Budget subwoofers discussions, opinions and questions thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 97Likes
post #3481 of 3501 Unread 11-06-2016, 06:23 PM
Liked: 0
Originally Posted by MIX_MASTER_ICE View Post
Absolutely agree with Jim. Wouldn't recommend a sub placed inside a cabinet for multiple reasons. Do a sub crawl to find the best one or two locations and do what you can to rearrange the layout of the room to place the sub there. Otherwise a sub in a poor location will sound mediocre or even lousy.
I'm sure you are all correct. But...this is not my ballgame. Just doing some legwork on subwoofers for a friends HT. I will however pass along this info and recommend something else. He did tell me that the front of the cabinet will be material much like a regular flr standing speaker grill. So...if you take off the the grill on the sub...wouldn't you essentially have a similar effect? One could also have a small fan installed to cool down the unit. Just thinkin. It may or may not work. I do know that space is at a premium. There may be no other option (place) for the sub to go. Thanks to all for their good comments. As this is a work in progress...I will insure my friend does the right thing. JC
Moseboy is offline
post #3482 of 3501 Unread 11-06-2016, 06:33 PM
MIX_MASTER_ICE's Avatar
Quoted: 1098 Post(s)
Liked: 858
Short answer.....no.
MIX_MASTER_ICE is online now
post #3483 of 3501 Unread 11-06-2016, 09:45 PM
KenM10759's Avatar
Quoted: 983 Post(s)
Liked: 548
Not a great place for a sub. Let's not forget that the long wavelength of bass wraps around the front baffle of their cabinets and that's why some of the smoothest ones have minimal real estate there. You friend's subwoofer could potentially emit a much more localized bass response being inside a cabinet.
Is the cabinet near the front where the main left & right speakers are located? That's not always the best location for a sub, just the most commonly seen one. Often times it'll perform better along a side wall or in a corner you wouldn't expect it to do well. Do the "sub crawl" with it before committing.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Sumiko Pearl, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #3484 of 3501 Unread 11-20-2016, 07:13 AM
PTMD's Avatar
Quoted: 54 Post(s)
is it possible for someone to put together the top 10 - i am not sure i can read through 3500 posts before black friday and decide which one to buy
i need a new sub to replace my family room one... it was a def. tech prosub1000
PTMD is offline
post #3485 of 3501 Unread 11-20-2016, 08:03 AM
cel4145's Avatar
Quoted: 2418 Post(s)
Liked: 2805
What is your budget?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3486 of 3501 Unread 11-20-2016, 08:21 AM
PTMD's Avatar
Quoted: 54 Post(s)
being in canada under $400 - which probably equates to under U$320
the bic F12 comes up a lot - thats about $290+tax (13%) here
PTMD is offline
post #3487 of 3501 Unread 11-20-2016, 08:32 AM
cel4145's Avatar
Liked: 2805
Watch to see if the BIC PL-200 goes on sale. It's currently a little over your budget on Amazon.ca.
post #3488 of 3501 Unread 11-20-2016, 08:43 AM
KenM10759's Avatar
Quoted: 983 Post(s)
Liked: 548
I have one in my secondary system. It's not bad at all, just not going to fill a large room without working really hard. The 150w amp is no powerhouse. If you have a smaller room, say under 15' square with a normal ceiling height, no problem, otherwise look around for more power.
post #3489 of 3501 Unread 11-20-2016, 09:59 AM - Thread Starter
JimWilson's Avatar
Quoted: 1177 Post(s)
Liked: 1413
A list like that is almost entirely subjective, so the one you might get from me will most likely differ from what the next person provides. Even if our lists included the exact same 10 subwoofers they would probably be in a different order, relative to our own individual preferences, so it might cause more confusion then it resolves.
