Budget subwoofers discussions, opinions and questions thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 115Likes
post #3151 of 3578 Old 03-31-2015, 06:39 AM
[Irishman]'s Avatar
Quoted: 182 Post(s)
Liked: 123
Originally Posted by RoninStang View Post
The usual which budget sub questions...
My place is an open concept where my HT is. The space is around 4500 cubic feet, and opens up to around 6000 cubic feet if other doors etc open. I know a budget sub isn't going to fill the room, I just want the best bang for the buck.
Budget is $300
But limited on size for WAF and placement issues.
The sub can only be around 20" Depth X 16" Wide X 21" Tall.
I plan on building an isolation platform that will be around 2-4" tall to bring the sub up to about 24" (2 ft) so it can be used as an end table as well. Nothing permit will be placed on top though. The floors are hardwood.
The sub will be placed in a corner next to the couch. So sitting position will be close to the sub, either right next to it or max like 4-5 feet away.
If rear firing port it will be against the back of a wall with about 3-4" to spare. If the port is down firing could go a little closer to wall.
If a front firing sub the driver will be pointed towards the TV. I know the sound is Omni-directional but would a down firing help at all or would it matter?
Will be approx 75% Gaming/Movies & 25% Music.
Top Choices:
- BIC PL-200 seems solid , recommended a lot, great warranty.
- NXG NX-BAS-500 , great performance, but the Auto On/Off problem seems annoying, and it seems like a decent amount of people have had problems with Amps or Drivers on them going bad. Also as mention in Jim's review it seems to vibrate a lot, would the sub isolation platform eliminate this?
Second Choices:
- Klipsch SUB-12HG , on sale right now on Amazon, down firing, but seems to have bad amp issues.
- Premier Acoustic PA-120, seems to get good reviews, but looks like the PL-200 or NX-BAS-500 outperform it.
- Dayton SUB-1200, getting a little wide, but cheap for performance.
I also looked at the HSU STF-2 , but it seems like the 10" Driver would even have a harder time filling the room, and would just be a waste either way.
My hope was to find a used Outlaw LFM-1 Plus since size is perfect but have had no luck , plus issues if something happens when buying used.
That's about it lol, thanks for the help!
I second the Hsu STF-2. Driver size doesn't impact how hard a sub must work to pressurize a room. All of your choices will have the same problem, which is the open floor plan. None of them will give you that visceral, kick-in-the-chest feeling that a better sub can in your space. Can you offer some more details of how and where the listening area opens to the other spaces? Especially with regard to where your theater is located? Also, lastly, do you have any flexibility as to where you can place your sub? An end table, while allowing your sub to pull double duty in your theater, may not provide you with the best - or even good - sound in that spot.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
post #3152 of 3578 Old 03-31-2015, 08:01 AM
humbland's Avatar
Quoted: 443 Post(s)
Liked: 93
+1 with Jim on the need for total output. Your Paradigms will handle the "quality" aspect. Cross them over at 80 hz and use the sub to fill in the low end...
My $.02: If you want LFE "vibrations" for movies and games, then adding bass shakers for the seating is the cost effective way to go. We have Buttkickers in the couch and they add the "feel" of a big money sub without the expense or the structuctural impact (not to mention the good neighbor factor). We had a twin SVS Ultra for awhile. Great sub , huge box, big money. It was fun, but with neighbor complaints and worries about the windows...We sold it, got a couple of smaller, less imposing subs and added the bass shakers. The best of both worlds, INMO.
humbland is offline
post #3153 of 3578 Old 03-31-2015, 08:04 AM - Thread Starter
JimWilson's Avatar
Quoted: 1533 Post(s)
Liked: 2039
Transmaniacon likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3154 of 3578 Old 03-31-2015, 09:07 AM
Liked: 2
Jim - Yes, that makes a lot of sense, as to why the PL-200 could have been a better fit. Good insight.
For me, I think it will be a good tradeoff. With my old system, I rarely pushed it hard on HT (due to sleeping young kids upstairs & a wife that got anxious about waking them). And that system had small satellites and relied more heavily on a weaker sub. Simply put, I think I would be bothered more by poor SQ more than lack of output, so I think it is a good concession.
