Component cable RG-59/U Coax cable for Sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-04-2012, 10:19 PM - Thread Starter
punman's Avatar
Would a component cable RG-59/U Coax cable work (with the trio of red/blue/green ends)?
I need a longer subwoofer cable than the one I have. I have some longer component cables. Would one of those work?
punman is offline
post #2 of 4 Old 01-04-2012, 10:57 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
I believe you can as a component cable is still a 75 ohm cable
pokekevin is offline
post #3 of 4 Old 01-05-2012, 07:54 AM
aidoroboo's Avatar
It should be fine unless you are lacking space behind your sub and avr.
Just make sure to use the same color on each end.
aidoroboo is offline
post #4 of 4 Old 01-05-2012, 01:54 PM - Thread Starter
punman's Avatar
Cute!
They seem to be stuck together like licorice in a package in the sun - I think I can just peel them apart.
punman is offline
Q See 1000ft Rg59 Cable , Q See 500ft Rg59 Cable
