Budget subwoofers discussions, opinions and questions thread - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 112Likes
post #3511 of 3539 Old 12-22-2016, 05:53 AM
Raylon's Avatar
Quoted: 220 Post(s)
Liked: 173
Looking to pressurize a 1200^3 ft room for cheap. I am looking at 2 Dayton SUB-1500 for $350. Any better suggestions for that much money?
Raylon is online now
post #3512 of 3539 Old 12-24-2016, 07:30 PM
Quoted: 21 Post(s)
Hey all.
So I have a ZVOX 670 soundbase and a Vizio P50, and looking to get a decent sub for under $200.
I am completely clueless in audio related things, but the ZVOX has a sub output on the back. Is this the only way I'd be able to connect a sub? Or could I have two RCA cables from the sub to a single cable going to my ZVOX?
If the connection isn't an issue, what would you recommend? My room is a mere 12' x 14', so I do not need something super crazy. My primary focus is movies, but also a good amount of shows. Music is a very low priority.
Let me know if I left anything out, and have a good Christmas.
FirelanceRZ is online now
post #3513 of 3539 Old 12-25-2016, 04:48 AM
Raylon's Avatar
Quoted: 220 Post(s)
Liked: 173
Originally Posted by FirelanceRZ View Post
Hey all.
What is your budget? All new subs connect using a single digital coax so your connections are good.
post #3514 of 3539 Old 12-25-2016, 05:36 AM
Quoted: 21 Post(s)
I'd prefer under $200, but maybe $250 could be my max. I won't buy it anytime soon now, but I like to do my research beforehand.
post #3515 of 3539 Old 12-25-2016, 05:45 AM
Raylon's Avatar
Quoted: 220 Post(s)
Liked: 173
There are a few options at that price. I just bought two of these for my bedroom:
http://www.parts-express.com/dayton-...oofer--300-634
I will be getting them Tuesday so I will have a better impression then, but for the money, I think they will be hard to beat.
cel4145 and FirelanceRZ like this.
post #3516 of 3539 Old 12-25-2016, 07:22 AM
Quoted: 21 Post(s)
Great, I was looking at the 12" variant. I've heard good things. I'll see how much room I actually have and pull the trigger. Thank you.
post #3517 of 3539 Old 01-23-2017, 03:04 PM
Quoted: 50 Post(s)
Liked: 9
It's soon to be upgrade time! I have a crappy PSW10, it's get surprisingly low but it's fairly sloppy and doesn't handle transients very well. 90% of the time the sub will be used for movies and gaming, but I won't rule out music. We're not critical listeners, but I like good, clean, tight BASS!!!! The room is about 1800 cubit feet 15' wide, 17' long and has a trapezoidal ceiling the raises from 5' to 9' with an 8' section in the middle that's flat. Looking around the BIC F12 gets lots of love from the budget minded folks, and it's available on Amazon for $209 The Bic Eviction series is available for about the same price. I'd like to 2 if one... is good, 2 must be better, right? The question now becomes is 2 BIC's going to be as good as 1 $400 sub? If I were to go with the BIC is the Eviction any better then the F12? It seems to have similar specs other then the red cone. I'm also fine with the DIY approach. I'd like to stay in the $400-$500 range at most.
reburg99 is offline
post #3518 of 3539 Old 01-23-2017, 04:39 PM
MIX_MASTER_ICE's Avatar
Quoted: 1233 Post(s)
Liked: 1024
Check out the DIY board for advice on that option. $500 can go a long way with DIY. If you are willing to spend up to $500, definitely get a good ID sub over two budget subs. The RBH I-12 and SVS PB-1000 are both $500 and for your room would do well. I have multiple RBH and SVS subs and would go with the RBH I-12.
MIX_MASTER_ICE is online now
post #3519 of 3539 Old 01-24-2017, 01:28 AM
Quoted: 208 Post(s)
Liked: 36
+1 on the RBH, @MIX_MASTER_ICE suggested it and im still grateful. That sub rocks, literally my couch vibrates and it goes low. Note its quite big so hope you have the space for it.
Living Room: Pre-Pro- Marantz AV7702, Amps- Crown X1500 & XLS1000(5). Mains- RTi12, Center- CSi5, SR- RTiA1, SRB-RTi8, Atmos- 620RT(4), Sub- RBH I-12 & BIC F12, TV-LG55LB7200, PJ-Benq HT1075, Screen 106", UBD- Samsung K8500, Bluray-LGBP440, Misc- Nvidia Shield, Apple TV, Chromecast, DSTV HD PVR, Wii U, DVP-5000s.