You didn't really provide much for people to go on though, so if anyone wanted to suggestion something specific instead it might not prove to be appropriate for the task at hand. You should take a look at this sticky thread to get an idea of what type of info is most helpful.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3490 of 3501 Unread 11-20-2016, 04:58 PM
PTMD's Avatar
Quoted: 54 Post(s)
Let me try again. I would like a recommendation for a subwoofer that fits these criteria
Budget - under C$400 - prefer best bang for the buck, so if a $350 sub is better than a $300 or $400 sub, i would get the $350 sub (and not marginally better)
Size - open to up to 12's - if i can hit lower and clean - i would be happy
Room size - 12.5 x 16.5'x 9' (height) - three walls, one side open to kitchen - end of kitchen is 19ft away
Listen to - TV/movies
time - doesnt matter
placement - I'll likely place on the back wall - about 3 feet away from the corner, If i put it in one corner, it will be behind my receiver table, where my house plant is (wife wont let me move it). If i put in the other corner, it will be in between the sofa and loveseat and will likely need a wireless transmitter. If i put it on the otherside, then that area is open to the kitchen
Note: this will be going into my family room for normal listen experiences. I have a basement, where i am putting in larger speakers and 2 subs for awesome movies, sporting events and just enjoying over the weekend
I have currently have in my family room, 4x Def Tech. Pro 800 and a Def. Tech Pro cinema 2000 (center) connected to a Denon 2113CI. My def tech Pro 800 sub is dying and making lots of scratching noises, so it needs to be replaced
PTMD is offline
post #3491 of 3501 Unread 11-20-2016, 05:00 PM
PTMD's Avatar
Quoted: 54 Post(s)
placement - I'll likely place on the back wall - about 3 feet away from the corner, If i put it in one corner, it will be behind my receiver table, where my house plant is (wife wont let me move it), i can put it closer, but there are limits. If i put in the other corner, it will be in between the sofa and loveseat and will likely need a wireless transmitter. If i put it on the otherside, then that area is open to the kitchen
I have currently have in my family room, 4x Def Tech. Pro 800 and a Def. Tech Pro cinema 2000 (center) connected to a Denon 2113CI. My def tech Pro 800 sub is dying and making lots of scratching noises, so it needs to be replaced. so anything as good as this expiring sub or better
PTMD is offline
post #3492 of 3501 Unread 11-20-2016, 05:13 PM
cel4145's Avatar
Liked: 2805
Best Buy is running a special on Klipsch, and apparently the R-12SW will be half off. Check their flyers.
post #3493 of 3501 Unread 11-20-2016, 05:25 PM - Thread Starter
JimWilson's Avatar
Liked: 1413
If DIY is an option, what about something like this subwoofer kit and this amplifier?
post #3494 of 3501 Unread 11-20-2016, 07:12 PM
PTMD's Avatar
Quoted: 54 Post(s)
diy is out... too expensive in canada, especially for since its not my main a/v room
looking for retail/online versions...
PTMD is offline
post #3495 of 3501 Unread 11-21-2016, 06:55 AM
PTMD's Avatar
Quoted: 54 Post(s)
how good is the R-12S?
PTMD is offline
post #3496 of 3501 Unread 11-21-2016, 07:14 AM
kgallerie's Avatar
Quoted: 59 Post(s)
Liked: 85
At this price, this sub would work well for you.
http://www.ebay.com/itm/Jamo-J-112-D...8AAOSw4shYB5mk
But like the others said, the BIC PL-200 would also be good choice for your criteria.
Personally I dont have any experience with either of these, but they are normally highly recommended around here.
kgallerie is offline
post #3497 of 3501 Unread 11-22-2016, 09:44 AM
draco159's Avatar
For a 10-12" for 100% music only in a 2.1 desk setup, could I do any better than the white Jamo J12 (not J112) 12" for $179 at Newegg? I'm not picky on color and my bookshelves are the Elac B5. Room is 13x11x8.
draco159 is offline
post #3498 of 3501 Unread Yesterday, 09:35 AM
Quoted: 171 Post(s)
Liked: 26
First off, let me say a big Thank You to @Jim & @Mix _Ice for recommending and giving me advice on the RBH I-12. Its exactly what i was looking for. It has the bass thumping chest as well as the low extension (no more port noises).
However i would like to get another sub but i dont want something as larges as the I-12. I currently have the RBH I-12 paired with the Bic F-12 and im looking for a similar sub in performance to the RBH but in the size print of the Bic F-12.
Been looking at the RSl 10s would it give a similar performance to the I-12 ?
Thanks again for all the advice and help
Living Room: Pre-Pro- Marantz AV7702, Amps- Crown X1500 & XLS1000(5). Mains- RTi12, Center- CSi5, SR- RTi8, SRB-75T, Atmos- 620RT(4), Sub- BIC F12, TV-LG55LB7200, PJ-Benq HT1075, Screen 106", UBD-K8500, Bluray-LGBP540 & BP440, Misc- Fire TV, DSTV HD PVR, Wii U, DVP-5000s.
Bedroom:AVR- Marantz SR5009, Mains-TSx110B, TV-VIZIO E500i-B1, Bluray-iVid BD780, Misc- WDTV, Sennheiser RS170, DSTV HD, QNAP TS-451+.
shyyour is online now
post #3499 of 3501 Unread Yesterday, 10:16 AM
Liked: 858
The Speedwoofer 10S looks like a good little sub, but you couldn't expect it to compete with the much larger 12" I-12. Ported subs are usually quite a bit larger than sealed, so the 10S being on the smaller size is one of it's advantages, at least for someone looking for a smaller sized subs. You could always try the 10S for yourself, since RSL has free return shipping if it doesn't work out.
post #3500 of 3501 Unread Yesterday, 01:11 PM
Quoted: 171 Post(s)
Liked: 26
Thanks Unfortunately i dont live in the states so i cant try it out. I guess ill either have to find a space for it or make do with what i currently have. Thanks again.
post #3501 of 3501 Unread Today, 07:36 PM
cel4145's Avatar
Liked: 2805
I'd be very tempted to order the new Emotiva S12: http://emotiva.com/products/subwoofers/basx-s12. Looks like it fits your size requirements.
