Dual 10" Polk Subs in custom trunk enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2012, 07:29 AM - Thread Starter
TJe0454's Avatar
Hey all. new to this forum. I have a Wrangler TJ that im going to be doing some more audio work on. Normally i use WranglerForum for my jeep stuff, but thought id get a better response about audio here! My idea is this: mount 2 downfiring 10" DVC Polk subs in a custom sealed enclosure behind my rear seats (trunk area). I wanted to put the amps (Alpine m500 and a 2 channel) below the enclosure mounted to the tub. I plan to mount the enclosure on sliders, so that i can pull the subs out if need be...any major concerns/issues with this? Ill try to find some pics to show you what i want to do.
Oh and im gonna wire them to get 4ohms load on the amp.
TJe0454 is offline
post #2 of 3 Old 01-20-2012, 07:39 AM
gtpsuper24's Avatar
Liked: 100
AVS is mostly home audio and video. You'll have better luck posting over here http://www.diymobileaudio.com/forum/ Car audio forum, lots of knowledgable guys over there that can help.
gtpsuper24 is offline
post #3 of 3 Old 01-20-2012, 07:54 AM - Thread Starter
TJe0454's Avatar
thanks. i just posted over there.
TJe0454 is offline
