Budget subwoofers discussions, opinions and questions thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 111Likes
post #901 of 3530 Old 01-24-2013, 04:47 PM
DGCanuck's Avatar
I am looking at the HSU STF-2, 2 of the SVS cube subs and the PL-200. I nearly went with the PL-200 but if I add 6" to the depth of the box for the rear port, it's a no go. Box size is a real issue for me so I am attracted to sealed and front ported subs. The SVS PL-1000 seems a great compromise.
But I would appreciate some feedback on the HSU STF-2 as an alternative. I am not sure if the 2 ports with plugs is gimmiky or the real deal.
DGCanuck is offline
post #902 of 3530 Old 01-24-2013, 06:23 PM
tiguej's Avatar
Jim and Bond 007,
Thanks for the replies.
Someone recommended I look at the SVS Dual PB-1000. With your extensive sub knowledge which would you choose?
JT.
tiguej is offline
post #903 of 3530 Old 01-24-2013, 07:41 PM
Splicer010's Avatar
Liked: 39
You should go for a bottom ported. Take a rear port sub, block the port(s) and VOILA!!! A sealed sub. cool.gif
Splicer010 is offline
post #904 of 3530 Old 01-24-2013, 07:49 PM
Splicer010's Avatar
Liked: 39
Originally Posted by tiguej View Post
Jim and Bond 007,
JT.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-766 cool.gifbiggrin.gif
post #905 of 3530 Old 01-24-2013, 08:02 PM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1911
Jim and Bond 007,
JT.
I really don't know your situation and Jim is the only one here with extensive sub knowledge. The pb1000 is a nice sub from what people say. If you post (or repost) your room size, budget and so forth it would be helpful.
Licence to Kill
Bond 007 is offline
post #906 of 3530 Old 01-24-2013, 08:08 PM
Bond 007's Avatar
Liked: 1911
My prediction is that you will die of old age before you purchase a sub. wink.gif The stf2 does not have 2 ports or plugs. Perhaps you should rethink things.
Licence to Kill
Bond 007 is offline
post #907 of 3530 Old 01-24-2013, 08:26 PM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
Originally Posted by edlittle View Post
If that is the case, and I would like to reach as low as possible, should I get: BIC PL-200, Klipsch RW-12D, HSU STF-2, or something else? Thanks for the help?
The BIC PL-200 peaks at in output at about 50hz and is already almost 15db down by 25hz. So depending on your room and whether or not you have sub EQ, it may or may not be possible to get usable <30hz response. The Klipsch has been show to have a much flatter response, and you could almost count on getting good <30hz response out of it.
And of course the RW-12D will have more output than the STF-2, which as a 10" sub, might be a little challenged give that your room opens up to another room of about equal size.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #908 of 3530 Old 01-24-2013, 08:28 PM - Thread Starter
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1573
Depending upon what your placement options are I think that could work very well. The PB1000 is a pretty nice sub, especially for the price. Had I known your budget was going to balloon to a grand I would have suggested that days ago, saving you a lot of aggravation. tongue.gif
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #909 of 3530 Old 01-24-2013, 09:29 PM
DGCanuck's Avatar
Bond007
My prediction is that you will die of old age before you purchase a sub. The stf2 does not have 2 ports or plugs. Perhaps you should rethink things.
Good catch, you are right on that score sir. I think I might have been thinking the HSU-VTF 2 and it looks like it is rear ported. I guess my question about port plugs stands. What exactly would they do?
I am too close to 65 with various bits of surgically implanted metal and some unplanned shrapnel in my body. I played football and hockey, raced cars and bikes and still ride so if I kicked it tomorrow it would probably be from mileage not old age or sub chasing!!!. My speed is saved for 2 wheels.
Actually, the fronts and center came yesterday and rear surround ceiling speakers will be installed next Wednesday. I needed the renovation plans to figure out what space would be left over for the sub.
The old Polk Audio PSW10 will have to pitch hit until then. At 14"x14" it at least fits and I know where the new one will go.
