Paradigm monitor subs - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By plasma_fan
  • 1 Post By JimWilson
post #1 of 18 Old 12-12-2011, 06:22 PM - Thread Starter
6g72tt's Avatar
Has anyone heard these yet, I know they come in 8,10 & 12 versions but I am hoping for some real world reviews?
6g72tt is offline
post #2 of 18 Old 02-19-2012, 06:11 AM
HDVidGuy's Avatar
Quoted: 21 Post(s)
Bump
Cannot find any reviews to date. Anyone listened or purchased the 10 or 12?
Considering 2 sub 10's or one sub 12 for bedroom. Nice wireless feature would make easy setup in the room. Match to my Mini Monitors.
Bryston SP3
Bryston BDP-2, BOT-1
Bryston 14B SST, 6B SST
B&W 802N's, HTM1
Paradigm Sub 2
Paradigm ADP 470 v3
HDVidGuy is offline
post #3 of 18 Old 02-19-2012, 07:12 AM
cjsiv's Avatar
Liked: 33
I am curious as well. I have a Hsu STF-2 and would like something with more punch. I am obviously aware of the price to performance of the ID brands. I just purchased a full Paradigm monitor setup though and after reading about the Sub1 and Sub2, it's obvious Paradigm is capable of making a killer sub. Those are out of my price range though.
cjsiv is offline
post #4 of 18 Old 02-19-2012, 09:23 AM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
I have Monitor 9's for left and right, an LCR350 for center, ADP150's for surround and a PS1200 for the sub. After hearing all the good things about ID subs, I'm not even thinking of a Paradigm sub. Personally they are over priced (I was looking at a DSP32/3400 but the 3400 was 1K retail). Maybe it is a good sub that Paradigm makes, but for the money you would do better with sticking with an ID company.
Jeff
pronghorn/az is offline
post #5 of 18 Old 02-29-2012, 10:32 AM
plasma_fan's Avatar
My INITIAL impressions, copied from my other thread in this section but are likely more appropriate here. All in all im happy but as was warned the sub may be a touch weak for my space.
"I did go with the monitor sub12. Ive done basic setup, and an initial PBK. The sub has met my expectations but fell short of my hopes...
According to my cell phone spl meter, the PBK charts, and my ears the sub12 really starts to work well around 25Hz, maybe a little before. But a long cry off the 16Hz advertized, however right in line with other good quality small box sealed 12"ers and I more or less expected this, but did hope for "real" sub 20Hz extension. The sound quality is great, the volume is there, the slam is ok but not fantastic. Explosions and other loud LFE effects in movies give an ok rumble, however to get a good feeling from the bass in music the volume needs to be cranked, keeping in mind i listen to ZERO electronic music. Im sure in a slightly smaller room this sub would come alive in that regard. I also only have the gain set to about the 10:30 position, so there is more in the sub.
Next steps will be to work on dialing things in a little better, and enjoy untill the upgrade urge strikes again and at that point probably step into a true big boy sub... Or a second monitor sub12, see how I like it given some time.
I may move the sub to the better corner in the room, that corner gives a smoother and bigger gain but can sometimes sound localized however the PBK may help in that regard. That corner MAY help with a little more extension and slam, but not expecting it."
plasma_fan is online now
post #6 of 18 Old 03-12-2012, 01:38 PM
HDVidGuy's Avatar
Quoted: 21 Post(s)
I now have personal expereince with the Monitor Sub 12. Did not do the PBK setup, just wanted to test as new.
I have a CD that does full freq. steps starting at 10Hz and goes all the way up past what I wanted to test.
Here's my results with a sound meter:
10Hz - basically no ouput
20Hz - output, down 6-7db
25-26Hz - output down 4db
28Hz output down 3db.
30Hz and up fairly flat - of course room setup made for some bumps
Movies and music sounded great, but didn't have the low extension I was hoping for. For movies, I want to have a sub that is strong at the 20Hz range and dipping down to 16Hz. This sub cannot do that. Output down 6-7db may not sound like much on paper, but it really is to my ears!
