Klipsh rw12d sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-18-2012, 04:27 PM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
hi just got a new klipsh rw12d subwoofer iam running it to a marantz 6005 reciever with a subcable.i would like to know if anyone has any settings for the sub as to which to use punch or depth or flat. also which volume to set on the sub. i had it at 0 and it sounded boomy thinking to go minus instaed of plus.also on the back what should be the hz setting on the sub
destiny 21 is offline
post #2 of 13 Old 01-18-2012, 04:51 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Try the "FLAT" eq and set the crossover all the way to the right wich turnes it off, thats what i use, or set it low to 60 or 55, somthing like that, its a good sub for the price, try that out and see if you like it.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #3 of 13 Old 01-18-2012, 04:53 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
I assume you have a 5.1/7.1 receiver. If so set it to flat with crossover to off and have your receiver does bass management.
tvuong is online now
post #4 of 13 Old 01-18-2012, 04:54 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
are you sure you have the RW-12D? if you do it should be on the top of the sub.
HT~
2.1CH~
Joshjp is offline
post #5 of 13 Old 01-18-2012, 05:09 PM
Jleblan1's Avatar
I like the humor of the Klipsch engineers to make the digital level adjustment go to "+11".
Jleblan1 is offline
post #6 of 13 Old 01-18-2012, 05:25 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Why is it so funny?
HT~
2.1CH~
Joshjp is offline
post #7 of 13 Old 01-18-2012, 06:23 PM
Jleblan1's Avatar
Josh See......
http://en.m.wikipedia.org/wiki/Up_to_eleven
Had to use mobile wikipedia because of the SOPA blackout.
Jleblan1 is offline
post #8 of 13 Old 01-18-2012, 06:31 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Josh See......
Ok i see now.
HT~
2.1CH~
Joshjp is offline
post #9 of 13 Old 01-21-2012, 08:22 AM
mr.pope's Avatar
makes me chuckle every time i mess with my sub.
mr.pope is offline
post #10 of 13 Old 01-21-2012, 08:56 AM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
Funny
Anyway I came in here to post Newegg's Shell shock Sat sale http://www.newegg.com/Product/Produc..._-Homepage2011
Don't know how great of a sale it is, but you never know.
DJoel
Djoel is offline
post #11 of 13 Old 01-22-2012, 04:06 PM
bifftannen's Avatar
Originally Posted by Djoel View Post
Funny
DJoel
thanks for the heads up. i just bought it because of this actually
bifftannen is offline
post #12 of 13 Old 01-22-2012, 09:32 PM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
You got it pal..
DJoel
Djoel is offline
post #13 of 13 Old 01-23-2012, 07:57 AM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
Also try to pull the sub away from a corner as much as possible, if that's the way you have it,( which is the first place people, (including me) put their subs, 98% times can be the worst). Run the Room correction setting if your AVR have any, it helps tame any unwanted anomalies!
Djoel
Djoel is offline
Klipsch Rw 12d 12 Subwoofer Each