I guess if I am really wanting more after watching a few films, I could send it back.....Or more likely, be one of the many future "upgraders" on this forum. But truthfully, I think it will be more than adequate for me.
jake12345 is offline
post #3155 of 3578 Old 03-31-2015, 10:02 AM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
I hope it works out for you. Might get best results by sitting next to it.
Not sure if you're aware but you have to pay return shipping on the stf2. It cost me $75.
Bond 007 is offline
post #3156 of 3578 Old 03-31-2015, 11:45 AM - Thread Starter
JimWilson's Avatar
Liked: 2039
I think that's essentially every one of us...
post #3157 of 3578 Old 04-02-2015, 07:01 AM
slarity's Avatar
Quoted: 153 Post(s)
Liked: 74
So what's the consensus on the Polk PSW505? I'm not a huge Polk fan but for $179 today only this seems like a pretty good deal. I got a buddy putting his theater together now and think one or two of these might work well for him.
slarity is offline
post #3158 of 3578 Old 04-02-2015, 04:55 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
I haven't heard that one myself - so I can't comment from direct experience - but from the posts I've read it sounds like it's decent for HT but less impressive with music. An argument could probably be made that it's not too dissimilar from the SUB-1200. If so, that's about $50 cheaper so it might be worth considering as well.
post #3159 of 3578 Old 04-06-2015, 12:18 PM
Liked: 0
Originally Posted by Bond 007 View Post
Good choice.
Very late reply here. Just wanted to say thanks again for the recommendation. The Dayton sub was an excellent choice for my living room. The amount of bass is incredible! My wife hates me when we watch horror movies and the sub scares the crap out of her. Music and movies have all been improved by adding this sub to my sound system.
philharmonik is offline
post #3160 of 3578 Old 04-06-2015, 12:36 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
Glad to hear it worked out for you. It's quite a lot of sub for very few dollars.
post #3161 of 3578 Old 04-15-2015, 02:14 PM
Liked: 0
$700 Sub System Better Than Sony Shake-33?
I could use some advice putting together a simple sound system for playing music, mostly bass-heavy electronic, in a medium size living room.
Budget: $700. Ideally I'd like a good sub-woofer, speakers with good clarity and power, and an receiver with bluetooth and/or USB input.
The pre-assembled option to beat is the Sony Shake-33. I'm a big Klipsch fan, but they're obv expensive and cannot be used for all components, hopefully one or two.
Ideas?
pbody27 is offline
post #3162 of 3578 Old 04-15-2015, 07:35 PM
Bond 007's Avatar
Liked: 2090
Ideas?
Start a new thread in the speaker forum. You will get all kinds of help there.
Bond 007 is offline
post #3163 of 3578 Old 05-06-2015, 04:28 PM
Cucuy's Avatar
Quoted: 18 Post(s)
Looking for some initial recommendations on where to go as far as sub selection. I am putting together a game/movie room in a spare bedroom that's a little small . Probably will go with a
5.1 system with in walls for fronts and in ceiling for surrounds since I don't have a lot of space. I have approximately 1100 cubic feet and want to get an idea of how much money would
be needed and which sub to get to move up in sound quality and impact from my current setup with a PSW100 that came as part of package a long time ago.
Main use would be for console games, bluray movies, and shows streamed from netflix and amazon. I would love some impact in my bass and I don't get much with the Polk.
I prefer to stay around 200-300 bucks.
Thanks in advance!
Cucuy is offline
post #3164 of 3578 Old 05-06-2015, 06:37 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
The oft mentioned NXG NX-BAS-500 sounds as though it would be a good candidate, along with the BIC F12 (another favorite).
post #3165 of 3578 Old 05-06-2015, 06:43 PM
MIX_MASTER_ICE's Avatar
Quoted: 1388 Post(s)
Liked: 1163
Jim, how come you never tested/reviewed the Klipsch sub-12?
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Polk M60 SII, SVS PC12NSD x2 subs. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Bic V1020 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
MIX_MASTER_ICE is online now
post #3166 of 3578 Old 05-06-2015, 06:44 PM
sk373's Avatar
Quoted: 292 Post(s)
Liked: 432
Thanks in advance!
The Dayton SUB1500 for $198 is a strong contender in this price range.
http://www.parts-express.com/dayton-...oofer--300-634
sk373 is online now
post #3167 of 3578 Old 05-06-2015, 07:16 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
I've actually made several inquires, to both the company themselves and their PR firm, but no one has ever replied. I don't mind if someone says "thanks, but no thanks", but I consider it unprofessional to simply ignore me altogether.
