Three choices, Need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-15-2012, 06:55 AM - Thread Starter
jeremymil's Avatar
Ok I have bought my denon 2112 receiver.
Pioneer 5-1/4" Floor Speakers, 4" Bookshelf Speakers & Center Channel Speaker (From best buy)
And the Last (but not least) is the sub. I am already getting close over my budget so I am looking for the best bang for my buck.
#1 JBL E150p (I can get this brand new localy for $125)
#2 BIC America F12 (can get for $188)
#3 Bic Acoustech Cinema Series H100 (can get for $235)
I know these are all budget Subs. My question is am I going to notice much difference between them?
jeremymil is offline
post #2 of 5 Old 02-15-2012, 07:07 AM
flickhtguru's Avatar
Liked: 110
If you can up your price to just under $300 you can get the BIC Acoustech PL-200 250 Watts RMS Continuous and freq resp of 22hz -3db. http://www.acousticsounddesign.com/c...pid=1555&sc=28
Make an offer of like $280 or $300 delivered to your house.
Shawn
flickhtguru is offline
post #3 of 5 Old 02-15-2012, 07:13 AM
mde8965's Avatar
Quoted: 24 Post(s)
Of those choices, in order of best to worst it would go #3, 2, 1.
You might also want to look at the BIC Accoustech PA-120W which should be able to be had at a lower price than what you quoted for the H100 by submitting your best offer here:
http://www.acousticsounddesign.com/c...pid=1205&sc=28
Main System: Denon AVR-4311ci; Emo XPA-5, Panasonic TC-P65ST50, Oppo BDP93, PS2&3, Wii, Sonos Connect, Mede8er, Roku 3
Ascend RAAL Towers, RAAL Horizon Center, Sierra 2's (surround), Def Tec SM350's (rear surrounds), 2 Rythmik F15's
2 other systems: 1 Onkyo, 1 Denon, Paradigm Studio V1 and V2 speakers, Panasonic Plasmas, etc.
mde8965 is offline
post #4 of 5 Old 02-15-2012, 07:52 AM
Liked: 110
You mean Premier Acoustic not BIC Acoustech
Shawn
post #5 of 5 Old 02-15-2012, 09:02 AM
mde8965's Avatar
Quoted: 24 Post(s)
Yup
mde8965 is offline
