Best bang for the buck? ~$1000 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 33 Old 02-04-2012, 01:17 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Originally Posted by brutal0101 View Post
Sorry that I am going off topic but what do you use your EMO XPA-3 for because I think wouldn't just the receiver been enough to power your Monitor 70 since they can't handle much or does the External Amp really makes a big difference because I have the Polk RTI 12 and I only use my Onkyo NR609 to power them Bi Amped, is an external amp like the XPA-3 really worth it? Does it really make a big difference? Thanks
You can't really biamp with the NR609. Actual separate power amps would be much better. I use my Onkyo avr just as a preamp for the L/C/R channels, I use two 250/w per channel amps; L/R share, center gets it's own. Use the avr just for the surrounds and back surrounds since they don't need so much.... but someday that might change
lovinthehd is offline
post #32 of 33 Old 02-04-2012, 03:19 AM
the Son's Avatar
That's a beautiful sight man!
Thank you!!!
As I said, it was my vision from the start, but it turned out WAAAAY better than I thought it would.
the Son is offline
post #33 of 33 Old 02-04-2012, 06:46 AM
trolly's Avatar
Quoted: 62 Post(s)
Liked: 48
I would highly encourage the PB12-Plus-maybe one of the outlet deals. I auditioned the PB12-nsd and it's a great sub for the money, I currently have Empires downstairs and they are a good value but the PB12-Plus is the total package in terms of quality (inside and out) and performance.
trolly is offline
