Dayton Audio SUB-1200 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #181 of 184 Old 04-23-2015, 03:51 PM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
Originally Posted by riley08 View Post
Originally Posted by PlasmaPZ80U View Post
You might benefit from a second, mainly due to the kind of content you listen to. I don't really need a second as I have a small 12 by 12 by 8 room and mainly watch movies and play video games.
Music can have more sporadic bass frequencies vs. movies and larger rooms might need more subwoofer to fill the room and get truly deep bass. Basically, a second sub can help minmize existing nulls in bass response and smooth things out in terms of frequency response.
Really the main question you should ask yourself is do you feel the bass could be any better/smoother and do you have space for a second sub and is the cost of a second one worthwhile to you?
If you're fully satisfied, you probably don't need a second but if you feel things could be significantly better, you might wish to consider it. Also, keep in mind sub placement and setup matters a lot whether you have one sub or two. So, make sure you're getting all you can from the current one before getting a second. And if you get two, make sure you know how to setup dual subs properly, otherwise it may not sound any better than one.
very good advice so I think I will think about what you said and just enjoy what I have for now! thanks for the input!
Yeah, always get the most out of what you have now before considering an upgrade. It's sound advice.
PlasmaPZ80U is offline
post #182 of 184 Old 09-07-2015, 02:22 PM
Liked: 559
http://www.parts-express.com/caprop65
Is this warning anything to be concerned with?
post #183 of 184 Old 10-13-2015, 08:22 PM
GrnXnham's Avatar
Only if you plan on chewing on your audio equipment.
Squirrel! likes this.
GrnXnham is offline
post #184 of 184 Old 03-07-2016, 02:05 PM
Liked: 1
It may help skim this:
https://www.cpsc.gov/PageFiles/12191...nal%200113.pdf
"Pressed-wood and wood-based products: Pressed-wood (i.e., hardwood plywood,
particleboard, and medium-density fiberboard (MDF)) and wood-based products, especially
those containing UF resins, may be a significant formaldehyde source.
• Formaldehyde emissions from pressed-wood products have been reduced 80-90% from
levels in the 1980’s and earlier due to mandatory formaldehyde emission standards in
California and national voluntary formaldehyde emission standards, which are described
later in this booklet.
• Emissions decrease 6-10 months after initial testing"
bartrinsic is offline
Dayton Audio Sub 1200 12 120 Watt Powered Subwoofer , Dayton Audio Rs1200a 12 Reference Series Subwoofer Assembled , Dayton Audio Hts 1200b Home Theater Speaker Set Black , Dayton Audio
