Budget subwoofers discussions, opinions and questions thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 117Likes
post #1441 of 3580 Old 05-29-2013, 09:09 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by JimWilson View Post
Disassembly is relatively easy, it's the construction part where I seem to be lacking. Perhaps someday...
Don't let anybody kid you. Woodworking is a whole new hobby, complete with a shop full of gear and all the fiscal pain and suffering that comes with stocking a worthy wood working studio. When I retired from contracting, I gave away three pickup loads of tools, materials and supplies to a business friend so I comment from experience. If one doesn't believe me or wants to argue this point, my recommendation, stop by rockler.com and check out the truth of what I'm going on about.
Only go there if willing to light the candle. I don't care what anybody says, knowing what I know about the price of a quality setup, I can buy three subs much cheaper then it will cost to buy all the tools, gear and a shed to put everything in as our garage and shed is already as full as a "rational" person will allow.
A suggestion, before anybody decides to go DIY, stop by the DIY forum and check out the progress images and what the background looks like as these inexpensive marvels are created and assembled.
BeeMan458 is offline
post #1442 of 3580 Old 05-29-2013, 09:20 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
you can buy pre-made cabs for this purpose, does that make it much easier?
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #1443 of 3580 Old 05-29-2013, 09:24 AM
Bill Fitzmaurice's Avatar
Liked: 5687
Originally Posted by Bond 007 View Post
How do you know that the company that makes your DIY amp arent lying about its specs? wink.gif
Because DIYers are the sort who have testing gear, know how to use it, and do. And they're not the least bit shy about posting the results of their tests, especially when the posted specs are spurious. I doubt one in a thousand owners of commercial subs have the gear, the ability, or the inclination, to test their amps. I doubt if one in a hundred measure their sub's frequency response. Manufacturers who fudge on specs are very aware of that.
Bill Fitzmaurice is offline
post #1444 of 3580 Old 05-29-2013, 09:34 AM
humbland's Avatar
Quoted: 457 Post(s)
Liked: 96
A question for the guys here:
I'm trying to add bass to a stereo (2 channel R/L) only set up using small Boston satellites (CR6). They are 2 ways with 6 inch drivers.
I need it to run off the speaker level output (not LFE) of the amp. It should have adjustable xover, gain and auto power on.
I don't have a lot of room to work with where it can be installed, so I am limited to an 8" powered sub or a small 12" design.
FWIW, I have 100W into 8 ohms available, so I could probably even use a passive design of some sort, like the "tubes" you see for car stereos.
Most of the thread seems to be devoted to best bang for the home theater buck. What about a music only sub to fill out the bottom in a large room?
humbland is offline
post #1445 of 3580 Old 05-29-2013, 09:44 AM
BeeMan458's Avatar
Liked: 813
That's kind of an easier said then done sort of question as large rooms take a lot of subwoofer based output to fill or pressurize them and that's gonna cost and the smaller a subwoofer's driver is, the less chance there is of it doing what you want it to do.
If filling out the bottom end of music only, then for the most part, subs capable of down six dB at about 24Hz, like a delivered Klipsch, RW-12d from Newegg.com for $350.00, would work. But with large rooms and a single sub solution, one has problems created by subwoofer based sound waves bouncing around in a room as you're now dealing with inevitable reinforcement/cancellation issues. Hence the need for multiple subs to smooth these room modes out.
How large is the room and what kind of budget are you working with.
post #1446 of 3580 Old 05-29-2013, 10:00 AM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
Yes, to a point, and it increases the cost.
The finish work kills it for me. I can throw together a box and hide it somewhere, but, if it has to look good, too, count me out.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #1447 of 3580 Old 05-29-2013, 10:17 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #1448 of 3580 Old 05-29-2013, 10:21 AM
Liked: 1416
Absolutely, which is a PITA and, again, adds to the cost.
I admire the DIYers, but I'm not going to be one.
