JL Audio E Sub series - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #91 of 166 Old 02-27-2014, 06:39 AM
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2097
Originally Posted by lees23 View Post
How about 2 E110's vs Rythmik/ PSA?
With the PSA sub I assume you were referring to the XS30?
The FV15 is an absolutely beast, so it probably has very similar output capabilities compared to those of the XS30. Each will have their own strengths and weakness, but overall you can probably expect them to perform comparably.
Co-located, a pair of E112's should come pretty close to either of those, but in the end I suspect they would fall a bit short in total output and extension. Sound quality wise the JL Audio's are easily the equal to virtually anything out there, and indeed are better than most. If you choose to place them in different locations -- in order to even out any nulls -- then they would have an advantage over the other two, but then you would lose the benefit of co-location (which is where you gain additional output potential).
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #92 of 166 Old 03-05-2014, 01:08 PM
JimWilson's Avatar
Liked: 2097
For anyone who might be interested, I posted my review of the JL Audio E112. It can be accessed using this link.
oneeyeblind and Dr. Jekyll like this.
post #93 of 166 Old 03-11-2014, 11:32 AM
TommmyJ's Avatar
Thanks very much for your review. It was very detailed and well written. Thanks
TommmyJ is offline
post #94 of 166 Old 03-11-2014, 03:09 PM
JimWilson's Avatar
Liked: 2097
You're welcome. I'm glad you found it useful.
post #95 of 166 Old 03-11-2014, 05:43 PM
jeremymak's Avatar
is e112 chest punching ??
jeremymak is offline
post #96 of 166 Old 03-11-2014, 06:09 PM
JimWilson's Avatar
Liked: 2097
It's definitely solid in the mid-bass, which is often what people consider 'chest punching', but it won't hold a candle to something like an FV15HP. It's targeted at a different audience.
post #97 of 166 Old 03-11-2014, 07:02 PM
TommmyJ's Avatar
Sound and vision also just published a favourable review of the E110 in their magazine.
TommmyJ is offline
post #98 of 166 Old 03-13-2014, 01:53 PM
AidenL's Avatar
Quoted: 542 Post(s)
Liked: 268
Seem to be very few owners of the Esubs?
Anyone have any opinions on them ?
Im considering a pit of E112s vs a single F113 - also versus a Sub 1 - any thoughts?
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Panasonic UDP 700 & HD Fury Linker| Apple TV3 | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Submersive Master/Slave |
Control : Control 4 |
AidenL is offline
post #99 of 166 Old 03-13-2014, 03:48 PM
duc135's Avatar
Quoted: 173 Post(s)
Liked: 228
That's because there are much better performers for the same price if you go with an ID company.
Yes, they are very nice, but overpriced for the performance you get out of them.
If you absolutely have to go with JL then I would recommend multiple E112s and place them properly around the room for best frequency response.
I understand the benefits of the JLs. They are probably one of the best performers in their size and are absolutely gorgeous in the piano black, but if you are not bound by those limitations then you can do much better if you consider ID companies like Rythmik, Seaton, JTR, SVS, HSU, PSA, Funk Audio, etc. DIY will destroy the F113 (performance wise) at a tiny fraction of the cost.
oneeyeblind likes this.
duc135 is offline
post #100 of 166 Old 03-14-2014, 09:24 AM
feistyacorn's Avatar
Quoted: 18 Post(s)
I'll be interested to hear what option you choose. I'm in the same boat with those exact 3 options. I've heard a F113 but not a E112 or Sub 1 yet. My local dealer plans on setting up a demo E sub soon. These options seem to give the best cost, WAF, output and SQ combination.
feistyacorn is offline
post #101 of 166 Old 03-14-2014, 05:32 PM
jeremymak's Avatar
Originally Posted by JimWilson View Post
It's definitely solid in the mid-bass, which is often what people conside'chest punching', but it won't hold a candle to something like an FV15HP. It's targeted at a different audience.