DGCanuck is offline
post #910 of 3530 Old 01-24-2013, 11:51 PM
AVSearcher's Avatar
lol Beeman.
Originally Posted by JimWilson View Post
Some indication of your room size and budget are necessary in order for anyone to assist, otherwise you're going to get suggestions that won't work for your specific situation. Size restrictions, if any, are good to know as well.
I am not sure of the size of the ceilings, just that the living room ceiling starts at a standard height you see in most apartments (whatever that is) and then slants upwards, getting higher until about 10' at the other end. The rest of the living space is of standard ceiling height. The living room is about 12 x 13, but the total combined space of the kitchen, dining room, living room, and hallways (only partial / non-fully-enclosed walls separating the back side of the living room from the hallways...and only half-way-up counters separating kitchen from dining room, and the dining room is essentially part of one big room with the living room) is probably at least 3 times that size.
Honestly, I was hoping that, if I would benefit from a sub at all, the other criteria I set would already put a strong limitation on what I needed (not disturbing the neighbors next door on the same floor and downstairs, not needing/wanting *loud* bass, not needing its benefit-area to cover any more space than the living room itself). As for budget, I was hoping to get some recommendations on what would be the "best bang for the buck" according to my criteria, and also not going completely overkill based on the budget speakers I currently have (would seem kind of silly to get a REALLY good sub that cannot really do justice to the sound with my current speakers, unless the lower recommended subs are not that much more cheaper). It would be nice to get a recommendation on the minimum recommended (recommended, not downright minimum that you don't really recommend...would be better to just save money to get a decent one months later) for my circumstances and also one(s) you would strongly advise I consider for a longer term, though non-audiophile and still value-oriented investment, considering I will not get speakers much better than the Daytons anytime soon. Size does not matter unless it is really heavy and requires a lot of strength to move, in which case that would be a problem at the moment.
Am I still being too vague? I understand that subs are harder to recommend in a generalizing manner than speakers.
AVSearcher is offline
post #911 of 3530 Old 01-25-2013, 03:28 AM
Bond 007's Avatar
Liked: 1911
Yes. You are still being too vague. But that's ok. I think I get the picture. You don't have a sub and are not real picky but want something reasonably cheap that will put out a good amount of bass and size is not an issue. With that much space you need all the output you can get. IMO These are your best options from good to better to best. 1 Bic F12 for $200. 1 Klipsch RW12-d for $300. 2 Bic F12s for $400.
Licence to Kill
Bond 007 is offline
post #912 of 3530 Old 01-25-2013, 05:14 AM
BeeMan458's Avatar
Liked: 813
In order to respond to your above, one needs to use fuzzy logic. So here it is in a nut shell or if you will, the extended play version of Bond 007's comments.
Absolutely, anybody and everybody who asks your questions is in need of a subwoofer as a subwoofer is that important in sonic reproduction due to inherent speaker limitation built into "ALL" speaker systems. A subwoofer is the "POW!" in someones laundry detergent and we all need "POW!" in our lives.
With that in mind, the best bang for the buck is going be either a Klipsch, RW-12d or a BIC, PL-200. In the budget minded category, these are the top dogs and many years down the road, will give you the most bang for the buck. But, and it's a big but, to get the most out of the deal, one needs two of these subwoofers and the reason why is, sound waves as they bounce around in a room, like to argue with each other and cancel each other out in the process. This cancelling needs to be countered or you'll get a drop off (bad sound quality) in the frequencies they're arguing in. Not good. The short version, two subs is better than one, four subs is better than two or three subs. So my minimum recommendation would be a pair of either of the two recommended subs.
The next step of the edification process will be getting the most out of these subwoofers once you have them in the room as they're not simply place and forget in order to bring the best out in them. There a bag load of who-ha surrounding getting the most out of subwoofers, too much to address in a missive of this kind.
