Down to 3 choices for 12" Duals..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 12-05-2011, 09:48 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Duals of either : LFM-1 plus, Rythmik F12, Epik legend : OK so i'm down to these 3 for my Home Theater . 1 : I like clean unmuddy bass
2 : I have fairly large room (4000cf)
The room will be mostly used for HT 75% , and 25% Music
randyc1 is offline
post #2 of 27 Old 12-05-2011, 09:53 PM
ObsceneJesster's Avatar
Im in your same boat, except I wanted one 15 for now. I decided on the Rthmik F25. I've read great things about Rthmik and their servos.
ObsceneJesster is offline
post #3 of 27 Old 12-06-2011, 06:24 AM
flickhtguru's Avatar
Liked: 110
I'm right there with you. I'm buying dual LFM-1 Plus's.... What sold me on them was a the power, b the price, c the extension, and d the fact that sub and ports are down firing cuz I have a 7 mo old daughter and a cat and dog.
Shawn
flickhtguru is offline
post #4 of 27 Old 12-06-2011, 09:37 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Seems like a very good choice from all the reviews i've read ,let me know your impressions when all set up !!
randyc1 is offline
post #5 of 27 Old 12-06-2011, 10:05 AM
Liked: 110
Will do........ but i'm getting them at tax return time. With a 7 mo old not to much extra cash on a day to day basis.
But the LFM-1 Plus's are definitely what I'm getting. I already made isolation platforms for them.
Shawn
post #6 of 27 Old 12-29-2011, 08:53 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Any more Sub Guru's advise on which subs would be the best choice ???
randyc1 is offline
post #7 of 27 Old 12-30-2011, 07:20 AM
Liked: 110
The wife let me take advantage of the sale...... so i got dual pluses for $998 delivered. They are amazing, very beautiful and huge. They have more than enough power, output, and extension for me. I couldn't be happier. When I first used them they were really tight and didn't seem to have a lot of out put, but that changed after about an hour of music and a few bass intense movie scenes. They sound amazing.
Shawn
post #8 of 27 Old 12-30-2011, 07:36 AM
monomer's Avatar
I believe you meant to say Dual Rythmik FV-12 in the opening post, correct?
F-12 is sealed and FV-12 is vented... and about a $300 difference in price (times two would make it $600 difference for duals)
"For deep bass, the listener is not really listening to the speaker, but rather, is listening to the room as it is being played by the speaker."
Juicy
Doggie Jabber
monomer is offline
post #9 of 27 Old 12-30-2011, 10:02 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
No,... I actually was considering the F12's or building downfiring DIY DS1200 . I could not live with the look of the FV12, ugly and to big . If they change the design (on previous thread RYTHMIK said were open to suggestion, I suggested similar design to LFM-1) ) ,they would probably first option.)
It's hard to decide , some prefer the LFM-1+ because they have higher output at lower HZ for movies and are still are very good with music ??
On another thread one member directly compared the FV12 with the Legend and said suprisingly that the Lengend went lower and louder !! but the FV12 was tighter.
One thing is I dont want Huge boxes ,the LFM-1+ is at the very limit of size for me.
Since I listen at moderate levels (-15) , maybe the Dual F12's or DS1200could provide the ouput needed , and the best accuracy.
I really am seriously thinking of building 2 DS 1200's . Downfiring make them very discrete and small footprint !!
randyc1 is offline
post #10 of 27 Old 12-30-2011, 10:06 AM
Liked: 110
One thing to add about the LFM-1 Plus, it makes a very good end table. Even while cranked up there is virtually no vibrations on the top of the sub. My wife thinks they look good and liked that the second one could double as a new end table and its black so it matches the new coffee table we just bought.
Shawn
post #11 of 27 Old 12-30-2011, 01:03 PM
monomer's Avatar
...It's hard to decide , some prefer the LFM-1+ because they have higher output at lower HZ for movies and are still are very good with music ??..
Apparently not compared to the FV12 according to someone (Shift) who had listen to both subs in the same room and reported about it in your other thread.
...On another thread one member directly compared the FV12 with the Legend and said suprisingly that the Lengend went lower and louder !! but the FV12 was tighter...
If you are referring the soapboxpreacher, he's said a lot of contradicting things in that one long thread comparing first the Legend to his Velodyne and then later the FV12... his opinions kept changing depending upon when it was said. He went from dissing the FV12 to finally seeing the error of his ways (apparently had something to do with placement and calibration, I don't remember precisely what his deal was as I didn't bother to read close enough). Bottom line being apparently he changed his mind over time and I believe in the end he was saying just the opposite of what you're saying (except for the part about the FV12 playing tighter).
Juicy
Doggie Jabber
monomer is offline
post #12 of 27 Old 12-30-2011, 01:19 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Well reading threads just get us within the 2-3 best subs for our buget. One will prefer one sub and then another will be the opposite ?...After getting the 2-3 best choices, it's all up to personal tastes I guess .
I really wish there was a Mid priced Shootout (400- 750.00 $) with a mixture of Sealed and Ported 12" Subs . This is probably the most popular price range and would benifit the most people!!
randyc1 is offline
post #13 of 27 Old 12-30-2011, 01:38 PM
spyboy's Avatar
Liked: 47
Can someone show me a professional test on the LFM-1 Plus that demonstrates the prowess of the LFM-1 Plus with music?