I'm VERY happy with my Klipsch 12d.
post #1449 of 3580 Old 05-29-2013, 10:22 AM
humbland's Avatar
Quoted: 457 Post(s)
Liked: 96
Thanks for the quick feedback.
I think that the RW-12d will be too large to fit on the shelf where it has to go. The area is open to two rooms, kitchen and dining, so I know I can not get good pressurization. This is for background listening, so I'm not worried about nodes. The budget is as cheap as possible, and still work; But no more than $200. A good 8" or compact 12' is what I had in mind.
humbland is offline
post #1450 of 3580 Old 05-29-2013, 10:43 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by humbland View Post
The area is open to two rooms, kitchen and dining, so I know I can not get good pressurization. This is for background listening, so I'm not worried about nodes. The budget is as cheap as possible, and still work; But no more than $200. A good 8" or compact 12' is what I had in mind.s
I hate questions like this as I've found folks are wanting $2,000.00 worth of output in a $200.00 form factor. There's nothing wrong with doing this but it's a hard ideal to replicate.
There are two kinds of subwoofers, sealed and vented or ported. Ported for large rooms that open into other rooms and sealed for small rooms that benefit from room gain.
(if you know the above, my apologies for being so basic)
If you're expecting the subwoofer to have musical authority, you're setting yourself up for fail as you've limited yourself with your specifications. But if realistically, one understands they've intentionally limited themselves and are willing to live within the restrictions of the inherent limitations, then, for it's size, something like a Dayton, Sub 1200 would work but it's frequency limited.
And as one goes up the ladder of desirable features, cost goes up as well until you're at something like a SVS, SB-1000 (13"x13"x13" which is a small form factor) that runs $500.00. If one is willing to deal with a larger size, the ported, PB-1000 would be a better choice for your listening venue but it's larger and at $500.00, also above your stated budget of $200.00.
It all depends on how much one values their music, how many Benjamins they have to throw at the problem and what kind of limitations they're willing to live with.
post #1451 of 3580 Old 05-29-2013, 10:53 AM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Dayton Audio
- SUB-800 ($79)
- SUB-1000 ($99)
- SUB-1200 ($119)
eljaycanuck is offline
post #1452 of 3580 Old 05-29-2013, 11:50 AM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
Check your local Craigslist for any possible deals. Check the classifieds here and other forums for local deals (at that low of a budget, shipping will be 50% of a sub cost so it's likely going to have to be local)
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #1453 of 3580 Old 05-29-2013, 04:47 PM
humbland's Avatar
Quoted: 457 Post(s)
Liked: 96
Originally Posted by eljaycanuck View Post
Dayton Audio
- SUB-800 ($79)
- SUB-1000 ($99)
- SUB-1200 ($119)
All good sugestions.
I had a Dayton 12", but sold it a while back. It's good, but too big for this shelf. I get it that I'm pushing the form factor "bang for the buck", but isn't that what this thread is for...smile.gif
Any other suggestions for a good 8" or small 12'?
humbland is offline
post #1454 of 3580 Old 05-29-2013, 04:58 PM
Liked: 1964
I had a Dayton 12" ... It's good, but too big for this shelf.
Okay, so, what are your max dimensions (l x w x h)?
post #1455 of 3580 Old 05-29-2013, 05:06 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
JBL SUB150P has been down below $200 on sale at Newegg a few times: http://www.newegg.com/Product/Product.aspx?Item=82-665-157.
Newegg testimonials for it are good, and someone on AVS bought it and liked it. If it's the right size, could be a good choice for you if it goes back down in price.
Here's a review: http://www.avhub.com.au/images/stories/australian-hifi/reviews/2011-05_to_12/2011-11/jbl_sub150p_subwoofer_review_lores.pdf
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #1456 of 3580 Old 05-29-2013, 05:11 PM
Liked: 1964
If it's the right size, could be a good choice ...
