Budget subwoofers discussions, opinions and questions thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 117Likes
post #1891 of 3580 Old 10-05-2013, 12:50 PM
Brad Sutliff's Avatar
It's 10x12x8 Roughly. So about 1000 cubic feet
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #1892 of 3580 Old 10-05-2013, 03:47 PM - Thread Starter
JimWilson's Avatar
Quoted: 1567 Post(s)
Liked: 2097
Since your room is so small you may not benefit from the true value that duals provide, so in this case one better sub is probably the better option.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #1893 of 3580 Old 10-05-2013, 03:50 PM
Bond 007's Avatar
Quoted: 2662 Post(s)
Liked: 2113
+1 Especially if properly placed and set up.
Licence to Kill
Bond 007 is offline
post #1894 of 3580 Old 10-05-2013, 05:28 PM
Thanks for the help guys!
post #1895 of 3580 Old 10-07-2013, 07:52 PM
chanwhk's Avatar
I've just received my NXG BAS 500. The moment I turn it on and played some music, i started to hear a rattling noise. Like something loose on the driver. The sound is like something vibrating against the cone as the cone moves. After a closer look, I've found out that the very center of the cone, which looks like its glued on top of the surrounding, is poorly glued and can be lift off with my nail. Only 90 degree of the circle is glued and I can lift the remaining 270 degree off a few mm. If i lightly touch it while music is playing the rattling sound disappears.
After hearing good things on how good it is built and how good it sounds it's kinda disappointing to see it fails on something so simple.
Another thing that might not affect the SQ is how badly the center circle is cut. You can see that in the photos. I don't really mind, just want to point out.
Is this a common problem among budget subwoofer? Is it safe to just glue it myself with some super glue?
Edited: The center circle is called a "dust cap"
chanwhk is offline
post #1896 of 3580 Old 10-07-2013, 08:50 PM
endtr0ducing's Avatar
where did you order it from?
endtr0ducing is offline
post #1897 of 3580 Old 10-07-2013, 08:51 PM
chanwhk's Avatar
Radioshack online and ship to store
I can return it if need be
chanwhk is offline
post #1898 of 3580 Old 10-07-2013, 08:58 PM
chanwhk's Avatar
I'm thrilled to report that after less then an hour of some light testing and playing, the whole damn circle just came off!! LOL
I have used some double sided tape to reduce the rattling as a quick fix and when I took the front grid off. This happened.
I admit I did play some bassy music along with some light classical but I wasn't trying to shake the house..
But thanks to this.. i can say it is probably safe to glue the circle back on.. (probably easier too)
the black circle is the where the glue took the metallic paint off
chanwhk is offline
post #1899 of 3580 Old 10-07-2013, 09:13 PM
Bond 007's Avatar
Liked: 2113
Please take a better picture of that without the center.
And then...take that piece of crap back.
Licence to Kill
Bond 007 is offline
post #1900 of 3580 Old 10-07-2013, 09:23 PM
I was thinking about getting that sub...
post #1901 of 3580 Old 10-07-2013, 09:26 PM
Bond 007's Avatar
Liked: 2113
imo Its a fluke. But theres no way I would try to repair it when I just got it home.
Licence to Kill
Bond 007 is offline
post #1902 of 3580 Old 10-07-2013, 09:27 PM
Yeah I agree. But still is worrisome. But yeah I'd return that pronto
post #1903 of 3580 Old 10-07-2013, 09:33 PM
chanwhk's Avatar
Here u go
chanwhk is offline
post #1904 of 3580 Old 10-07-2013, 09:41 PM
chanwhk's Avatar
The center circle only act as a dust cover so nothing weird gets inside it seems.
It doesn't seem to affect the sound at all as I only found out its gone after I took the grid off
Sound is pretty good from my short listen tho.
chanwhk is offline
post #1905 of 3580 Old 10-07-2013, 09:43 PM
Bond 007's Avatar
Liked: 2113
Thank you, sir.
I hate to be a pain in the *** but it would be appreciated by all if you could take a tighter close up of the center of the woofer. Especially since your pics are so small.
Licence to Kill
Bond 007 is offline
post #1906 of 3580 Old 10-07-2013, 09:46 PM
Bond 007's Avatar
Liked: 2113
That center is supposed to act as much more than a dust cover.
You are in a bit of a unique position here because youre the first one to get one of these at this thread.
Thanks for posting.