First things first. Yes you need the subs if you want your speakers to blossom. These are the best bang for the buck as anything less, and you're short-shriftting yourself. And no, at this level, even though these are budget minded sub recommendations, you won't have to worry about replacing them a month or two down the road or even a year or five years down the road. These subs won't need to be replaced until either you decide you want better like one decides they want a faster car or that fail and are in need of replacement as even a fast car gets old and becomes in need or repair or replacement. These should be light enough to move around but there's always the possibility that you'll need assistance because to a certain extent, "ALL" subs are awkward and "HEAVY.'
All of the above takes into consideration room size, variables and budgets, full well knowing that in those departments, I'm completely without a clue. tongue.gif
Hope the above is the type of response you're in need of.
BeeMan458 is offline
post #913 of 3530 Old 01-26-2013, 08:01 AM
tiguej's Avatar
Bond 007,
Here are my room dimensions. MY original budget was 300-400 per sub. I'm willing to go to 500 per sub if they are worth it compared to the 300-400 subs.
JT
Basement Dimensions.docx 26k .docx file
tiguej is offline
post #914 of 3530 Old 01-26-2013, 02:36 PM
cel4145's Avatar
Liked: 2991
For anyone looking for a 10" sub for under $200, the JBL Studio 1 Series SUB150P could be worth a good look at $175. Got a good review and the measurements look decent.
cel4145 is offline
post #915 of 3530 Old 01-26-2013, 02:38 PM
cel4145's Avatar
Liked: 2991
Bond 007,
JT
How big are your ceilings? That room is pretty good size in sq feet. Sub performance is impacted by total room volume.
cel4145 is offline
post #916 of 3530 Old 01-26-2013, 06:10 PM
tiguej's Avatar
My ceilings are 8ft. tall.
tiguej is offline
post #917 of 3530 Old 01-26-2013, 06:16 PM
cel4145's Avatar
Liked: 2991
Then two of the SVS PB1000s you were considering should have plenty of output for your room. Of if you want to save some money, go with the Klipsch RW-12d on Newegg at $350 ea. Those would be my choices.
cel4145 is offline
post #918 of 3530 Old 01-27-2013, 05:07 PM
dangerine49's Avatar
I recently lost most of my surround sound system (along with most of the contents of my family room and a couple of cars) to Hurricane Sandy. I had a 6.1 system with Polk satellite speakers and a PSW10 subwoofer through a Sony receiver. I'm a ways away from getting the room back to where it was, but I'm thinking of a different subwoofer this time around. Three of the Polk satellites were saved, but the Sony and PSW10 were destroyed. It's a large L shaped family room with the main living and entertainment area of about 20 ft. X 18 ft. with 7 ft. ceilings. We had carpet before but we will be replacing it with ceramic tile. We use the room mostly for watching TV and DVD's.
Any recommendations for a new subwoofer?
10" or 12" ?
front or down firing?
BIC F12, V1220 or V1020?
Velodyne VX-11?
It's got to be budget (sub $200) because we are replacing pretty much everything.
dangerine49 is offline
post #919 of 3530 Old 01-27-2013, 05:16 PM
cel4145's Avatar
Liked: 2991
Look at the information for the JBL I just linked to a few posts back. That looks to be a very good deal for a 10" at $175.
Also, the VX-11 is available in pairs for $229. That's a little more than your budget, but that's where it's a good value is getting two at that price, not one VX-11 at $175 or so.
cel4145 is offline
post #920 of 3530 Old 01-27-2013, 07:07 PM
Anodyne's Avatar
I'm very satisfied with my Dayton SUB-1200. 12" 150 watts for $130 each. My room is probably similar in volume to yours and while it doesn't fill the space as much as I'd prefer, it is great for the money (tight budget here as well) and I'm looking forward to adding a second soon.
Anodyne is offline
post #921 of 3530 Old 01-27-2013, 09:38 PM
soundwhat's Avatar
Quoted: 17 Post(s)
Liked: 43
Ok. I want to buy the best sub for the best deal. Tomorrow.