Sadly, they aren't alone. I could tell you stories like that about quite a few companies I'm afraid, along with many more were I got lead around by some knucklehead for months on end only to have the arrangements fall through or the communications simply stop for no reason. Apparently my time means nothing to some folks. Bet you would recognize a bunch of the company names too.
post #3168 of 3578 Old 05-07-2015, 12:31 PM
drm870's Avatar
Jim, I noticed you have a review of the NXG up at HomeTheaterShack, but no such review for the BIC F12. Could you elaborate on how they stack up to one another?
drm870 is offline
post #3169 of 3578 Old 05-07-2015, 03:03 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
Given the fact that I haven't heard the F12 I can't really comment on it from personal experience. I did review it's 'older brother' though, the H100, but I suspect it's targeted at a different audience. But perhaps you can cull something of value from that review.
For sure, BIC is overdue for some new products. If something comes along I'll definitely reach out to my contact and see about securing an eval unit. They've proven to be quite accommodating in the past, so I don't suspect it would be difficult to arrange should that come about.
post #3170 of 3578 Old 05-07-2015, 04:04 PM
Bond 007's Avatar
Liked: 2090
I've heard both.
My overall impressions are that the NXG is a better sub overall. Better output, extension and accuracy. Seems to be a bit of a problem with quality though whereas the Bic is built like a tank.
Bond 007 is offline
post #3171 of 3578 Old 05-07-2015, 04:06 PM
Bond 007's Avatar
Liked: 2090
Bic recently came out with an update to their speakers (at least their towers) so you'd think a new sub would be soon. But who knows.
If they do I hope you can get your hands on it.
Bond 007 is offline
post #3172 of 3578 Old 05-07-2015, 04:19 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
Which model was updated? Just curious because their website shows pretty much the same thing I've seen for years. That's actually why I think they're (over)due for an update; ID companies can't sit still that long and expect to survive.
post #3173 of 3578 Old 05-07-2015, 08:02 PM
Bond 007's Avatar
Liked: 2090
Don't know why they're not showing on the website but these recently replaced the PL-89ii.
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=6331&sc=32
Bond 007 is offline
post #3174 of 3578 Old 05-08-2015, 04:27 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
They added the new Acoustech Platinum PL-980 towers, but that is the only new model so far. Maybe they are gauging interest before releasing the rest of the speakers, I hope they do however and include a refreshed PL-280 as well.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3175 of 3578 Old 05-08-2015, 05:26 AM - Thread Starter
JimWilson's Avatar
Liked: 2039
Yea, those are new. Nice catch.
post #3176 of 3578 Old 05-11-2015, 06:59 PM
Cucuy's Avatar
Quoted: 18 Post(s)
Thank you for the recommendations and helping me narrow it down to a few choices. I am leaning towards the BIC F12 mainly because of warranty and it's carried by Amazon. Do these things fail much?
Cucuy is offline
post #3177 of 3578 Old 05-11-2015, 08:36 PM
Bond 007's Avatar
Liked: 2090
Not from what I've heard. Read the Amazon reviews. There's also a Bic F12 thread here at AVS.
Bond 007 is offline
post #3178 of 3578 Old 05-12-2015, 04:19 AM
Liked: 1394
The F-12 is pretty solid and has been one of the best selling budget subs ever. I've got one and for home theater it offers some good boom in a small to medium sized room. It isn't the greatest for music, but just about everything in this price range is going to fall short there.
post #3179 of 3578 Old 05-12-2015, 10:01 AM
humbland's Avatar
Quoted: 443 Post(s)
Liked: 93
For $50 more. I would check out the H-100
http://www.amazon.com/Acoustech-H-10...&keywords=H100
Jim reviewed it very well. http://www.hometheatershack.com/foru...er-review.html
Amazon reviews are 5 stars across the board.
Full Disclosure: We have one and it is amazing for the $...
humbland is offline
post #3180 of 3578 Old 05-29-2015, 06:34 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Monoprice 10" pro studio subwoofer on sale for $143: http://www.monoprice.com/Product?c_i...seq=1&format=2
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
