Budget subwoofers discussions, opinions and questions thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 115Likes
post #1801 of 3578 Old 09-03-2013, 03:20 PM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
Where is the best place to get the Dayton SUB 1200?
Licence to Kill
Bond 007 is offline
post #1802 of 3578 Old 09-03-2013, 03:40 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Dayton is the parts-express.com house brand.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #1803 of 3578 Old 09-03-2013, 03:41 PM
Bond 007's Avatar
Liked: 2090
Thanks. Duh..I forgot.
Licence to Kill
Bond 007 is offline
post #1804 of 3578 Old 09-03-2013, 03:42 PM
cel4145's Avatar
Liked: 3002
cel4145 is offline
post #1805 of 3578 Old 09-03-2013, 04:32 PM - Thread Starter
JimWilson's Avatar
Quoted: 1533 Post(s)
Liked: 2039
Originally Posted by dude74 View Post
Thank, sounds good. Jim, is there a place where all of your reviews are located?
Most of them can be found here. My screen name is theJman. Pour yourself a cold one - I'm long winded, so there's a lot to read... tongue.gif
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #1806 of 3578 Old 09-03-2013, 05:38 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
My two PL-200s are set for delivery tomorrow. It's going to be a long day at school while I look forward to getting home to set them up and test them out.
Gronnie is offline
post #1807 of 3578 Old 09-04-2013, 03:36 AM
dude74's Avatar
I'm thinking I might need a front ported sub, since it will probably be placed in a corner or against a wall. What would be the difference in sound and clarity with front ported versus rear ported? And what is a good front ported budget sub?
Yamaha RX-V1065 receiver
Bowers & Wilkins 685 front speakers
SVS SB-1000 subwoofer
Marantz PMD350U CD/cassette player
Sony BDP-N460 Blu Ray player
Sony Bravia KDL-40V5100 flat screen TV
Wii game console
Roku 2XD internet streaming box
dude74 is offline
post #1808 of 3578 Old 09-04-2013, 03:53 AM
Bond 007's Avatar
Liked: 2090
Bond 007 is offline
post #1809 of 3578 Old 09-04-2013, 05:24 AM
Yankees24's Avatar
Quoted: 92 Post(s)
Liked: 38
Some Velodyne models are front ported. I had an old cht-10 that was.
Think before you speak....
Yankees24 is offline
post #1810 of 3578 Old 09-04-2013, 05:35 AM - Thread Starter
JimWilson's Avatar
Liked: 2039
Most ports don't require a lot of room, so depending upon how close to the back wall you need to place it a rear port might still work.
A port not facing the listener tends to mask some of the unpleasant sounds that are almost inevitable when a bass reflex sub gets pushed to it's limit. The port noise is not eliminated, mind you, but is often less obtrusive.
post #1811 of 3578 Old 09-04-2013, 07:02 AM
dude74's Avatar
So what are the results of a rear ported against a wall? How much space is actually needed? Also, would a bottom ported correct these issues?
Wii game console
dude74 is offline
post #1812 of 3578 Old 09-04-2013, 07:57 AM - Thread Starter
JimWilson's Avatar
Liked: 2039
What type of 'results' are you referring to?
post #1813 of 3578 Old 09-04-2013, 08:39 AM
Bond 007's Avatar
Liked: 2090
You can run into port noise when any sub is driven too hard. Especially in this price bracket.
12" is usually plenty of room between the port and any surface.
Licence to Kill
Bond 007 is offline
post #1814 of 3578 Old 09-04-2013, 10:21 AM
dude74's Avatar
By "results" I'm looking for how the sound is affected with a rear ported sub too close to the wall. Also, are bottom ported subs better for corner/wall placement? I only have a sealed sub and never had a ported one before.
Wii game console
dude74 is offline
post #1815 of 3578 Old 09-04-2013, 11:10 AM - Thread Starter
JimWilson's Avatar
Liked: 2039
The port contributes to the overall depth and output of a bass reflex subwoofer, so it's always best to ensure they have sufficient room to "exhale". If there's a question about whether you can do that, given your placement options, it's best to err on the side of caution and go with something else.
post #1816 of 3578 Old 09-04-2013, 01:40 PM
dude74's Avatar
For example, with the NXG, how close is too close? Would a down firing port make more sense? Most of the "higher quality" budget subs seem to be ported. Are there good sealed budget subs out there?
