer, I got the Dynamo 700. Now my question is, does the type of floor and position affect whether or not to go one way or the other in terms of the firing (downward, forward)?
Currently I have a carpeted living room and it's near the corner next to the right ESL. And as for the room, the walls are what they would consider "bright". Not because of the paint color but because there's not padding or any drapes or any other objects to muffle the sound such as a bookshelf which would then make the room "dull".
Also what would adding ANOTHER sub do? My receiver (Marantz SR7005) does have outputs for 2 sub-woofers. What are the benefits?
P.S. - Originally from the NYC (Queens)
jaramill is offline
post #16 of 21 Old 11-30-2011, 12:56 PM
Currently I have a carpeted living room and it's near the corner next to the right ESL. And as for the room, the walls are what they would consider "bright". Not because of the paint color but because there's not padding or any drapes or another objects to muffle the sound such as a bookshelf which then make the room a "dull" room.
Two subs can flatten the room response to the sub as well as increase the output if the subs are stacked near each other.
Also, you don't need two sub outputs on the AVR. Y-adatper from monoprice will do the trick!
post #17 of 21 Old 11-30-2011, 01:13 PM
jaramill's Avatar
Quoted: 14 Post(s)
When you say "flatten" you mean distribute if I put the other sub on the other side?
But it's ok to use the 2 outputs from my A/V receiver correct?
And would adding a sub from a different brand make it less optimal? I got a deal on my purchase (0% interest from Magnolia) when I got everything and HSU or SVS or online products only.
jaramill is offline
post #18 of 21 Old 11-30-2011, 01:24 PM - Thread Starter
alrha's Avatar
i dont think you want to fire downward if the floor is carpeted.
Pioneer Elite SC-57
4x Mirage OMD-5
1x Mirage OMD-C1
alrha is offline
post #19 of 21 Old 11-30-2011, 01:31 PM
Actually, a carpet is much better than hardwood. Less rattle and buzz.
post #20 of 21 Old 11-30-2011, 01:49 PM
milkfat's Avatar
There are a TON of discussions on this topic if you search "down front firing" on AVS. The consensus is that there is no audible difference. Bass wavelengths are far too long to be affected by carpeting.
If you have a sub that can be configured either way, then just choose the orientation that pleases you most.
Easy peasy.
milkfat is offline
post #21 of 21 Old 12-01-2011, 06:48 AM
mrjktcvs's Avatar
I have an Auralex Gramma. It doesn't matter what's on the floor.
mrjktcvs is offline