tell me more, jim
post #102 of 166 Old 03-14-2014, 05:54 PM
duc135's Avatar
Quoted: 173 Post(s)
Liked: 228
tell me more, jim
I'm not Jim, but JL Audio subs are for the people who want the best performance out of a very compact form factor with WAF in mind IMO. They are excellent subs for their size. ID subs like the FV15HP by Rythmik are produced more with performance in mind and with less emphasis on compactness. DIY can reach the complete opposite end of the spectrum. You can build a sub the size of a refrigerator at a very relative small cost that will decimate the JL Audio subs (Gotham included). It's all about balancing your wants and needs.
duc135 is offline
post #103 of 166 Old 03-14-2014, 07:24 PM
JimWilson's Avatar
Liked: 2097
+1
post #104 of 166 Old 03-14-2014, 07:35 PM
jeremymak's Avatar
+1
thanks guys
post #105 of 166 Old 03-15-2014, 11:37 AM
TommmyJ's Avatar
I don't think the JL's are as much of a compromise as some people think. I guess you can't argue with measurements but I went to 2-JL audio E112's from an SVS PB12-NSD/2 (which Ed Mullen had told me is close to the PB-13 ultra in output) and a PB-12 Plus and just don't really miss them all that much. I think the JL's sound great and for me don't seem to be giving up much compared to two top notch, well reviewed very large ported subs. My opinion and I am no expert by any means.
TommmyJ is offline
post #106 of 166 Old 03-15-2014, 12:17 PM
JimWilson's Avatar
Liked: 2097
They aren't a compromise, it's just JL Audio doesn't target the "best bang for the buck!" folks. Their customer is a different person is all.
Djoel likes this.
post #107 of 166 Old 03-16-2014, 06:27 AM
TommmyJ's Avatar
That's a great way to put it. Thanks
TommmyJ is offline
post #108 of 166 Old 03-21-2014, 09:33 PM
BVLDARI's Avatar
Liked: 27
I compared an e112 to an F113 in my home (very nice dealer let me take them home for 24 hours). I had them near the corner and then pulled them out of the corner a bit. F113 was on the bottom and the E113 was on top. They were both running off the same pre-amp - F was hooked up via XLR and E via RCA. I did the best I can to level match them using a hand held db meter.
My summary is very short and sweet: the E112 is stellar but the F113 is better yet. If money is an issue, I can tell you that you can get an E and you will be happy. If money is not an issue, then I would encourage you to listen to the F113. If you have space to put two subs in your place then I would strongly consider the E112 because you can get two for less than the price of one F113.
BVLDARI is offline
post #109 of 166 Old 03-22-2014, 05:23 AM
AidenL's Avatar
Quoted: 542 Post(s)
Liked: 268
I went on a detour via KK DXD 12012 and ended up buying a Sub 1 this week actually smile.gif
AidenL is offline
post #110 of 166 Old 03-22-2014, 08:20 AM
BVLDARI's Avatar
Liked: 27
I was fortunate enough to have the E112 and the F113 in my home for about 24 hours. Although I did not have the opportunity to test either of these to the extent that Jim did, I just wanted to say that my opinions of the E112 parallel those of Jim. He did a fabulous job describing and writing about it.
Thanks Jim for doing these reviews for us - they are very helpfu.
JimWilson likes this.
BVLDARI is offline
post #111 of 166 Old 03-22-2014, 11:25 AM
JimWilson's Avatar
Liked: 2097
You're quite welcome. I'm glad you found the information useful.
post #112 of 166 Old 03-24-2014, 10:15 AM
DJKham's Avatar
Thanks to everyone who has been populating this thread (and this forum) -love that there are always people here having healthy discussions about everything HT-related.
I'm a lurker most of the time on these forums but pop on to post the odd opinion when I come across new gear.
My main listening room is 20 x 20 with 8' ceiling and space/placement options are limited which is why I need a sub that's on the smaller side.
I upgraded from a Definitive SC6000 to an e112 as as the Def Tech was having to run really hard to keep up with my loud music/HT/gaming habits.
The JL is exactly what I was looking for and integrates very cleanly with my Marantz SR7005/Monitor Audio RX6 setup after some extent of experimentation with Audyssey and x-overs.
