REL T3 for $5 at thrift store! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-15-2012, 12:37 PM - Thread Starter
rohfan2112's Avatar
Just got it home, tests a.o.k! The only thing is it's missing its legs. I'm gonna have to fabricate them. Any suggestions?
The one on top is mine:
http://www.sumikoaudio.net/rel/prod_t3.htm
rohfan2112 is offline
post #2 of 14 Old 01-15-2012, 12:51 PM
benclement11's Avatar
$5, really? That's theft.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #3 of 14 Old 01-15-2012, 12:59 PM - Thread Starter
rohfan2112's Avatar
Yeah, he wanted $15 but I didn't know what it was at the time so I offered 5 just in case it didn't work. I figured at the very least the 8" driver looked SOLID and I could use that elsewhere if the amp was toast. After I got home and googled it I finally started to realize what I had. Tested good, now I just have to figure out something for legs.
post #4 of 14 Old 01-15-2012, 01:06 PM
drewTT's Avatar
Quoted: 706 Post(s)
Liked: 715
Wow. Lucky sob.
LG OLED65E6 | NAD C368 | Dynaudio Special 40 + Stand 3x | Oppo UDP-205 | Maingear Drift Z170 GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+
drewTT is offline
post #5 of 14 Old 01-15-2012, 01:09 PM - Thread Starter
rohfan2112's Avatar
My plan was to give it to my son for his 2ch computer system so he can have 2.1. His bookshelfs are Dayton B652s. His room is carpeted so I don't know how well it will integrate being that it's a down-firing sub. Maybe I should give him my Bic F12 and keep the REL for MY 2ch rig!
post #6 of 14 Old 01-15-2012, 01:14 PM
drewTT's Avatar
Quoted: 706 Post(s)
Liked: 715
The T3 is a big step up from the Bic. The last T3 I heard sounded excellent with music. Very tight and accurate.
drewTT is offline
post #7 of 14 Old 01-15-2012, 01:27 PM - Thread Starter
rohfan2112's Avatar
When you heard it, do you know if it was connected via the Speakon cable or via the RCA LFE input?
post #8 of 14 Old 01-15-2012, 01:35 PM
Having carpet and being down firing will have no negative effect on the performance.
post #9 of 14 Old 01-15-2012, 01:43 PM - Thread Starter
rohfan2112's Avatar
When I figure out how to fabricate some legs would you advise using carpet spikes? Seems the logical thing to do.
post #10 of 14 Old 01-15-2012, 01:46 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Sure. Parts express has a bunch of them.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #11 of 14 Old 01-16-2012, 05:52 PM
Bone215's Avatar
put it on 4 blocks of wood, you know the kind of blocks little kids play with?
deeper than the deepest ocean
Bone215 is offline
post #12 of 14 Old 01-16-2012, 06:06 PM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
I would contact REL first, to find out what it would cost for legs for it. Might be cheaper than you think and look better as well.
Iain- is offline
post #13 of 14 Old 01-16-2012, 06:50 PM
omegaslast's Avatar
Theres a passive radiator on the bottom... if you arent using legs then flip it over so the passive radiator is firing upwards
omegaslast is offline
post #14 of 14 Old 01-16-2012, 07:13 PM
dpc716's Avatar
Quoted: 13 Post(s)
Liked: 24
Home Depot has wooden legs with a threaded bolt attached. Just got some this weekend for a stand I made. Don't know if they would work for you.
dpc716 is offline
