What sub to pair with Empire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-01-2012, 05:15 PM - Thread Starter
jmnaas's Avatar
I have one Epik empire and am looking to add another subwoofer to my theater. I want to stay around $1000. I would not mind adding another empire but was wondering if there might be another option that would hit harder. Placement may be a problem. My room is 18ft across front, 15ft deep and 8 ft high. As I look at screen there is a 10 foot opening on left with rest of room enclosed. My sectional only allows placement in rear left corner or beside sectional on the right. Front corners of the room are filled with cabinet and fireplace. My empire is now in the left corner. The new sub would have to be along right side wall or swapped with empire. The hsu 15 inch ported and sealed subs have stellar reviews. I do not know if the would blend well with my empire. I am looking for the kind of bass that you feel in your chest. Thanks for any help.
jmnaas is offline
post #2 of 4 Old 02-01-2012, 05:21 PM
Hksvr4's Avatar
Quoted: 28 Post(s)
Liked: 34
You should stick with the same sub you have. Acoustically, it's not a good idea to mix subs. I found out the hard way. Get another Empire and you will have more chest thumping bass.
Hksvr4 is offline
post #3 of 4 Old 02-01-2012, 05:22 PM
benclement11's Avatar
everyone is going to recommend another empire if you plan on using both subs. people will not recommend using two different kinds of subs. especially since the empire is at the same price point. buy another empire.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #4 of 4 Old 02-01-2012, 05:27 PM - Thread Starter
jmnaas's Avatar
Thanks. I guess I will go with another empire I have been very happy with it so far. Just want a little more.
jmnaas is offline
