Hsu VTF-3 vs Velodyne F-1500 vs SVS PB2-ISD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-20-2012, 12:34 AM - Thread Starter
KtrainHurricane's Avatar
Quoted: 38 Post(s)
thread re-named/re-created here: http://www.avsforum.com/avs-vb/showthread.php?t=1389254
...mods please delete this one
KtrainHurricane is offline
post #2 of 14 Old 01-20-2012, 06:17 AM
mrcoop's Avatar
Quoted: 35 Post(s)
Liked: 52
IMO, vtf 3...I owned one and loved it...that should be more then sufficient for that size room.
mrcoop is offline
post #3 of 14 Old 01-22-2012, 08:50 PM
razzy3's Avatar
which vtf3 version mk 1, 2, 3, or 4?
i just got a new subwoofer and now i want another one...what in the world is wrong with me?!
razzy3 is offline
post #4 of 14 Old 01-22-2012, 10:21 PM - Thread Starter
Quoted: 38 Post(s)
mk3
post #5 of 14 Old 01-23-2012, 08:19 AM
cacihome's Avatar
Quoted: 37 Post(s)
IMO,vtf then.
Cacimar Hernandez
cacihome is offline
post #6 of 14 Old 01-23-2012, 08:23 AM - Thread Starter
Quoted: 38 Post(s)
Thanks a lot for the input guys! ...Any comment on how something like the Outlaw LFM-1 EX would factor in and compare?
post #7 of 14 Old 01-23-2012, 08:29 AM
cacihome's Avatar
Quoted: 37 Post(s)
The EX is like a 3.3, but with more port noise down low...
Cacimar Hernandez
cacihome is offline
post #8 of 14 Old 01-23-2012, 08:35 AM - Thread Starter
Quoted: 38 Post(s)
Sorry to sound like a "noob," but I am not sure what ^that means
post #9 of 14 Old 01-23-2012, 08:35 AM - Thread Starter
Quoted: 38 Post(s)
(OP has been edited so please re-read!)
post #10 of 14 Old 01-23-2012, 08:42 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2989
Really, because both subs have been indicated to have some port noise when pushed very hard. How do you know which has more? Although, in his recent review where he noticed a little distress in viewing Terminator Salvation, Ricci noted that "The LFM-1 EX's performance with this piece of bombastic home theater bass was above and beyond what subwoofers in its price range would usually be able to provide. Impressive."
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #11 of 14 Old 01-23-2012, 09:00 AM
cel4145's Avatar
Liked: 2989
Between the EX and the VTF-3, in testing, the VTF-3 has been show to have a flatter frequency response and a little better low end extension. However, shadyj, who owns both, has said,
Originally Posted by shadyJ View Post
I have the VTF3 mk3 and the LFM-1 EX, they are mostly alike, and the differences are minor. The differences between the VTF3 mk3 and mk4 are pretty minor also. The down-firing ports are not a con unless the carpet is so thick they become blocked, you will want to have a little clearance for them. I would say the VTF3 has a slight advantage on paper that may not actually make a difference in practice. The VTF3 has more port volume than the LFM-1 EX which means it should be capable of more output at its tuning point. However, I can't tell the difference between the two, although I haven't tried pushing them hard enough in an attempt to notice any difference, because at that point they are both pretty loud, more than loud enough for me. I guess if I had to choose I would go with the VTF3, but only because of a few extra features and larger ports, but, like I said, in practice they are a lot more alike then they are different.
So between these two, you should probably base your decision on other factors such as do you want new with full warranty, do you like the look of one over the other, would downfiring serve your room placement better than the side firing of the VTF-3.
post #12 of 14 Old 01-23-2012, 03:18 PM - Thread Starter
Quoted: 38 Post(s)
How does this come into play? I do have carpet as mentioned in the above post, but it is not "thick enough to block down-firing ports"
post #13 of 14 Old 01-23-2012, 03:22 PM
cel4145's Avatar
Liked: 2989
If people feel the carpet is too thick, they get a riser like the Auralex Gramma.
post #14 of 14 Old 01-23-2012, 03:47 PM
spyboy's Avatar
Liked: 47
How easy is it for you to come up with another $149 for the EX? In a room your size, the EX shouldn't have to work too hard so you should be able to run it in Maximum Extension mode which gives strong response to at least 18Hz. Interestingly enough, Josh Ricci, who tested the EX for Audioholics stated that the EX is slightly mistuned. But, it is partly that mistuning that allows the EX to play as deep as it can with strong output. As much as I like the EX, it is fair to note that Josh noted the mistuning as a "Con". Even so, it seems that many EX buyers are quite happy. Not to say that everyone who buys an EX keeps it. That is why Outlaw has B-Stock sales on the EX for $574 delivered.
Warranty is a consideration as cel4145 noted. If you are really comfortable with buying used, the HSU 3.3 is a very good buy at $400.
spyboy is offline
