NEED POOR MANS ADVICE: sub to pair with KEF q100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-28-2011, 10:15 PM - Thread Starter
skichiiwa's Avatar
want to find a sub to pair with kef q100
receiver : onkyo txnr609
large grand room 15 x 25
sub 400 dollars
listen to 80 percent sports/ tv, 20 percent music / movies
or would it be better to get the centre first?
thanks
skichiiwa is offline
post #2 of 9 Old 12-29-2011, 06:34 AM
kesando's Avatar
Liked: 31
sub 400 dollars
thanks
The Cadence CSX 12 or 15 is a good place to start. You may still be able to get $100 off at checkout using the code CA100.
http://www.cadencehometheaterspeaker...p?idCategory=2
kesando is offline
post #3 of 9 Old 12-29-2011, 09:13 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
That's a big room and kef aren't bassy speakers.
Consider getting two subs instead of one. Vanns frequently has 10" Klipsch subs in their clearance section for around $200. A pair of them would work.
KidHorn is online now
post #4 of 9 Old 12-29-2011, 09:21 AM
Fiberopme's Avatar
I Love Vanns !!! I got my entire system from them and saved 70% what I would have paid through a local retailer (You know who you are BB). I added a center speaker to the mix that helped out the older folks not hearing the words too good due to bad hearing, I bought the JBL CSC56 300W 5" 2-Way Center Channel Speaker. It has fixed all my problems. Roughly $325.00 but, way worth it ! You can hear stuff that is usually said under the actors breath, which is a plus for me, since I could never hear that before due to the background music taking over, the center will fix that !
I have 2 subs and never tried it with one so, I have to agree with KidHorn on this one !
Fiberopme is offline
post #5 of 9 Old 12-29-2011, 10:48 AM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2984
The JBL CSC56 would not be a good choice for the OP as a center channel. The center should be timbre matched, and the KEF Q200C seems to be the best option.
As for subs, in addition to kesando's recommendation, the BIC PL-200 could be a good choice for a home theater setup. Acoustic Design is known for taking offers below $300.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #6 of 9 Old 12-29-2011, 07:42 PM - Thread Starter
skichiiwa's Avatar
thanks for the replies.
I have to say that my room is big but when I'm watching tv I'm in an area about 18 x 12.
it is not enclosed. yet I'm rarely that far away. i just want to help my speakers out.
IM not looking for an awesome theatre sound.Nor am i looking for I don't spend my nights watching movies , tv or listening to music . I just want something to make my hockey games, odd movies and background music more enjoyable then the speakers from my 55 inch samsung tv.
thanks again
post #7 of 9 Old 12-29-2011, 08:11 PM
J4yDubs's Avatar
I'd get a center first, especially with your watching habits. Are you using the TV as your center right now?
John
J4yDubs is offline
post #8 of 9 Old 12-31-2011, 08:23 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
Agreed; a center is probably a good idea. I watch a lot of sports myself, and find the dialog is much better with a dedicated center.
As far as subs go... check out the budget subwoofers thread. You'll more then likely find something that works there.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #9 of 9 Old 01-02-2012, 10:38 PM - Thread Starter
skichiiwa's Avatar
John
thanks for all the replies....
john...Im not using anything as my centre.
Is it vital to pair my KEF bookshelf's with KEF centre?
