Anyone ever regret buying a SVS PB-12NSD ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 151 Old 02-19-2012, 10:58 AM - Thread Starter
E-A-G-L-E-S's Avatar
To those of you who have auditioned and or owned an SVS PB12-NSD, did anyone ever regret their choice? As in, they ended up going bigger to find what they were looking for?
(for say 2500 cu ft spaces or less)
E-A-G-L-E-S is offline
post #2 of 151 Old 02-19-2012, 11:05 AM
eljaycanuck's Avatar
Quoted: 1349 Post(s)
Liked: 1963
I have owned both a PB10-NSD and a PB12-NSD (the older, BASH-equipped models). Both subs were awesome performers for the money. The only reason I eventually sold my PB12 was because I needed a bit more oomph in my newly-finished, laminate-over-concrete, ~3,375 cu.ft. basement HT room.
But I don't ever regret having owned either SVS sub.
eljaycanuck is offline
post #3 of 151 Old 02-19-2012, 11:21 AM
datranz's Avatar
Quoted: 58 Post(s)
Liked: 43
Get the biggest one you can afford and never regret. Saves money in the long run
datranz is offline
post #4 of 151 Old 02-19-2012, 11:46 AM
drewTT's Avatar
Quoted: 822 Post(s)
Liked: 831
I started out with the Bash PB12-NSD. I liked it but it wasn't quite enough for me. I also got it to make some strange noises when pushed really hard. I believe the newer Sledge models do have better control over the driver.
I did end up going with PB12-Plus. That was a nice upgrade.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | Apple TV 4K
drewTT is offline
post #5 of 151 Old 02-19-2012, 11:53 AM
ratm's Avatar
Quoted: 41 Post(s)
Liked: 39
+1. Dealing with that right now
ratm is offline
post #6 of 151 Old 02-19-2012, 12:10 PM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
No Doubt!
Reefdvr27 is offline
post #7 of 151 Old 02-19-2012, 12:39 PM
SmokenAshes's Avatar
Liked: 53
Does a VTF-3 MK4 have more oomph than the PB12-NSD?
SmokenAshes is offline
post #8 of 151 Old 02-19-2012, 01:11 PM
Luis Gabriel Gerena's Avatar
Quoted: 97 Post(s)
Liked: 64
Indeed. Based on the many posts I have seen from you, you are over thinking this. If your max budget is 1K then do the VTF-15H and enjoy. I doubt you will ever need 2 in that room and you will have a lot of power. You are losing valuable movie viewing time by over thinking
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #9 of 151 Old 02-19-2012, 01:33 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
You'll never get a satisfactory answer to that question. They are the same class of sub. One might perform better in your room in one spot than other, or vice versa. Pick between those based on features, appearance, etc.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #10 of 151 Old 02-19-2012, 01:52 PM
Liked: 53
Do they both have the same reliability?
post #11 of 151 Old 02-19-2012, 01:59 PM
kesando's Avatar
Liked: 31
+1
I intended to get a PB12nsd and ended up with a Plus and I am very happy I did
kesando is offline
post #12 of 151 Old 02-19-2012, 03:30 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
I'm know I'm going to take flak for this, but I think the VTF3 will have more oomph than the PB12. Take a look at these charts, specifically the CEA2010 Max clean RMS Subwoofer output from Josh Ricci's measurements. Compare the PB12-NSD's measurements to the Outlaw EX's. The Outlaw has more twice the clean output capability of the PB12 from 30 hz on up, at certain points a lot more. The VTF3 is a lot like the Outlaw EX, except more features and deeper bass extension. To the PB12's credit, it has an amazingly flat frequency response, but that won't be a big deal if your room correction EQ is going to be reshaping the FR anyway.
shadyJ is offline
post #13 of 151 Old 02-19-2012, 03:35 PM - Thread Starter
....this is something I do not understand, the rest I do.
post #14 of 151 Old 02-19-2012, 04:00 PM
shadyJ's Avatar
Liked: 1352
The subwoofer's frequency response will be flat, but only in an anechoic setting, or semi-anechoic setting like an open outdoor area. When you place it in a room, the response will inevitably see some pretty severe peaks and dips. Most mid and higher end AVR's come with a room correction EQ like Audyssey or Yamaha's YPAO or Pioneer's MCACC just to name a few. This will measure the room's effect on the sub's frequency response and compensate for it by adjusting the outgoing signal to the sub. But the EQ itself doesn't know whether its compensating for the room's uneven frequency response or the sub's; you will end up with a corrected response regardless.
There are some real benefits to having a flat frequency response, but in this case the Outlaw has a headroom advantage at almost every frequency, and since neither sub will have a flat FR in-room and will get corrected by the AVR anyway, the SVS's flat frequency response advantage is negated.
shadyJ is offline
post #15 of 151 Old 02-19-2012, 04:08 PM - Thread Starter
Then in your opinion, the VTF3-MK4 vs LMF-1 EX?
I have a Denon with Audyssey.
Rectangular sealed room, wood framed with sliding glass doors on one end...~2100 cu ft.
I can't find any charts with multiple subs' spl readings that include the VTF3-MK4
post #16 of 151 Old 02-19-2012, 04:32 PM
kesando's Avatar
Liked: 31
+1
The only area I see the PB12nsd having an output advantage is down low and even then, the HSU can be retuned for max extension (at the expense of upper bass)if need be.
kesando is offline
post #17 of 151 Old 02-19-2012, 04:34 PM
NewHTbuyer's Avatar
Liked: 42
ShadyJ,
I don't doubt the above, but it makes me wonder. Why so much effort by speaker and sub manufacturers to try to make speakers flat if you can just throw together anything and room correction software will flatten it out. My gut tells me it is more complicated than that, but I don't have the knowledge to answer why.
