Best Buy Sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 01-14-2012, 10:10 AM - Thread Starter
Dahlyn's Avatar
So I have have about $160 credit at Best Buy and would like to get a subwoofer. I can add in about $50 so the price can be about $200. My reciever is 7.1 and can power a sub. To save money I was thinking an unpowered sub would be good but dont really see them.
Other considerations - I know that meeting my price, store and other parameters might not be possible looking for the best compromise:
I big cube can pose a problem. Width and height of the box are not an issue but depth is.
It is a medium to small room but it is open- a stair case to a loft area, two large entry ways and a door to another room.
Dahlyn is offline
post #2 of 22 Old 01-14-2012, 10:24 AM
Elisha's Avatar
Quoted: 308 Post(s)
Liked: 241
You're confusing a sub pre-out as a separate amp channel. The pre-out can only send the signal to your sub. You will still need an amp for the sub if you get a passive sub.
Elisha is offline
post #3 of 22 Old 01-14-2012, 08:04 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
A $200 sub from BB unfortunately isn't going to get you much of anything good. All the subs I've seen at BB are mostly junk.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 22 Old 01-14-2012, 08:23 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2989
I was just thinking that there is no sub that is a "best buy" at BestBuy.
If the credit is a gift card, better to sell it our save it for something else.
Also, "width and height of the box are not an issue but depth is" doesn't really help anyone to help you unless you say how much depth you have
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 22 Old 01-14-2012, 10:29 PM
cjsiv's Avatar
Liked: 33
If you absolutely have to stick with best buy, the best you will do is this one:
http://www.bestbuy.com/site/Bic-Home...&skuId=4235056
The BIC F12 is regarded as a great sub for the price. It's only online, but you should be able to use your gift cards there as well. I owned two of them and for under $200 they perform great. You will most likely be happy for what you paid. I've since upgraded to a Hsu, but if I were to buy from best buy, I would choose a BIC over anything else outside of magnolia. Hope this helps.
cjsiv is offline
post #6 of 22 Old 01-14-2012, 10:41 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
if they have the bic f12 at best buy, it would be the only one I would recommend out of what they have... even the magnolia hifi locations don't seem to carry that high end of stuff either.
stormwind13 is offline
post #7 of 22 Old 01-14-2012, 11:46 PM
Tdekany's Avatar
I am just going to throw this one out there for you. the pioneer SW8 Andrew Jones designed. Very tight and properly placed it should be way better than no sub. $150.00
Tdekany is offline
post #8 of 22 Old 01-15-2012, 02:26 AM
binarysoldier's Avatar
+1 for the BIC F12.
paired with Energy Micros and Onkyo 509 Audessy it sounds great.
I was actually shocked at how deep the sub sounds. For $187 shipped at Amazon I cant think of a better value
binarysoldier is offline
post #9 of 22 Old 01-15-2012, 06:26 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I would agree. The BIC is your best bet. I was only thinking of the B&M stores and forgot about online.
post #10 of 22 Old 01-15-2012, 08:21 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Andrew jones didn't touch the subwoofer some said its just a remake of the energy 8" that came with the Takes Classic
Spent $30 more for the Bic f12 and you will be heavily rewarded
crazyrob425 is offline
post #11 of 22 Old 01-15-2012, 10:34 AM - Thread Starter
Dahlyn's Avatar
I think I understand what a sub pre out is maybe I'm wrong. My 7.1 reciever, to my understanding, lets you use the the back speaker outputs to hook up a unpowered sub. There are a bunch of settings an the manual tells you how to do it. I'm I confused here.
Thank for the advice I will look into getting the f12 to fit into the room if an unpowered isnt an option.
Dahlyn is offline
post #12 of 22 Old 01-15-2012, 10:40 AM
cel4145's Avatar
Liked: 2989
If your receiver has powered speaker level line outs for a sub, then it is a HTIB receiver. It would be worth saving towards a better receiver in the future.
cel4145 is offline
post #13 of 22 Old 01-15-2012, 02:43 PM
benclement11's Avatar
It would be easier to tell us the make and model of your receiver. Then we can tell you what you have instead of guessing.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #14 of 22 Old 01-15-2012, 04:34 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
He wants to connect a passive sub to the speaker outputs and pass the audio through the sub to the speakers... should not be a problem its just different than what most people do.
Charlie
chashint is offline
post #15 of 22 Old 01-15-2012, 11:01 PM
Nosferatu's Avatar
Quoted: 144 Post(s)
Liked: 89
do they still sell the Def Tech Supercubes? Those are decent if size is an issue but it'll be out of your budget. I know newegg has them for dirt right now.
Thread to Build:Theater Build
Theater: Monitor Audio Platinum PL200/PL350C, Seaton Submerssive, 150" 3D Elite Screens +more
Living Room: Aperion Grand Verus, Outlaw LFM-1 EX, 70" Sharp Aquos +more
Stage 1 - Enthusiasm, Stage 2 - Realism
Stage 3 - Obsession, Stage 4 - Acceptance
...Which stage are you on?
Nosferatu is offline
post #16 of 22 Old 01-15-2012, 11:17 PM
Quoted: 443 Post(s)
Liked: 337
What's you receiver? Model number and brand?
Why the unpowered subwoofer? You are shooting yourself in foot with it
post #17 of 22 Old 01-15-2012, 11:22 PM
Quoted: 443 Post(s)
Liked: 337
That's not how a passive subwoofer works. Passive subwoofers require their own amp/ subwoofer hookup with speaker jacks. They also don't output audio to the speakers
What you are referring to is when a person with an active subwoofer runs the speaker out wire to the in on the subwoofer amp and then out of the subwoofer amp to speakers
post #18 of 22 Old 01-16-2012, 12:04 AM
kickerofelves's Avatar
He signed his name is on the back, so it must be true. I'm guessing it applies to assembling that whole Pioneer series which I see has gotten some good reviews. Isn't the woofer is different than the Energy (which is something I guess)?
Anyway I use the SW-8 in my home office with Audioengine A5s. It does a fine job for the $149 I paid for it. I'm waiting for an Outlaw M8 delivery next week. I'll play with the M8 and see how it compares. For the OP's Best Buy credit thingy the SW-8 is probably one of the best choices.
EDIT: Better for an inexpensive computer system set-up (SW-8) and the BIC is probably best for his needs now that I think about it.
kickerofelves is offline
post #19 of 22 Old 01-16-2012, 12:24 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
That is how the old passive subs worked. I had an old Cerwin Vega sub that used power from the receiver via the L/R speaker wires into the sub, and then speaker wire from the sub to the L/R speakers. The sub had an internal crossover but no external or internal amplification other than what it could get from the receiver.
post #20 of 22 Old 01-16-2012, 07:39 AM
cel4145's Avatar
Liked: 2989
No, not typically. Most passive subs were meant to run with external amplification. There are cheap passive subs that come with HTIB systems where the receiver has an extra set of powered speaker outputs for a matched sub.
cel4145 is offline
post #21 of 22 Old 01-16-2012, 07:48 AM
Quoted: 443 Post(s)
Liked: 337
Yes thats how the cheap passive subwoofer work these days.,. It's also very rare to find a receiver that supports them.
post #22 of 22 Old 01-16-2012, 12:37 PM
Believe it or not I picked one up on a whim at Fred Meyer in The Dalles of all places (see you're from Ptld).
