Budget subwoofers discussions, opinions and questions thread - Page 110 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
Old 01-31-2016, 01:38 AM
Quoted: 114 Post(s)
Originally Posted by Bond 007 View Post
Not really. Order one today.
It will be worth the wait.
Thanks a lot
Living Room: Marantz AV7702, (1)Crown XLS1500 & (5)Crown XLS1000. Mains-Monitor 75T, Center-CS2, Surrounds-(4)TSx110B, Ceilings-(4)620-RT, BIC F12. Projector-Benq HT1075, Elite Screen 106",Bluray-LG BP550 & LG BP440, Amazon Fire TV, DSTV HD PVR, Wii U.
Bedroom:Marantz SR5009, Mains-Klipsch R-14M Monitor, Sub-Monoprice 8", TV-LG55LB7200, Bluray-iVid BD780, WDTV, Sennheiser RS170, DSTV HD, QNAP TS-269-Pro.
Lounge: TV-VIZIO E500i-B1, Soundbar-LG NB3530, Wii.
shyyour is offline
Old 01-31-2016, 03:41 AM
Quoted: 114 Post(s)
Originally Posted by JimWilson View Post
The SB-1000 is not the solution to your problem. It's a great subwoofer, but it isn't the the unit one thinks of when they say "vibrating and chest thumping" bass. Your room is almost 3000 cubic feet so even the PB-1000, which has a lot more output, won't provide those sensations in a room that size.
The LV12R is quite possibly the best option given your circumstances. If the projections of early February availability prove true it means in a week or two. It would be far wiser in the long run to wait a short while for something that works then hastily get something now which you'll regret afterwards.
Thanks Jim this helps a lot. I was previously thinking of getting an open box PB-1000 @$449.99 but based on what you just wrote. I'll rather just wait and get the LV12R.
I have a follow up question. Can I pair the LV12R with the Bic F-12 pending when I get funds to get another LV12R or will that make matters worse?
shyyour is offline
Old 01-31-2016, 04:12 AM
Bond 007's Avatar
Quoted: 1280 Post(s)
Liked: 1336
I actually tried that when I owned both. The F12 just muddied the clean sound of the LV.
Bond 007 is online now
Old 01-31-2016, 04:30 AM
Quoted: 114 Post(s)
Originally Posted by MIX_MASTER_ICE View Post
RBH I-12. It retails for $500, but you may be able to get a discount if you contact Brian at RBH. Brian gave me a very nice discount on mine. My room is of similar size (2700 ft^3) and the I-12 sounds very nice. It's comparable in output (slightly less) and extension to the SVS PB12-NSD in my room. The I-12 is also easily the best looking sub in this price range. Mine is glossy red burl finish, curved cabinet, curved grille and an aluminum driver. It is multi-ported (3), so you can run it in ported or sealed configurations. It's a very accurate sub with a very linear frequency response. It sounds great with everything I've thrown at it.
The Rythmik LV12R is a little more expensive ($569) than the I-12, but it's a well established, highly recommended sub in this price range. The servo amp is it's strong aspect, with many people really enjoying the musical ability of this sub. It's a very generic looking sub, with just a basic grille covering the entire front, devoid of any badges and the cone is made of treated paper. The LV12R has three extension settings, but it's noted that at it's deepest setting, the sub's extension does go to 19Hz, but "drops off a cliff" after that.
I think either of these subs would serve you well and perform well enough in your room, but after my time with the I-12, I can't imagine paying more for the LV12R. Both would be a huge step over the Bic F12. Neither of these subs are going to give you earth-shaking bass in a 3000^3 room, but if you add a second later you would be in business.
Wow you've given me something to really think about. I was dead set on the LV12R but if I can get something as good for less than $500 that also looks nice its really something to think about. I was going to hide the LV12R in the corner and eventually get another one but due to space constraints the other sub would have to be in the open and I'm definitely sure my Wife won't have approved.
Have you paired the LV12R with the I-12? I know it won't be as good as two LV12R's but would it be far off.
Thanks again for your input.
shyyour is offline
Old 01-31-2016, 04:40 AM
Quoted: 114 Post(s)
Ah I see, I was worried about that. What are your thoughts on the I-12. I haven't found a lot of reviews on it?
shyyour is offline
Old 01-31-2016, 05:52 AM
Bond 007's Avatar
Liked: 1336
I dont know anything about it. It seems to be a fairly new little talked about sub.
If it wasnt for Mix suggesting it lately I would never have heard of it.
Old 01-31-2016, 05:58 AM
Bond 007's Avatar
Liked: 1336
I wouldnt mix them. If ultimately wife approval is the decision maker get 2 I-12.
Old 01-31-2016, 08:56 AM
Quoted: 114 Post(s)
Thanks Again
shyyour is offline
Old 01-31-2016, 10:33 AM - Thread Starter
JimWilson's Avatar
Quoted: 799 Post(s)
Liked: 956
The I-12 certainly looks nicer, but whether it's the equal of the LV12R - performance wise - has yet to be determined. There's always a trade off, and for the lower cost and better looks of the RBH you lose some in the lower bass range vis-a-vis the Rythmik. Not sure about sound quality as I've never heard an I-12, but it's unlikely to provide more than the LV12R. Like all such decisions, it comes down to your priorities and situation.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is online now
Old 01-31-2016, 10:52 AM
Quoted: 114 Post(s)
Thanks a lot Jim i have a better understanding of both subwoofers now.
shyyour is offline