Wii game console
dude74 is offline
post #1817 of 3578 Old 09-04-2013, 01:42 PM
dude74's Avatar
My current system has a SVS SB-1000. It's a great sub, but I don't want to pay that much for my budget system.
Wii game console
dude74 is offline
post #1818 of 3578 Old 09-04-2013, 02:33 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
The vast majority of budget subwoofers will be ported, primarily because that enables you to get "extra" output from lesser components. With acoustic suspension you need better drivers and amps, which generally cost too much for a budget product.
When I was doing the NXG review I had the sub about 8" from the rear wall, and it seemed to work fine that way. You might be able to move it a bit closer, but probably not too much.
post #1819 of 3578 Old 09-04-2013, 05:39 PM
dude74's Avatar
It probably wouldn't be right against the wall. Maybe 4 to 6 inches?
Wii game console
dude74 is offline
post #1820 of 3578 Old 09-04-2013, 06:31 PM - Thread Starter
JimWilson's Avatar
Liked: 2039
6" is probably OK. Not sure about 4" though.
post #1821 of 3578 Old 09-04-2013, 08:03 PM
Bond 007's Avatar
Liked: 2090
+1
Licence to Kill
Bond 007 is offline
post #1822 of 3578 Old 09-05-2013, 03:24 AM
dude74's Avatar
Are there pros/cons for front ported vs. rear ported vs. bottom ported?
Wii game console
dude74 is offline
post #1823 of 3578 Old 09-05-2013, 03:55 AM
Bond 007's Avatar
Liked: 2090
In general, no.
Licence to Kill
Bond 007 is offline
post #1824 of 3578 Old 09-05-2013, 09:01 AM
batpig's Avatar
Quoted: 3707 Post(s)
Liked: 3577
It's harder for your cat to get stuck inside a bottom ported sub. Or for your 2 year old to shove grapes into.
Bass waves radiate omnidirectionally so, outside of the placement concern of a rear port close to a wall, it doesn't really matter. It's just a design choice but shouldn't offer any inherent advantage one way or the other.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #1825 of 3578 Old 09-05-2013, 09:26 AM
Bond 007's Avatar
Liked: 2090
lol Sounds like your speaking from experience.
Licence to Kill
Bond 007 is offline
post #1826 of 3578 Old 09-05-2013, 11:10 PM
dude74's Avatar
Ha. No kids or cats, but I have 2 dogs. NXG sounds really tempting. Also PSW505 and (maybe) F12. I'm looking forward to an in depth review of the Dayton, however. Is that pretty much the list of best budget subs? Klipsche RW12 sounds interesting too, but that's a bit too expensive for what I'm looking for.
Wii game console
dude74 is offline
post #1827 of 3578 Old 09-06-2013, 07:37 AM
xp0z3d's Avatar
Guys , I am getting Klipsch Rw12d used on CL for $275 but its 3 years old and I will have to drive 2 hrs away to get it. Would it be good idea to get it at that price or get a new Nxg 500 bass for $280 (with sales tax). Kind of confused and want someone to help me decide.
xp0z3d is offline
post #1828 of 3578 Old 09-06-2013, 07:45 AM
cel4145's Avatar
Liked: 3002
Considering the RW-12d was often on sale for $280 to $300 over the past several years, sounds like someone is trying to recoop all of their cost. Just google RW-12d and Slickdeals, and you'll be amazed how often it was posted as on sale (and it wasn't always posted there either). So I wouldn't pay $275 for it unless it's like new, never been used, in the box.
cel4145 is offline
post #1829 of 3578 Old 09-06-2013, 07:57 AM
Bond 007's Avatar
Liked: 2090
+1
Licence to Kill
Bond 007 is offline
post #1830 of 3578 Old 09-06-2013, 08:01 AM
xp0z3d's Avatar
Yeah i know it used to be on sale since forever at Newegg. Recently they have ran out of these so they are not selling them since few weeks now. This has driven up prices at ebay and amazon. So will tell this guy No then.
xp0z3d is offline