Bedroom:AVR- Marantz SR5009, Mains-75T, TV-VIZIO E500i-B1, Bluray-iVid BD780, Misc- Fire TV, Chromecast Audio, Sennheiser RS170, DSTV HD, QNAP TS-451+.
shyyour is offline
post #3520 of 3539 Old 01-24-2017, 07:18 AM
Quoted: 50 Post(s)
Liked: 9
Man, that's one good looking sub. However it's not going to match anything I've got.... does it come in a satin or flat? All I saw was gloss.
How will 1 sub vrs 2 cover? I know sub frequencies are omni directional, but was looking at trying to get the most even coverage at the various listening positions. And of course, couch shaking is always a plus, bass should be felt as much as it's heard!
reburg99 is offline
post #3521 of 3539 Old 01-25-2017, 12:49 AM
Quoted: 208 Post(s)
Liked: 36
Yep its one of the finest subs ive seen. i think it comes in just gloss (black or red burl).
Mix will have to answer that, he has 4, i just have the 1, but two subs should smoothen out the bass.
shyyour is offline
post #3522 of 3539 Old 01-25-2017, 07:46 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2994
Dual subs, when well placed, can typically provide a smoother frequency response through a wider seating area.
ChromeJob likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3523 of 3539 Old 02-02-2017, 11:21 AM
Liked: 3
Hey Everyone,
I'm in the field for a sub at $200 or less ( a few bucks over is fine). So far from what I've looked at, the Bic F12 sounds like my best bet, but I've heard that they aren't great for music, which is what my system would be used for 50% of the time. Is there anything that sounds better at the price point? Not looking into the DIY approach. Live in an apartment, living room roughly only 11' X 12' . Don't worry about loudness being an issue because neighbors blast their stuff much more than I would consider appropriate on weekends. Building is full of other college students. As far as bass preference, I do enjoy that rumbly bass you can feel and just encapsulates the room. Carpet flooring and standard sheet rock style walls.
Thanks in advance!
BadLuckBryce is offline
post #3524 of 3539 Old 02-02-2017, 11:28 AM
Quoted: 562 Post(s)
Liked: 231
amazon has the sub12hg for $250 with free prime shipping
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #3525 of 3539 Old 02-02-2017, 11:38 AM
clarkkent06's Avatar
Quoted: 48 Post(s)
Liked: 35
Originally Posted by BadLuckBryce View Post
Hey Everyone,
Thanks in advance!
If the deal comes back again, Fry's had the Klipsch R-112SW for $220 in December. In the ~$200 range it can't be beat
However, that's if the deal ever comes back. Depends on if you can wait and take the chance or if you want something now
clarkkent06 is offline
post #3526 of 3539 Old 02-02-2017, 11:42 AM
Quoted: 562 Post(s)
Liked: 231
whats the performance diff between the 112sw and the 12hg?
service - directv
(slow build out)
mdram is offline
post #3527 of 3539 Old 02-02-2017, 11:49 AM
Quoted: 48 Post(s)
Liked: 35
I've had both (have the 112sw currently) and although the specs show both at 24hz, the 112sw sounds better down low and also more punchy/tighter.
Also, the amp if I recall is a class D, which is better than the hybrid bash amp in the sub-12. Also, the R-112sw adds the option to go wireless with an add-on kit. And, it matches my klipsch reference speakers in color lol
Klipsch spec sheets here:
http://images.klipsch.com/Sub12sheet...9669090000.pdf
http://images.klipsch.com/R-112SW_-_...7732240000.pdf
post #3528 of 3539 Old 02-02-2017, 11:54 AM
Quoted: 562 Post(s)
Liked: 231
thanks! wonder how one would blend with my sub12 if i ever added it
service - directv
(slow build out)
mdram is offline
post #3529 of 3539 Old 02-03-2017, 10:47 AM
ousooner2's Avatar
Quoted: 272 Post(s)
Liked: 162
Reburg99... you want a musical sub that can hit as lower than the psw10, while being budget friendly. RBH has been mentioned already and I second that. Someone in the EMP/RBH thread compared his svs pc12+ to the e1010i dual 10" sub and said they sounded VERY similar. The sound quality was pretty much identical, but the svs hit lower. In my room its around 26-27hz before they fall off, but it's pretty large and it's not in a corner. Also, they look incredible! The i-12 looks to hit a little lower, but takes up more depth and is around $500. The PB-1000 at that price is a known solid sub too.
*cough* FS: EMP/RBH e1010i Subwoofer (Dual 10" Sub) *cough*
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #3530 of 3539 Old 02-03-2017, 11:31 AM
Quoted: 50 Post(s)
Liked: 9
If things work out, I'm going to try to get CrazyCramers ultimax 15 and iNuke. If not maybe a e1010 in my future?...
reburg99 is offline
post #3531 of 3539 Old 02-22-2017, 07:44 AM
oldnavycdr's Avatar
Quoted: 14 Post(s)
12HG vs. SW 450? Thoughts? 80% HT/TV.
oldnavycdr is offline
post #3532 of 3539 Old 03-02-2017, 06:34 AM
layzzzee8's Avatar
Quoted: 578 Post(s)
Liked: 703
I currently have a BIC-F12 that I have been relatively happy with as it was a big upgrade for me when I purchased it. Lately though it seems to be lacking in the low end so I am looking to add another sub to my Denon X3300. My room isn't very large. Its about 11x17x7.5. Would I be better off getting another BIC-F12 or something else? I am trying to keep the price below $300.
