Sub crawl question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-11-2012, 08:58 PM - Thread Starter
PhilT3's Avatar
Can't move my theater seating to put the sub in my LP.
How much will it "hurt" if I put the sub right in front of my LP?
PhilT3 is offline
post #2 of 7 Old 01-11-2012, 09:35 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Actually, near-field placement can help overcome many warts in your room acoustics. When you can place the sub in the best location, then you just have to experiment with the available spots.
Randy
ransac is offline
post #3 of 7 Old 01-12-2012, 05:22 AM
Rijax's Avatar
Phil, if I understand your question correctly, you are asking about placement of the sub during the sub crawl.
The ideal spot is "in" (on) your seat, if you can do that without destroying the seating. You want it be roughly where your ears would be so you can crawl around placing your ears where the sub would be. In essence, your ears and the sub are trading places temporarily so you can find the spot where the sub would produce the best bass in the seating area.
Next best place would be on the floor exactly where your seating would be, but you say that isn't possible. If the best you can do is place it just in front of the seating, then that is the best you can do. Place it in front of your seating, do the crawl, find the spot where you are hearing the smoothest, tightest bass, place your sub there, and don't worry about it.
When it comes to our sound systems, most of us in the real world have to make compromises. When setting up your system, do the best you can then sit back and enjoy the movies and the music. If you are listening to your system rather than to the movie or music, you are missing the point.
Jack
Rijax is offline
post #4 of 7 Old 01-12-2012, 05:23 AM
GSDTrainer's Avatar
Hes asking about placing the sub in front of the main LP for doing the sub crawl placement test.
GSDTrainer is offline
post #5 of 7 Old 01-12-2012, 06:18 AM
Gorilla83's Avatar
Quoted: 374 Post(s)
Liked: 517
Phil - What type of seating do you have? Could you turn the sub on it's side and have the driver fire toward the wall or something while sitting on the seat?
Gorilla83 is offline
post #6 of 7 Old 01-12-2012, 08:01 AM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
I see that now. My near-field comment still holds true though.
Now, placing the sub near the primary LP is not the same as on the LP. But in your room, it may be. How many times have we heard that moving the sub a couple feet, and even less, has made significant improvements in the sound. In other rooms, large placement changes were needed to make a difference. So the answer is yes, but maybe no.
Randy
ransac is offline
post #7 of 7 Old 01-12-2012, 10:42 AM - Thread Starter
PhilT3's Avatar
Hey Andrew,
I have one row of four and one row of three. They are connected to each other... And main LP is in the middle of the row of four. It's a pain to disconnect them and move them.
PhilT3 is offline
