Help me pick out a great sub :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-03-2012, 07:26 AM - Thread Starter
baddgsx's Avatar
Hi guys,
I want to purchase a nice sub to complete my system. Currently I dont have a sub but my speakers have built in subwoofers. i have 2 definitive 7000sc towers that have 1 14" powered woofer in each tower for fronts , 7001sc for rears (these have 10 inch powered subs in each) and a clr 3000 center channel that has a powered 10 inch woofer aswell.
The ROOM
my room im using is 9 ft by 9ft by 8ft high ceiling give or take some inches. It has 2 small windows that hopefully wont BREAK with all that LFE, lol
This room is also semi sealed. It has a door that can be closed unlike my old space
I might not need a sub in such a small room size with what i have now but i have to add a lfe channel to my editing progects. its a must.
which outta these 2 subs will work for me better? 1 epik sealed or one craigsub ss-18.1 sealed
i was thinking that the 18 incher would get down lower and i already have 2 14" inchers in the towers that could handle 30-60hz
Im guessing sealed is best for sound quality? if you think i should a ported within the pricerange , i just dont want the sub to be sloppy if that characteristic still applies to ported subwoofers of this generation.
any help is much appreciated.
Chris
- Independent Dreams - IDStudios
baddgsx is offline
post #2 of 7 Old 01-03-2012, 12:59 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Since it looks like you already have pretty good mid-bass and upper-bass, which is where the Empire shines, I would go with the CHT and cross it over a bit lower than usual, like 50 or 60 hz. That way there is even less chances of localization than usual.
shadyJ is offline
post #3 of 7 Old 01-03-2012, 01:13 PM
pokekevin's Avatar
Liked: 102
18.1!
pokekevin is offline
post #4 of 7 Old 01-03-2012, 02:52 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1567
The ROOM
So let me see if I have this straight; your fronts each have a 14" sub, your rears both have 10" subs and even your center has a 10" woofer? And now you want to add an 18" subwoofer -- on top of all those other subs -- to a room that measures a mere 650 CF?! Good luck with that! I think it's fair to assume your windows are a goner. What exactly are you editing?
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #5 of 7 Old 01-03-2012, 03:01 PM
spyboy's Avatar
Liked: 47
18.1!
spyboy is offline
post #6 of 7 Old 01-03-2012, 03:09 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
His hearing! LOL
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 7 Old 01-03-2012, 05:20 PM
capecodorthopod's Avatar
With your nearly perfect cube space you will have issues with room modes. Dual subs would help but would be overkill even if you could find some space for a second one. An SS 18.1, Empire or ULS-15 would pressurize that space nicely. Since your "satellites" are very capable below 80 hz I'd probably get a ULS-15 and cross it over at whatever frequency mitigates the modes best.
Good luck and keep us updated.
Tim
capecodorthopod is offline
