Which sub to a simple Def Tech Mythos 5.0? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2012, 06:18 AM - Thread Starter
kimare's Avatar
I've got a room which is 13" x 15", my planned setup is this:
Mythos Six (front)
Mythos Seven (center)
Mythos Gem (rear)
ProSub 800
Yamaha RX-V671
I wonder if its worth upgrading the ProSub800 ($350) with a Supercube I ($875) or SVS SB12-NSD ($699). The usage would be 80% games and movie and 20% music.
The volume would be normally used low to medium, but I would be nice to have the option to pump it up when we feel for it.
If I upgrade, which do you think would match my roomsize and Mythos set best?
This picture is a bit inaccurate with the placement of the couch, but will give an idea of the room.
kimare is offline
post #2 of 4 Old 02-25-2012, 05:00 AM
Ericthemidget's Avatar
Don't waste your money on a super cube. Get the SVS
Ericthemidget is offline
post #3 of 4 Old 02-25-2012, 12:06 PM
spyboy's Avatar
Liked: 47
Supercube I was discontinued several months ago. At that time the SC I could be had for $500. Even so, the size of the SC I restricted overall output, and low bass extension. There are better choices.
spyboy is offline
post #4 of 4 Old 02-25-2012, 03:50 PM
kesando's Avatar
Liked: 31
Is it a must for your sub to have a small footprint? What is your max budget?
kesando is offline