Off the top I would rate the OP's original choices:
Rythmik
Outlaw
Epik Legend
spyboy is offline
post #14 of 27 Old 12-30-2011, 04:11 PM
monomer's Avatar
Originally Posted by spyboy View Post
Can someone show me a professional test on the LFM-1 Plus that demonstrates the prowess of the LFM-1 Plus with music?...
Audioholics did review the EX (the "up-scaled" version of the PLUS???) and found accuracy to be somewhat lacking... I suppose one could translate that into saying it wasn't quite as good with music as others in its price range. This is quoted from the conclusion in that review, make of it what you will... "It also managed to sound very natural and just plain old good with music. Not the most articulate bass ever, but quite good."
From what I've read, I'd have to agree with your rankings...
Juicy
Doggie Jabber
monomer is offline
post #15 of 27 Old 01-03-2012, 05:07 PM
makutaku's Avatar
Have you considered the VTF-3 MK4 ? I like how it looks in Rosenut Veneer and I would like to hear some comparisons/opinions between this and the Rythmik F12.
makutaku is offline
post #16 of 27 Old 01-03-2012, 07:15 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
All of these will have muddy bass relative to a better sub. All will have clean bass relative to a lesser sub. So whether or not any/all of these meet your requirement really depends on your expectations, which hinges on your previous experience. What are you looking to do as well as or better than in a sub that you have heard before? It may be all would meet your expectations, and you can base your decision on other factors.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #17 of 27 Old 01-03-2012, 10:13 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
I'm know they would all beat my current sub easily, because it is a Kef Cube 2 ,10" ,250w sealed Sub . Will probably be going with (dual) Rythmik's DIY DS 1200 kits . I only listen at moderate levels (-15 on amp) so i think Output should be enough even for HT. Like i've said before , a 12" Mid-Priced (400-750$) shootout would benefit many consumers !
randyc1 is offline
post #18 of 27 Old 01-03-2012, 10:26 PM
cel4145's Avatar
Liked: 2991
Well, if you are used to the sealed sub sound, then Rythmik makes a lot of sense because they are known for tight sound with those servo drivers in their sealed subs. A definite upgrade
post #19 of 27 Old 01-08-2012, 10:32 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
What we really need to see ,is a Mid -Priced 12" Shootout ! (450 -750.00$)
randyc1 is offline
post #20 of 27 Old 01-08-2012, 06:43 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
I had owned both the LFM1-Plus & FV-12 (both at different times).
Out of these two, for movies they were comparable, but I do give the slight edge to FV-12. Amp was tuned lower and servo was set. The output on the FV12 has the slight edge and just was tight and cleaner. Output also showed from the sofa I sat on, which was about 13' away from the sub. Also since I owned the LFM1-Plus and did have it on the subdude, it still didn't sound as good. It was nice, but not as nice at the FV12.
Both cabinets are not appealing. The floor firing and option to close off a port on the Outlaw was nice. Too me they are nice for end tables, but who really wants these kind of subs very close (near field). Push this sub away and let it breath and travel to you!!
I like kisses blown to me (ever seen the scene on Superman when the lady blew Superman a kiss from a distance and he flew away further? )
Right now I don't have either (sold them both). Once I get my new house built, I do plan on getting either 2- FV12's or maybe the Legends by Epik subs, but for some odd reason since I know I had much smiles with the FV12, why not just get them and be happy. Plus my back is tired of messing with 60+ lbs subs. I am not getting any younger..... at least thats what my lower-back is telling me.
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
post #21 of 27 Old 01-08-2012, 06:58 PM
jsgrise's Avatar
Quoted: 171 Post(s)
Liked: 68
Hey Randy, got my VTF-15H. Let me know if you want a demo.
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #22 of 27 Old 01-08-2012, 07:01 PM
kesando's Avatar
Liked: 31
It's good to hear the FV12 is a great sub. I'm guessing it slots right in between the Outlaw LFM-1 Plus and EX as far as output with a slight edge in tightness.
kesando is offline
post #23 of 27 Old 01-08-2012, 11:02 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hey jsgrise ! how r u . I would love to hear it !. I am free all this week ,so u can give me a call 514 941 5419 or you can leave me your num, and I will call U back .
Thanks !
randyc1 is offline
post #24 of 27 Old 01-08-2012, 11:16 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Hey Shift ,thanks for the info . There was another member i think it was Soapboxpreacher that had the Legend and the FV12 in his room for comparisons. For HT he was very surprised that the Legend had more Ouput and Extension than the FV12 ! ...He still preferred the tighter overall sound of the FV12 !
randyc1 is offline
post #25 of 27 Old 01-09-2012, 07:43 AM
jsgrise's Avatar
Quoted: 171 Post(s)
Liked: 68
Thanks !
Alright I'll let you know as soon as I can. It should be during the day around mid-week.
jsgrise is offline
post #26 of 27 Old 01-09-2012, 10:12 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Great ,you can just PM me the info if you want .
randyc1 is offline
post #27 of 27 Old 01-09-2012, 12:51 PM
Audiojan's Avatar
Quoted: 18 Post(s)
I was in your shoes last year and ended up buying dual Epik Legends. I couldn't be happier with my decision. These are the least expensive components in my HT and perform way above their price range. Rest is Thiel and Krell, so pretty good stuff.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