Edit:
I wanted this for my bedroom, not my main AV system. Considering you can get a good deal via your dealer, this is good value. All thru the tests, never did I hear wind noise and any other strange noises. It's built very good and is solid. Also to consider is the wireless adapter adding approx. $120. This will enable you to place this sub any where in the room close to a power outlet and add more subs to boot.
Bryston SP3
B&W 802N's, HTM1
Paradigm Sub 2
Paradigm ADP 470 v3
HDVidGuy is offline
post #7 of 18 Old 06-12-2012, 10:04 AM
lifeis11's Avatar
would love to hear someone who has auditioned the 12 for mainly music, if such a person exists.
i auditioned it myself, and it seemed tight and really controlled. id like it to match up with my studio 60s
Paradigm Studio 100 Floorstanding Loudspeakers
REL R505 Subwoofer
Marantz PM8004 Integrated
Marantz SA8004 SACD
Rega P6 Turntable
Rega Exact 2 Cartridge
Cambridge Audio StreamMagic 6
Salamander Archetype 5.0 Equipment Rack
Chord ChameleonPlus, CobraPlus interconnect RCA
Legend Audio Bi-Wire...
lifeis11 is offline
post #8 of 18 Old 07-22-2013, 07:13 PM
m.sharp's Avatar
looking to add a sub to my system and am considering the monitor sub 8 or 10 or maybe a def teck prosub 1000.
Anyone have experience with the 8 or 10 inch monitor sub? My room is about 10x14.
m.sharp is offline
post #9 of 18 Old 07-22-2013, 09:25 PM
JimWilson's Avatar
Quoted: 1284 Post(s)
Liked: 1600
I'm listening to a Monitor SUB 12 as I type this. It's actually a unit I'll be reviewing in the coming months.
Whenever I get a new sub it's run for a few hours just to ensure everything is working (I'd hate to go back to a manufacture weeks after getting something and have to say "um, it was a DOA - sorry it took so long to let you know"). My room is 13x17x8, so probably more cubic feet then yours. The SUB 12 has only been run about 3 or 4 hours thus far, so it's not broken in yet, but it does seem to be pretty musical.
DefTech is notorious for being very optimistic with their lower extension numbers -- saying the ProSub 1000 can hit 18Hz is a prime example -- but it seems Paradigm might also be taking liberties with the SUB 12; while I haven't pushed it at this point, I'm not getting in the teens with what I have tried. I can tell you this much, the amp doesn't get the least bit warm. After a few "energetic" sessions there was zero heat coming off this thing. When you have a tiny enclosure like this that's not very common. Usually the amp will heat up pretty quickly due to how hard the driver is being pushed in order to achieve output.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #10 of 18 Old 10-21-2016, 04:33 AM
Liked: 0
Paradigm monitor sub 12
Hi,
I was hoping you could give me your experience with Paradigm monitor sub 12. How did it do for movies and music? Were you able to get a flat response down to 20Hz?
I look forward to heraing from you.
Many thanks.
Jawad Ahmed Siddiqui is offline
post #11 of 18 Old 10-21-2016, 05:25 AM
Liked: 0
Originally Posted by JimWilson View Post
I'm listening to a Monitor SUB 12 as I type this. It's actually a unit I'll be reviewing in the coming months.<br><br>
Whenever I get a new sub it's run for a few hours just to ensure everything is working (I'd hate to go back to a manufacture weeks after getting something and have to say "um, it was a DOA - sorry it took so long to let you know"). My room is 13x17x8, so probably more cubic feet then yours. The SUB 12 has only been run about 3 or 4 hours thus far, so it's not broken in yet, but it does seem to be pretty musical.<br><br>
Hi,
Did you get to review Paradigm monitor sub 12? Would you kindly share your findings here?
Many thanks.
