In a *.2 system. How important is it for the subs to be matched... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-05-2012, 11:54 AM - Thread Starter
liltalkm's Avatar
Quoted: 262 Post(s)
Liked: 297
Or is it ok to run two different breed of subs as long as they are rated similarly?
I currently have a ML setup with a Depth i, but am looking to move to a dual sub scenario and wondered if there would be a better more economical solution than going with another Depth i.
My receiver uses XT32 so I am ASS-U-Ming that would help blend the two.
TIA
(Theater)Speakers: Martin Logan Montis, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Anthem AVM 60 | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a, PS Audio Directstream | Sources: DirecTV HR54, HTPC, Mac Mini, Oppo UDP-203, PS4 Pro, Xbox One S | Television: LG 77G6P | Remote: Logitech Harmony Elite
(Bedroom)ORB Audio Mod 2 5.1, Anthem MRX 520, LG 55E6P, LG UP970, Harmony Elite.
liltalkm is offline
post #2 of 12 Old 01-05-2012, 12:30 PM
spyboy's Avatar
Liked: 48
TIA
Rated similarly by who, the manufacturers? Ideally the subs should be the same, but some people have no problems with using different subs.
spyboy is offline
post #3 of 12 Old 01-05-2012, 12:49 PM
flickhtguru's Avatar
Liked: 111
I would recommend 2 identical subs.......If you can't or don't want to do that then at least make sure the specs are the same and that they are either both sealed, both ported, or whatever.
Shawn
flickhtguru is offline
post #4 of 12 Old 01-05-2012, 01:25 PM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
I'm currently using 2 different subs and I'm fine with it. (12inch vs 10inch) But still the weaker sub can handicap the better sub!
pokekevin is offline
post #5 of 12 Old 01-05-2012, 01:53 PM
spyboy's Avatar
Liked: 48
You should look at the HSU ULS-15 or if you need something smaller, look at the SVS SB-13 Plus. Either one should keep up with you M-L Depth i.
spyboy is offline
post #6 of 12 Old 01-05-2012, 04:19 PM - Thread Starter
liltalkm's Avatar
Quoted: 262 Post(s)
Liked: 297
Thanks for the replies fellas. I have some ideas to ponder now.
liltalkm is offline
post #7 of 12 Old 01-06-2012, 06:18 AM
KidHorn's Avatar
Quoted: 1467 Post(s)
Liked: 963
I would do everything I could to have the 2 subs match.
Would you think it's a good idea to have mismatched fronts?
KidHorn is offline
post #8 of 12 Old 01-06-2012, 07:28 AM
aidoroboo's Avatar
Get 2 of the same then your room is symmetrical to keep Feng Shui.
aidoroboo is offline
post #9 of 12 Old 01-06-2012, 09:33 AM
below90hz's Avatar
Another option:
Get two additional small subs to work with the ML sub. Allows for symmetry both visually and acoustically. Two Epik Legends or two VTF- MK 4's for example, would be a pretty economical purchase and would sound absolutely fantastic.
I've tried quite a few different sub positions/configurations, and I must say that 3 subs (2 smaller subs handling front soundstage and larger sub placed nearfield handling 50hz and under) is my personal favorite. as always, ymmv
Quit readin my signature ya stupid signature reader.
below90hz is offline
post #10 of 12 Old 01-06-2012, 10:02 AM
capecodorthopod's Avatar
+1
Your best bet would be to sell the Depth and get dual identical subs from an internet direct company like the Epik or Hsu previously mentioned. ML makes some very nice speakers. Their subs are pretty decent but nowhere near the performance per dollar of the ID sub companies. I auditioned a Depth several years ago for a bedroom set up. Nice for music but not a lot of output and limited extension for movies.
If you like sealed subs you can get a pair of Epik Legends for a little more than you could sell the Depth on Audiogon. It would be a dramatic upgrade for both music and movies.
Good luck in your quest for better bass.
Tim
capecodorthopod is offline
post #11 of 12 Old 01-13-2012, 07:17 PM - Thread Starter
liltalkm's Avatar
Quoted: 262 Post(s)
Liked: 297
Thanks again for the suggestions. I was very close to pulling the trigger on dual Rythmik F12's but the thought of the hassle of selling my depth i kept me from pulling the trigger. Plus the wife approves of the look of the depth would like the symmetry. She preferred another depth if I had to have another sub.
So I just pulled the trigger on another very lightly used Depth i. It should be here a week from Monday. I can't wait for it to get here and totally expect it to make my system sound that much better.
liltalkm is offline
post #12 of 12 Old 01-14-2012, 08:34 AM
Auditor55's Avatar
TIA
If you are using the Earl Geddes approach to set up of multiple subs, it doesn't really matter what brand they are.
Auditor55 is offline
