Should I get a better Sub? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 01-22-2012, 06:46 AM
Mupi's Avatar
Liked: 27
So from BIC F12 ($188) to Outlaw LFM-1 EX ($549)
That is from "Kick A**" to what? :-)
Mupi is offline
post #32 of 33 Old 01-22-2012, 12:05 PM - Thread Starter
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1063
Listing and tuning the F12 today with music (ipod) it really sounds good and gets pretty low! The problems with me is I do not have the same results with movies and that is 90% of my listing! It sounds OK with movies, but seems to distort or I can a sloppy bass. Also it sounds good close to it, but just across the room it fades out.
Reefdvr27 is offline
post #33 of 33 Old 01-23-2012, 06:53 AM
bayn's Avatar
Originally Posted by sputter1 View Post
Keep in mind that placement is key, a poor placement won't even make the best sub sound impactful.
I haven't responded because I've followed the one rule of AVS, once you buys something don't ever come back! These guys will get you to swap or buy something else in a heartbeat!
I've had HSU and SVS's sub's before although I've never listened to an Outlaw. But these guys never steer you wrong. The HSU sounded like they said it would, so did the SVS's and if they are telling you the Outlaw rocks, well then I'd buy one myself if I was looking.
Just follow the advice, now that you have a good sub coming and focus on getting the most out of your equipment with a SPL meter, placement and calibration tips from the forums before you go buying another sub. It can make more of a difference that upgrading especially if you make the mistake of placing the sub so that your seat is now in a null for bass waves (like I did once when I was starting )
An expert at anything was once a beginner...
bayn is offline