Edit: Just want to add that its main use is movie watching. I rarely use the room for music.
layzzzee8 is offline
post #3533 of 3539 Old 03-02-2017, 02:31 PM
Liked: 1024
Your room is only 1400 ft^3, which is pretty small. If you are wanting more extension, a second F12 won't help you with that. To get more extension, $300 budget really won't be enough. I would sell the F12 and use that money to get a quality sub. A SVS PB-1000 would be a good fit for your small room and will give you extension that no budget sub can deliver. Bad part of that is the price tag of $500. They are often in the SVS outlet for $450-$475, however.
A second option that would work for your small room is the SVS SB12-NSD. It's currently available for $359, which is closer to your budget. This is a sealed sub and in your small room it should perform well with good room gain. Use ebay code CGAMETECH10 to get 10% off through Mar. 6th and this makes the SB12-NSD $359.10. http://www.ebay.com/itm/SVS-SB12-NSD...sAAOSw8w1YAQ2A
If it were me in your situation, I would sell the F12 for around $100-$125, depending on age, then use that money to buy the SB12-NSD for $359. I had a SB12-NSD previously and it's a great little sub.
Game Room>Vivitek 1080p projector w/100" screen/ Hisense 65" 4K w/HDR10, Onkyo TX-NR656 receiver, Klipsch KF-28 L/R, KC-25 center, KB-15 sides, Loft 40 rears, RBH I-12/e (x2), I-12 (x2) subs. Living Room>Samsung 59" Plasma, Onkyo HT-RC560 receiver, Primus P363 L/R, P163 center, Polk RC60i in-wall rears, SVS PB12-NSD (x2) subs. PC set up> Pioneer VSX-524, Pioneer BS22, SVS PC12-NSD (x2) subs. Game Systems> PS4 Slim, PS4, PS3, XBox One S, XBox One, XBox 360, Wii.
post #3534 of 3539 Old 03-02-2017, 03:08 PM
Quoted: 17 Post(s)
This is incorrect. Very few subs exist that can accept a digital coaxial input (I have seen a couple but it is not common), and no A/V receiver I am aware of has a 'digital' subwoofer output (maybe a couple high end preamp/processors exist that can provide a digital subwoofer output. The single RCA signal output from an A/V receiver's subwoofer output is an analog unbalanced audio signal - only a single connector is used because the subwoofer channel in most surround formats is encoded as a single channel of audio.
The majority of subwoofers being sold today have two RCA inputs on the rear panel, which enables a stereo signal to be provided to the plate amplifier. Then the circuitry in the subwoofer's amplifier sums the signal before amplifying it.
Best regards,
Rory Buszka
Emotiva Engineering
Rory@Emotiva is offline
post #3535 of 3539 Old 03-02-2017, 03:20 PM
Raylon's Avatar
Quoted: 220 Post(s)
Liked: 173
Best regards,
Rory Buszka
Emotiva Engineering
I was referring to the cable, not the connection type. If you go to Amazon and type in subwoofer cable, all that pops up is 'digital audio coaxial cable's for sale. I said it just because that's how they are sold as to not confuse any newer people.
post #3536 of 3539 Old 03-03-2017, 08:53 AM
Quoted: 562 Post(s)
Liked: 231
i would go 12hg
service - directv
(slow build out)
mdram is offline
post #3537 of 3539 Old 03-06-2017, 06:18 PM
layzzzee8's Avatar
Quoted: 578 Post(s)
Liked: 703
Thanks. After some research I decided to pick up the pb-1000 using the same code bringing it to $450 shipped. I'll relegate the f12 to the basement. It comes tomorrow, very excited as the reviews are nothing but positive.
MIX_MASTER_ICE likes this.
post #3538 of 3539 Old 03-08-2017, 12:12 AM
smw6230's Avatar
FWIW, the HSU (B stock) clearance page has one VTF-1 mk3 for $337.00. $400 total (shipping) is IMO a nice deal for someone looking to upgrade from a budget sub.
smw6230 is offline
post #3539 of 3539 Old Today, 12:19 PM
Liked: 1024
The Klipsch sub-12hg is available now for $199.99. Been quite a while since this one has been below 200 bones. http://www.ebay.com/itm/311763065127...887&rmvSB=true