Licence to Kill
Bond 007 is offline
post #1907 of 3580 Old 10-07-2013, 09:46 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
& let us know how the return process goes, please
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #1908 of 3580 Old 10-07-2013, 10:06 PM
chanwhk's Avatar
Thanks for posting.
You mean one of these faulty ones.
Jman and a few others should have these
chanwhk is offline
post #1909 of 3580 Old 10-07-2013, 10:08 PM
chanwhk's Avatar
Will do.. returned should be no problem.. I've called and asked multiple times if I can return it.
Note that if you get it from Radioshack Online, I was told that the only way I can return it to store is to have it shipped to store in the first place.
If it was shipped to home you'll have to mail it back
chanwhk is offline
post #1910 of 3580 Old 10-07-2013, 10:23 PM
Quoted: 197 Post(s)
Liked: 511
Thanks. The could prove to be a handy little piece of information to have right there.
post #1911 of 3580 Old 10-07-2013, 10:24 PM
chanwhk's Avatar
Thank you, sir.
I uploaded original size straight from my OMD-EM5. You can click to see the original its pretty big. 4608x3072
anyways.. Here's your special request. Click to see original size.. its a 5Mb jpeg
Why do you want to see that part?
chanwhk is offline
post #1912 of 3580 Old 10-08-2013, 04:26 AM
Bond 007's Avatar
Liked: 2113
Many thanks. Unless someone else gets another defective one we may never have the opportunity to see whats under that center piece.
Licence to Kill
Bond 007 is offline
post #1913 of 3580 Old 10-08-2013, 04:31 AM
Bond 007's Avatar
Liked: 2113
I have never bought anything that expensive or big from Radio Shack but I have bought things from them and had it shipped to store and then picked it up there. Usually if you have it shipped to store instead of your home shipping is free. I have never had a problem just taking it back to the store to return it.
Licence to Kill
Bond 007 is offline
post #1914 of 3580 Old 10-08-2013, 12:10 PM
cherishzm1730's Avatar
I'm a kind of a newbie here trying to find out what would be the best option to improve the quality of my existing HT system (3.1). And because my subwoofer (from a 'HKTS 8' Harman Kardon HTIB package ) died few months ago I'm thinking about replacing the system and would like to start with a subwoofer.
First of all, I have the system set up in a huge open "great room" space that's has two sides wide open to a kitchen, foyer and breakfast room. And the great room (15"x23"x18") has and the total square footage including the kitchen, breakfast room, etc is about 26"x20"x9"). I've read some posts here and found it'd be quite difficult to have good bass to fill in this large space and my budget is limited at $300~$400 for the subwoofer.
I'll be using the system for 75% movie/TV watching and 25% music. If anyone can suggest me a good subwoofer to fulfill my needs, I'd appreciate. By the way, I currently have a Harman Kardon AVR254 receiver, Energy C-50 front speakers and Boston Acoustic center channel (don't know the model name). I did order a pair of Cambridge S30's to replace front speakers. Would I need to replace the receiver and the center channel? Also, would the Cambridge S30's be good addition to my system?
Thanks in advance!
cherishzm1730 is offline
post #1915 of 3580 Old 10-08-2013, 08:03 PM
swim33's Avatar
I would look at dual JBL ES250's or even dual BIC F12's because that is a pretty large space. I have heard the PA-150 recommended for large also. Just a few options to consider.
-Ben
swim33 is offline
post #1916 of 3580 Old 10-09-2013, 06:43 AM
Thanks for the suggestion. Where would be an ideal place to set up the dual subwoofers? And how do I connect them to the receiver?
How would the BIC F12's or PA-150 perform compared to a BIC PL-200? I was able to grab a PL-200 for $249 while it was on sale last weekend on Amazon.com but I can always return it within 30 days.
post #1917 of 3580 Old 10-09-2013, 06:55 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
The PA-150 would be my choice. It has impressive output and would help in a space like that. Eventually you will probably want a second one with such a big space.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #1918 of 3580 Old 10-09-2013, 06:59 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
I agree. The PA-150 seems the best bet for that large of a room space. From 40hz on up, it has the max output of some of the best much more expensive 12" subs.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #1919 of 3580 Old 10-09-2013, 08:21 AM
Thanks for the suggestion, folks. PA-150 is being sold for $499 on Amazon.com and it's over my budget unfortunately. Do these go on sale from time to time?
post #1920 of 3580 Old 10-09-2013, 08:30 AM
I think the PA-150 at 500 is somewhat of a deal. so might not
noiselisten likes this.