Good deal, but unfortunately - and according to the specs - it's an inch or more bigger in each dimension than the too-large SUB-1200:
17-3/8" (w) x 17-3/8" (d) x 18-1/2" (h)
post #1457 of 3580 Old 05-29-2013, 05:16 PM
Bond 007's Avatar
Quoted: 2654 Post(s)
Liked: 2104
Bond 007 is online now
post #1458 of 3580 Old 05-29-2013, 05:19 PM
screeli's Avatar
You may have waited too long for the Klipsch. It's been "Out of Stock" and "Discontinued" several times, but now it's "Not available":
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
This may be your next-best bet:
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/67178-nxg-nx-bas-500-subwoofer-review.html
available for $260:
http://www.amazon.com/NXG-Technology-NX-BAS-500-500-watt-Subwoofer/dp/B008FSTU4G/ref=sr_1_1?m=A28SS3BS1DBQ92&s=electronics&ie=UTF8&qid=1369768087&sr=1-1
Apparently so. As an alternative, I found a local deal on a Klipsch set that ill admit is a step down, but seemed like a killer deal for settling down until I can find the Perfect units. Does anyone have any feedback on the F2 speakers/sub? I have been looking for reviews and most reviews are fairly positive. seems to be a big bang for the buck! that said, they are 6-7 years old...
They are asking $345 for the set, which I may be able to get the price down a bit. The kit includes the following:
Klipsch F2 standing floor speakers (2), F2Center, and Sub (Sub 10. 120V model #T2.0AL 250V)
orlando.craigslist.org/ele/3715837033.html
seem like a good deal? Would anyone be worried about speakers sitting in storage for 3 years?
screeli is offline
post #1459 of 3580 Old 05-29-2013, 05:24 PM
humbland's Avatar
Quoted: 457 Post(s)
Liked: 96
Thanks for the ideas.
The max height I can work with is about 12.5-13" Depth and width are not an issue.
The Energy looks good, but too big.
There was another one on that page that caught my eye.
http://www.amazon.com/Energy-ESW-C8-8-Inch-Subwoofer-Black/dp/B0021L9BMO/ref=pd_cp_e_0#productDescription
What do you think?
humbland is offline
post #1460 of 3580 Old 05-29-2013, 05:27 PM
Bond 007's Avatar
Liked: 2104
What do you think?
A good choice. Hate to see you pay just as much for the 8 as the 10 but thats your business.
Licence to Kill
post #1461 of 3580 Old 05-29-2013, 06:35 PM
Splicer010's Avatar
Liked: 40
I just looked at your HT link...You ARE joking that the Dayton 1200 is "too big"???
http://www.amazon.com/gp/product/B001RPW6UE/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=A39ZEM0YEOKSJF
Its used but a really good sub for $199.
Another piece of crap using 'peak' power to sucker the consumer into believing it is a good sub...
What do you think?
I think it is an over rated piece of crap for the price...Don't be suckered by the BS power ratings...
Splicer010 is offline
post #1462 of 3580 Old 05-29-2013, 07:29 PM
Bond 007's Avatar
Liked: 2104
You obviously dont know anything about the older Energy subs.
Licence to Kill
post #1463 of 3580 Old 05-29-2013, 07:56 PM
richlife's Avatar
Quoted: 731 Post(s)
Liked: 854
I'm coming into this late and hope I don't repeat or offend. Picking up on recent questions to answer rather than offering specific solutions, this is some info that may help.
On the question of adequate sub for a large room. Always calculate LxWxH -- I have a living room/dining combo with overhead loft (high sloped ceiling). Total volume: 6000+ cubic feet. It takes me four (4) good-sized powered subs to really fill that space. (Yes, I put some real money into it many years ago.) When one of my subs went out, it was obvious. Still sounds good, but I'm retired and can no longer put that kind of money into my system.