NewHTbuyer is offline
post #18 of 151 Old 02-19-2012, 04:35 PM
kesando's Avatar
Liked: 31
I would give the edge to the HSU due to the extra port area over the outlaw as well as the extra tuning options including Q control and sealed mode. That said, if the Outlaw can be had for its $550 shipped sale price, it is a great value.
kesando is offline
post #19 of 151 Old 02-19-2012, 05:04 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
The Outlaw would be my choice (at the sale price). It certainly has more output. I used to have the VTF-3 MK3 before buying the 15H. The MK3 was no slouch. It can rattle and shake a room just like the 15H. The Outlaw should be very close to the MK3/MK4. With that being said, the Outlaw-HSU-SVS should all be great performers in your room. I wouldn't hesitate to purchase any of them. Find the one with the best price and never look back.
Sepen is offline
post #20 of 151 Old 02-19-2012, 05:32 PM
shadyJ's Avatar
Liked: 1352
EAGLES, both the VTF3 and Outlaw are killer subs. Both subs can blaze pretty nicely. I would take the VTF3 over the Outlaw though, mainly due to the longer, larger ports, with the Hsu can actually hit 16 hz with some pretty serious output. The Outlaw can get low, but not that low, at least not without chuffing with any serious output. The VTF3 also comes with a Q control and support for a sealed mode, but the sealed mode does not excite me, as one of the VTF3's greatest advantages is its port configuration. The improvements made on the mk4 modal don't look like they have affected the performance in any major way. Anyway, when you factor in the current sale price on the VTF3 and the Outlaw being backordered until late March, this decision is a no-brainer: go for the Hsu.
shadyJ is offline
post #21 of 151 Old 02-19-2012, 05:36 PM
Liked: 53
Thats the thing though, the Outlaw is sold out until March 26th. I placed my order back in Jan when it said estimated ship date Feb 27th and I don't even know if it got pushed back another month. They never sent me an email stating anything other than that I'm on the reserve list when I asked back in Jan. I would really like to know whats going on but they aint saying anything unless you call and ask which I'm going to be doing as soon as they open up tomorrow.
post #22 of 151 Old 02-19-2012, 05:41 PM
shadyJ's Avatar
Liked: 1352
Originally Posted by NewHTbuyer View Post
ShadyJ,
Aside from marketing reasons, the main advantage to having a flat response when you factor in room correction is that you know the sub has no weak spots. Lets say you have a big room response dip which is right on a same frequency as a dip in the sub's natural frequency response. Now you have to bring a heavy tax to a sub right at its weak spot, this could make for some major distortion.
shadyJ is offline
post #23 of 151 Old 02-19-2012, 07:35 PM
-RONIN-'s Avatar
Agreed! Over thinking is definitely present with E-A-G-L-E-S in this situation. Given the class of sub being looked at I think one would really be splitting hairs on the differences and will almost certainly be happy with either you go for. Pick the biggest, most powerful one you can afford and be done with it.
If you think hard enough and analyze deep enough, one could find things to nitpick with most any product.
-RONIN- is offline
post #24 of 151 Old 02-19-2012, 08:06 PM - Thread Starter
If the VTF3-MK4 is the same as the MK3 in terms of output across the board, does anyone have a link to the MK3's tested levels? To compare with the other options which I have seen the results for.
post #25 of 151 Old 02-19-2012, 08:23 PM
Liked: 53
Would this link work for ya?
http://www.hsuresearch.com/reviews/vtf3mk3rew.pdf
post #26 of 151 Old 02-19-2012, 08:50 PM
cel4145's Avatar
Liked: 3002
Good test data:
http://www.hometheatershack.com/foru...um-output.html
http://www.hometheatershack.com/foru...extension.html
cel4145 is offline
post #27 of 151 Old 02-19-2012, 08:58 PM
Liked: 53
I feel like a cave man figuring out a math problem while looking at these graphs.
post #28 of 151 Old 02-19-2012, 10:35 PM
cel4145's Avatar
Liked: 3002
You can read and study those graphs, the ones for the PB12-NSD and the EX, and still be no better off at making a decision. It's very close.
I will say this about the VTF-3.4. I think the sealed sub mode is mostly gimmick, in that if someone wants a sealed sub, then buy one that was specifically designed to be a sealed sub. For most people it will be an unused option. And I suspect that the Q tuning it not super useful unless one is taking sophisticated measurements with a mic and REW or maybe through using the SMS-1 sub EQ. Otherwise, it will be mostly guess as to how to tune it that finely.
If I had to pick between the VTF-3.4 and the PB12-NSD, I'd probably go with the PB12-NSD for the lower distortion below 30hz.
cel4145 is offline
post #29 of 151 Old 02-19-2012, 11:02 PM - Thread Starter
Well, I stayed up much too late and I'm taking a slight headache to bed...but I just ordered my SVS PB12-NSD. Time for a little sleep.
Thanks guys!
post #30 of 151 Old 02-19-2012, 11:03 PM
Liked: 53
Well I was set on getting the VTF-3.4 and then you chirp in on this. GAH!!!! I thought one of the good things about the VTF-3.4 was how low it can go.