What could I buy?
Many of the "deals" on this post are either out of stock or no longer great deals. Can someone help.
soundwhat is offline
post #922 of 3530 Old 01-27-2013, 09:53 PM
Bond 007's Avatar
Liked: 1911
What could I buy?
A price range might be helpful or I'm gonna recommend a $6000 sub that usually goes for $9000. Also, what is the size of your room?
Licence to Kill
Bond 007 is offline
post #923 of 3530 Old 01-27-2013, 10:13 PM
soundwhat's Avatar
Quoted: 17 Post(s)
Liked: 43
Haha.
The Living room is about is about 17X15 but the entire room is larger about 30X15.
I would like to be under $300 but no more than $500.
post #924 of 3530 Old 01-28-2013, 04:29 AM
Bond 007's Avatar
Liked: 1911
Haha.
With a room that big you will need 2. I would get the JBL SUB 150. See post 915.
Licence to Kill
Bond 007 is offline
post #925 of 3530 Old 01-28-2013, 06:19 AM
swim33's Avatar
Haha.
You could even go with 2 JBL ES250's if you can swing $400. They go for $199 each on amazon.
-Ben
swim33 is offline
post #926 of 3530 Old 01-28-2013, 09:14 AM
soundwhat's Avatar
Quoted: 17 Post(s)
Liked: 43
This is a town home so the living room is separated by a wall less walk way and connected to the dining rooms. Are two subs really necessary if I only want the sound and effects to make the impact in the television area? I hope this makes sense
post #927 of 3530 Old 01-28-2013, 09:26 AM
Bill Fitzmaurice's Avatar
Liked: 4648
Two subs will flatten in-room response for the best results at the lowest possible volume.
Bill Fitzmaurice is online now
post #928 of 3530 Old 01-28-2013, 11:03 AM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
well you have to balance your needs vs. the recommendations. When you ask in this thread, people are going to tell you the best route to really "pressurize" the entire space and get full bodied movie LFE action. With a space that size, it requires a significant amount of "woofage" to really fill the space properly.
If you are only listening at moderate volumes and just want a little "boom boom" in the low end then you obviously don't "need" that much. But just be aware that if you ever want to really "crank it" for the full theater experience, you may hit a wall with the subs on big modern action movie effects. If you will never really crank it, then not as much of a worry.
As pointed out many times in this thread, the benefit of two subs is more about "better" bass then it is about louder bass -- bass waves are long and bounce around the room, and cancel each other out or reinforce each other as they reflect off walls. This leads to "modal" areas where you get dips and peaks, leading to uneven response (e.g. the bass may be boomy at one end of the couch and weak at the other end). With two subs, you will get smoother response overall and fewer of these peaks/dips. So even if you aren't listening loud, dual subs can be very beneficial in making the quality of the bass more consistent over the entire listening area.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #929 of 3530 Old 01-28-2013, 12:47 PM
soundwhat's Avatar
Quoted: 17 Post(s)
Liked: 43
Ok. Well thank you very much for the input. I am going to order one and see how it performs. Then if I feel as though I want more, I will order a second shortly after.
post #930 of 3530 Old 01-28-2013, 01:01 PM
Bond 007's Avatar
Liked: 1911
Good plan. That's what I was going to suggest. Since you are going to do that I suggest a little better sub to start with. Klipsch RW12-d. It cost $299 at Newegg on sale but is better than the JBL imo and it will lessen the likelihood that you will need another because it has more output. I was going to suggest 2 of them anyway but it would put you over budget.
Now that I think about it, that's a hard one. You said you wanted something today. I'm not sure if the rw is on sale today. The jbl is. That is a really good deal on the jbl but I don't think one will do you a lot of good and by the time you figure that out you probably wont be able to get another at that price. It is important to match subs if you can.
So, after all that, my suggestion is that you get 2 of the jbl while you can because it is a great price and you are almost certainly going to be unhappy with 1.
Licence to Kill
Bond 007 is offline