Jawad
post #12 of 18 Old 10-21-2016, 06:33 AM
JimWilson's Avatar
Liked: 1600
I did indeed publish that review, which you can read using this link.
post #13 of 18 Old 10-21-2016, 10:33 AM
Liked: 0
Many thanks Jim. I couldn't recall but I did read this review before opting for Monitor sub 12. So thanks again for such a detailed review.
Allow me to ask about the graph in your review. I do know the basic theory but can you kindly explain the behavior of Monitor sub 12 below 31.5 Hz in your graph?
I ask this so that I can know the +-3db point for Monitor sub 12 (your findings) before I make a decision about moving to SVS PB2000 sub (+- 3db point 17Hz claimed). I understand you might not have listened to SVS PB2000 but any input from you will be highly regarded as to if this would be a significant upgrade from Monitor sub 12 for movies and music, specially when SVS PB2000 will not have an option like PBK.( I do have Marantz A/V receiver with Audyssey MultiEQ XT)
I hope you will take out time to answer. Thanks again.
Jawad
[quote=JimWilson;47627289]I did indeed publish that review....
post #14 of 18 Old 10-21-2016, 12:25 PM
plasma_fan's Avatar
Hi,
Many thanks.
I still have and use the SUB12. It's OK overall. The PBK makes setup easy, its very small, no complaints with the sound, output could be better however with the size considered it does well. At this point its 1 of 4 subs in my room. The remaining 3 are all DIY projects, in larger boxes getting more power.
Flat to 20hz is going to depend on both your room and how loud you want the sub.
Seeing your other posts, the SVS will be considerably louder around port tuning than the Paradigm. Sealed subs give up a lot around tuning for the option to dig deeper. The Paradigm has an undefeatable high pass around 20hz so the dig deep advantage is lost. The PBK on the other hand is very helpful. If you have a room that has some dominant modes/nulls look into a DSP option, there are a few available.
FWIW the best things I've did for subwoofer setup in order was add a second, add DSP, add 2 more.
post #15 of 18 Old 10-22-2016, 01:04 AM
Liked: 0
[/B]
Thanks for the reply. I have always struggled with understanding the link between the room and a sub going flat down to 20 Hz as you said "Flat to 20hz is going to depend on both your room". Can you help me here?
I am unable to post images here but I will be allowed to do so after few more posts. I will then post my PBK graph for your input.
Do you think SVS PB2000 and monitor sub 12 can co exist one being sealed and other ported?
Thanks again.
post #16 of 18 Old 10-22-2016, 11:45 AM
JimWilson's Avatar
Liked: 1600
You're welcome. I'm glad you found it to be useful.
What that graph shows is the subwoofer slowly starting to lose output as it reaches the limits of what it can effectively do. Depending upon the size of your room that response curve below 31.5Hz might change because the sub will 'couple' with the room and boost the low end. Placing it in a corner can also help in that regard.
Are you comparing the Monitor SUB 12 to the PB2000 or SB2000? The SUB 12 has been designed for an entirely different customer and usage than the PB2000, with the latter a clear winner in every catagory except size. If you meant the SB2000 instead then I would still give the nod to the SVS, but at least in that case you would be comparing products designed for the same customer.
post #17 of 18 Old 10-22-2016, 03:36 PM
plasma_fan's Avatar
[/B]
Thanks again.
As Jim noted above the sub will "couple" with the room. Bigger rooms need more energy from the sub to "come alive". In addition to that the lower the note the more energy required. In a car it doesn't take very much sub to really fill the space, think of a car as a very small room.
Sure the subs could co exist, may take some extra setup but many people mix ported and sealed with good results. If your worried about output the SVS is the clear winner. If you want small size and built in room correction then the paradigm is the winner.
post #18 of 18 Old Today, 10:55 AM
justin42's Avatar
Quoted: 27 Post(s)
Does anyone know whether the feet on the Monitor 10 sub are removable, to allow use of the SVS Soundpath isolation system? https://www.svsound.com/products/sou...olation-system
justin42 is online now
