Replacement for Infinity TSS-1100 Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-05-2011, 12:52 PM - Thread Starter
henoblah's Avatar
I just found out my Infinity Tss-1100 12" powered subwoofer is shot. Found threads here about this being a common problem for Infinity. I can get it repaired through ebay for $180, but I am thinking I should replace it. Can you all recommend a replacement in the $200-$300 range? I don't mind used as long as there's not a known history of failures (like the infinity I presently own )
henoblah is offline
post #2 of 6 Old 12-05-2011, 02:29 PM
Shadowdane's Avatar
Is it the speaker or the amp that is dead? With my old Infinity PS12 subwoofer the amp died, but the speaker was fine.
Shadowdane is offline
post #3 of 6 Old 12-06-2011, 08:41 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
People in this forum like the BIC PL-200 in the under $300 range. You need to check the PL-200 set of comments on how to get the best price.
People also like the Klipsch with the discount that drops the price to $299 (sale ends tomorrow).
http://www.newegg.com/Product/Produc...82E16882780078
wwinkler is offline
post #4 of 6 Old 12-06-2011, 12:39 PM - Thread Starter
henoblah's Avatar
It's the board. The speaker is fine.
henoblah is offline
post #5 of 6 Old 12-06-2011, 12:56 PM - Thread Starter
henoblah's Avatar
I bought the Klipsch. Thanks
henoblah is offline
post #6 of 6 Old 12-07-2013, 10:01 AM
michebre's Avatar
Hi, just replaced my TSS-1100 amp for subwoofer for $137.00 shipped from Infinity.
Hope this helps.
Miche Bre
michebre is offline
