AMP for JTR subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2012, 07:24 PM - Thread Starter
jzurek's Avatar
I am looking at finally making the break and pick up a pair of the passive JTR Captivator's was looking for some good recommendations on a Killer amp that will run both of these. They are going in about a 6k sq ft room and prefer to get one amp that can run both easily but could go with 2 if it made more sense. i am trying to keep this around $1k-$1200 for the Amp.
jzurek is offline
post #2 of 7 Old 01-31-2012, 07:36 PM
HuskerOmaha's Avatar
Quoted: 54 Post(s)
Liked: 50
If you can run the risk of a potential faulty amp and the steps and troubleshooting that may exist, a LG clone amp would be perfect for what they can take....see the LG clone amp 14k thread in the diy section.....
Can you get the subs in 4 ohm config or only 2 and 8?
HuskerOmaha is offline
post #3 of 7 Old 01-31-2012, 08:20 PM
Sidewayz's Avatar
With that price point you should be able to EASILY find amps that will more than fill the bill. I found a great deal on a Crown XTi 4000 (around $550 shipped) a couple months back and use it on my JTR subs. The XTi's have onboard EQ so you can shape your response better to suit your room. I am sure you should be able to find something. Have you considered asking Jeff at JTR what he might recommend? Good luck!
Toymachyne likes this.
Sidewayz is offline
post #4 of 7 Old 01-31-2012, 10:11 PM
the Son's Avatar
Jeff recommends (I use that term loosely) the Crown XLS5000. Check it out at www.uniquesquared.com. I will be using one each per Captivator. (8-ohm bridged)
....but it doesn't have DSP, if needed. I also have a DCX2496, so I didn't need a DSP amp.
the Son is offline
post #5 of 7 Old 01-31-2012, 10:52 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
Use that XLS5000 on the 2011 Captivators with a 14hz HPF from some other device, and the 2012 Captivators with a 16hz HPF, and you're set. Congrats!
nube is offline
post #6 of 7 Old 01-31-2012, 11:27 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
bsoko2 is offline
post #7 of 7 Old 02-01-2012, 12:25 AM
the Son's Avatar
Originally Posted by bsoko2 View Post
534 at http://dealnews.com/Crown-XLS-5000-1...ng/534590.html.
Coupon codes are expired. uniquesquared has no open coupons, but still the best price.
the Son is offline
