Pairing a Sub with RC Micros? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2012, 06:41 AM - Thread Starter
DoggyD's Avatar
I have been looking for speakers to pair with a Yamaha RX- A700 receiver in a room that is around 13x20 with 8 foot ceilings. After much research, I decided to purchase a 5 pack of RC Micros - hard to pass up for the 150 currently on sale at Newegg. It looks like a may be moving in a year or so - and plan on upgrading with some larger energy speakers for the fronts when i do and using the micros to expand from 5.1 to 7.1 (or use them as height/ rears in 5.1). So finally to my question - I know the Micros bottom out at 150 Hz, and need to purchase a sub to fill out my current set-up to 5.1. Any suggestions? I don't want to break the bank - I looked at BIC f12 but saw that it may have a hard time above 100-120 hz, I don't mind spending more but would like something that would work well now and move into a larger room well later. I saw some posts on the subject, but they are all dated a bit... I also have an old pair of JBL g300's that i could add to the mix if needed to help with the midbase (if they would in fact help). I appreciate the help, you guys have already taught me more about HT than you can imagine.
DoggyD is offline
post #2 of 5 Old 01-27-2012, 06:51 AM
flickhtguru's Avatar
Liked: 110
Ok first off that room is decent size room and if your looking at moving sometime in the near future and have a bigger room, I highly suggest you don't skimp on a sub. My advice you be buy one good sub now and when money is available add a second identical one. I would look at $500+ internet direct subwoofers from brands such as: Outlaw Audio, Hsu Research, SVS, Epik, Rythmik, etc.......
For reference I have a 23'L X 11'W X 7.5'H room. I'm running 2 - Outlaw Audio LFM-1 Pluses. Bought them on sale for $499 each and free shipping. They sound amazing and I love them. I would recommend no less than 1 of these or an equivelant for a room your size.
Shawn
flickhtguru is offline
post #3 of 5 Old 01-27-2012, 06:56 AM
batt50's Avatar
depends on your budget. the epik legend or empire will work well with the micros. the outlaw lfm-ex is on sale now ($550). i also started with the micros and slowly moved up the energy ladder.
batt50 is offline
post #4 of 5 Old 01-27-2012, 07:02 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
HSU STF-2 could work well, although if you plan on upgrading to better Energy speakers up front, it could be worth getting a 12" ID sub now so you bypass the temptation to upgrade the sub after you get the new speakers
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 5 Old 01-27-2012, 08:53 AM - Thread Starter
DoggyD's Avatar
I had already looked at the HSU ST-2, wasn't sure if it would work well with such a high crossover requirement. I would like to keep the purchase in the 300-400 range - but it seems like it may be worth to spend a little more now and not have to upgrade later - although the option of 2 subs is always there as flick mentioned.. such difficult choices! Mostly using the system for movies/gaming at the moment...How can i look at specs and tell if the sub will work at a crossover of 150 Hz competently (or will I even need that high of a crossover?)? I can see how this could quickly become an addiction, i am already looking at new speakers and i haven't even gotten the new ones set-up properly!
DoggyD is offline