Comparing it to the Deftech SC6000 isn't exactly a fair comparison as the JL is about twice the price. Still, I would say that the biggest differences are the 1) power of the JL which works effortlessly at volumes that strained the DefTech, 2) the precision of the JL -moving to a sealed sub from a passive radiator configuration (SC6000) may also be at play but it sound "tighter" and 3) the range of the JL which goes audibly quite a bit lower -hearing some sounds I didn't even know where there in certain FLAC recordings which is probably helped by its 12" driver vs the Definitive's 9" primary driver and dual 10" radiators.
It's abundantly evident that I could have gotten other (subjectively) comparable subs for less money but I went with the JL because of the build quality, size and reviews.
DJKham is offline
post #113 of 166 Old 03-24-2014, 09:10 PM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
Quick question regarding the ash finish. How is the quality of the finish? Are the edges glue in nicely (finish), no rough edges biggrin.gif? I have a gloss f113 for the main room, but might interested in the e110 sub for the office which is 13x15ft.
tractng is offline
post #114 of 166 Old 03-25-2014, 07:44 AM
DJKham's Avatar
I've only seen one e112 and one e110 in person. Both we're flawless when it came to aesthetics. From what I can see, JL's quality control is very thorough and they don't ship anything that's less than perfect. Being made in the USA also helps in that respect. Don't think you would be disappointed.
tractng likes this.
DJKham is offline
post #115 of 166 Old 03-25-2014, 07:55 AM
JimWilson's Avatar
Liked: 2097
+1
Same here.
post #116 of 166 Old 03-25-2014, 10:18 AM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
Thanks guys.
tractng is offline
post #117 of 166 Old 03-28-2014, 03:48 PM
humbug2's Avatar
Quoted: 48 Post(s)
Since the word "wood" does not appear in JL Audios information on the E-112 am I correct in assuming the Black Ash finish is vinyl?
Does anyone know what the black gloss finish is material-wise?
"Most people would die sooner than think, in fact they do so."  Bertrand Russell The ABC of Relativity, 1925
humbug2 is offline
post #118 of 166 Old 03-28-2014, 04:21 PM
DJKham's Avatar
Correct. The black ash is a vinyl finish (that looks like wood). The gloss black (aka "Piano Black") appears to be some sort of acrylic coating if I had to guess.
DJKham is offline
post #119 of 166 Old 10-23-2014, 08:29 PM
chimneysweep's Avatar
Liked: 0
Comparison of e and f series
Hi
I am pretty new to the forum but this thread caught my interest without quite giving me the info I was looking for.
I am trying to compare the performance of the e series to the f series.
I have Magnepan 3.7s as my front stereo speakers (with MMC2s as rear).
I use my system 50/50 music and home cinema and want to add a pair of JL audio subs.
I wondered if anyone has a view on the f110s to the e112s which, due to discounts on the f series (in light of the upcoming v2), are now pretty much the same price.
My impression of various reviews I have read is the the new e-series maybe as good as the old f series (which I suspect will change with the v2) but its hard to confirm and I don't want to compromise if the f series is a better speaker.
I appreciate the e doesn't have the ARO or balanced cables input but am OK with this.
The benefit of being able to go to the e112 model is a slightly deeper extension of bass.
I would prefer this all things being equal but the main thing to match to the Maggies is a fast response.
From the data I have seen:
the f110 goes from 31.5-100Hz with a range of +/-3dB
the e112 foes from 27.5-125Hz with a range of +/-3dB
The db variance between 20Hz and 80kHz is +/-5.5dB for the f110 and +/-5.7dB for the e112 so virtually identical.
JL Audio publish the
f110 at 25Hz
e112 at 21Hz
My room would be classified as small to medium (17'x18') so I don't need the power of a larger sub to fill the room.
I would really appreciate if anyone has any views that would help my opinion.
chimneysweep is offline
post #120 of 166 Old 10-23-2014, 08:48 PM
duc135's Avatar
Quoted: 173 Post(s)
Liked: 228
I don't know what the street price of the JL subs are, but for considerably less than MSRP you can get a much better sub from ID companies like Rythmik, HSU, SVS, JTR, Seaton, etc. JL subs would only be a consideration to me if size were an issue. Some of the ID subs have very nice finishes, especially if you go with custom enclosures from Funk Audio. For example, the Rythmik F15HP in piano black is only $1400. The JL E112 can't touch the performance of any of the ID subs.
duc135 is offline
