Will a good sub improve sound? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2012, 08:24 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Originally Posted by oztech View Post
Well said and I will add that one good sub will still be better than two mediocre subs especially if music and low end extension are priorities.
^ Word
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
Old 02-09-2012, 08:47 AM - Thread Starter
eugle's Avatar
Well, reading this forum many times, i am aware that multiple subs smooth out FR and make bigger sweet spot.
What i don't inderstand is what was said in that article about audible phase stereo information in very low frequencies, a kind of information that mono sub can't reproduce... maybe its just that i got it wrong.
eugle is offline
Old 02-09-2012, 09:01 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Can you post a link?
Nuance is offline
Old 02-09-2012, 09:09 AM
oztech's Avatar
Liked: 101
I doubt that most people can tell where low frequencies originated from in a room and I am talking about below 60 Hz it usually gives the feeling of all around you. If it were that noticeable then there would have been stereo outputs for subs long before now especially on high end gear. You also got to remember the industry is in it to make money so whatever can spark interest and sales will be implemented be it a perceived or actual improvement just look at interconnects and power cords the latter really gives me a laugh.
oztech is offline
Old 02-09-2012, 09:15 AM - Thread Starter
eugle's Avatar
2Nuance
this one http://kenrockwell.com/audio/stereo-subwoofers.htm
especially
While low frequencies are less directional, and the direction of a low-frequency sine-wave point-source may be less perceptible, critical to fine music reproduction are low-frequency interchannel phase differences present in true stereo recordings. When reproduced properly with stereo subwoofers (or two full-range speakers), these phase differences are critical to reproducing the sound space of the original concert hall.
Try jamming a stereo bass signal through one mono subwoofer and you lose a lot of hall ambience as well as bass level.
And so on...
He also says that Mono Sub became standard because of limitations of analog audio formats.
I haven't seen this being discussed previously
eugle is offline
Old 02-09-2012, 09:34 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
2Nuance
especially
And so on...
A. This appears to be anecdotal rather than scientifically derived. I'd be interested to see double blind testing that covered the issue. The way I understand it, to hear phase differences at low frequencies, our heads need to be several feet wider.
B. You left out what appears to be the description of why sub content is localizable:
"While a pure 40 Hz sine wave can't be localized, subwoofers almost always produce some higher-frequency sounds that can. Subwoofers generate plenty of harmonic distortion (higher frequencies) which are easy to localize, and vented subwoofers have higher-frequency wind noise as they are pushed harder."
So it depends on whether your sub is extending too high or making enough distortion for that to be localizable. Both are controllable. Vross over lower and/or steeper; play the sub within it's limits (with the corrolary obtain a sub that can play the frequency range you desire without undue distortion at the levels you require).
JHAz is offline
Old 02-09-2012, 09:40 AM
oztech's Avatar
Liked: 101
I think think localization was another reason THX recommends no higher than 80Hz.
oztech is offline
Old 02-09-2012, 10:15 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Well said, JHAz - I completely agree. It sounds like bunk to me, as I've never seen anything that confirms humans can hear phase differences down near the nether regions of the audible spectrum. I could be completely wrong, though, and fully admit that.
Nuance is offline