This leads to another question. To fill large volumes you need to move a lot of air. My choice has always been to use 8" woofers. But my subs each have 2 or 4 of these. Calculate the area of air that can be moved by 8" vs. 12" woofers. (The math guys will use pi, but pi rounded to 3 will illustrate.). 3x8=24 while 3x12=36. But if the sub has TWO 8" woofers, that's 48 sq inches of air moved vs. 36. That's why I like 8" woofers.
Individually, 8" woofers are less costly and they are no where near as self-destructive as the larger woofers. Properly designed, the sub is more efficient.
Now there's more to it than that, but if woofer materials, construction, etc. are equal, I'll take the 8" route.
Rich
Atmos/DTS:X HT in Vaulted Room -- LG OLED Settings Options
Yamaha RX-A3060: 7.2.4 or 7.2.2 + Zone2 (switchable); OPPO 203; LG OLED65B6P; Harmony 650 & Home Hub
Base: Mirage OM-6 (FLR), MC-si (C), OM-R2 (SLR), FRx-nine (BLR)
Presence: ELAC A4s (FP), RSL C34Es (RP); 2 aci Titan subs; RP amp: AudioSource AMP100VS
richlife is offline
post #1464 of 3580 Old 05-29-2013, 08:04 PM
Splicer010's Avatar
Liked: 40
Have you learned NOTHING from my past posts in this thread, my friend? confused.gif
It is all in the amp and the advertising of such that does it in, at least as far as I am concerned anyway.
240-watt custom matched amplifier for clean and deep bass down to 36hz
BS
RMS Power Range - Amplifiers60 watts
Most probable
With 240 watts, you'll hear and feel bass the way it's meant to be experienced
MORE BS
C'mon man, you gotta LOOK to see the wool being pulled over ones eyes... wink.gif
Do you seriously intend to tell me that this lil' 8 incher can even come close to the quotes 1 & 3??? Bullsheetz...
post #1465 of 3580 Old 05-29-2013, 08:07 PM
Bond 007's Avatar
Liked: 2104
Youre missing out by judging everything solely on specs.
Licence to Kill
post #1466 of 3580 Old 05-29-2013, 08:14 PM
richlife's Avatar
Quoted: 731 Post(s)
Liked: 854
And power is a consumption value -- not related to efficiency. The 10" is 400W peak (yes, crapola) but 150W RMS. Good power - not especially efficient. (But efficiency cost money.). The 8" is 240W peak (more crapola) and I don't see an RMS rating. So go back to my basic premise -- 3x8=24 and 3x10=30. You lose 20% of air movement -- that's a lot for a sub regardless of quoted test results. And you can assume these are equal materials and build.
Bond is right, you'd be much better off trying to make the 10" work.
Rich
richlife is offline
post #1467 of 3580 Old 05-29-2013, 08:18 PM
Splicer010's Avatar
Liked: 40
Yes, you are, of course, correct...I am missing out on wasting perfectly good money on CRAP! (damn phones that post before it is time!) wink.gif
post #1468 of 3580 Old 05-29-2013, 08:19 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Rich
Typical surface diameter (SD) of standard woofer sizes
8" - 200 cm2
10" - 350 cm2
12" - 500 cm2
15" - 800 cm2
18" - 1150 cm2
A 12" has 2.5 times more surface area then a 8". The increased SD of larger drivers allows them to be more efficient while still having a lower FS, and supporting longer excursion. Everything about the subwoofer frequency range is about how much air can you move. There is 0 advantage to a smaller driver. Not sure where you are getting some of this stuff (less self-destructive?)...
Jay1 is offline
post #1469 of 3580 Old 05-29-2013, 08:20 PM
Bond 007's Avatar
Liked: 2104
They are the same model except for size. The 10" is a respected sub here. Its cousin the Energy 10.3 was the best thing going until it sold out finally. I would not pay $300 for it but at $200 for a good used one its better than anything else mentioned imo.
Licence to Kill
post #1470 of 3580 Old 05-29-2013, 08:21 PM
Bond 007's Avatar
Liked: 2104
Whats up with the potty mouth? Grow up.
Licence to Kill
