Budget subwoofers discussions, opinions and questions thread - Page 88 - AVS Forum | Home Theater Discussions And Reviews
 111Likes
post #2611 of 3530 Old 02-13-2014, 09:24 PM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
Originally Posted by basshead81 View Post
Probably would give the edge to the servo controlled LV12.
Thats why I chose it. I was actually debating more between the LV12 and the SB2000. If I had to wait any longer Id have the SB2000 now. I nearly got it a couple of times but its a farly big difference in money.
Licence to Kill
Bond 007 is offline
post #2612 of 3530 Old 02-13-2014, 09:49 PM
S Russ's Avatar
At 600.00 it would be a no brainer to get the NSD over the LV12...more robust driver, more power, 5yr warranty = No brainer. Don't get me wrong the LV12 is alot of sub too at 589.00, but I do not think its quite at the NSD level. Bear in mind its probably not a huge difference either way you go. I would place the LV12 inbetween the PB-1000 and the NSD.
The more I think about it, I may want to add another in the near future.  The fact that the NSD is being phased out is a major factor.
That warranty really is something though...
Nice, I greatly value accuracy and extension.  How would they compare in regards to the latter?
I'm not the type that's too concerned with max output and obsessing over the extremes...
Hmm, I wonder if the budget thread is the best place for this..
PSN: sick_ap2
XBL: Th3Chosen0ne
S Russ is offline
post #2613 of 3530 Old 02-13-2014, 10:45 PM
brodi6's Avatar
Originally Posted by sjr809 View Post
Regarding dual Dayton Sub 1200's after lurking for months reading opinions and Jim's review over at the shack I pulled the trigger on 2 for Christmas. I haven"t had the time to really get them dialed in and really wanted to wait to give my 2 cents worth. My room is 16.5 x 21 and is a sunken living room with steps up into my dinning room. So far I am quite happy with my under $250 investment. I will post further once I have some time to play with placement and do some serious evaluation.
I await your full review as this is the solution I may be leaning toward as well.
brodi6 is offline
post #2614 of 3530 Old 02-13-2014, 10:56 PM
brodi6's Avatar
Originally Posted by batpig View Post
In general, placing them in different spots will give you a good shot at producing a smoother overall response (reducing modal resonances so you have fewer peaks and nulls and the bass is more consistent around the room) as each subwoofer will be energizing different room modes. Even if you can only place them semi randomly they should produce a smoother reponse.
If you have some flexibility, this article covers a few of the easiest options: http://www.aperionaudio.com/blog/dual-subwoofers-for-your-home-theater
The 1/4 wall approach is the best for a rectangular room as it will do a great job of smoothing out the horizontal modes, so the left/right response will be quite consistent. If you want to do one front, one back, you can still aim for that (for example, one sub up front 1/4 width in from the left wall, and the other sub behind you 1/4 width in from the right wall. Then you get some benefit in width mode reduction, as well as length modes.
Very good article! Lots of great info there. Thanks!
My room setup is very odd (TV in the corner, etc) so I don't know exactly how it's going to go if I take the plunge on dual subs. I'll probably just end up moving them all over the room to find the best sound and hoping to god they don't end up sitting somewhere completely inconvenient to life when I find the sweet spot.
brodi6 is offline
post #2615 of 3530 Old 02-14-2014, 04:19 AM
paulks's Avatar
Here is a few deals on subs you might be interested.
Outlaw M8 is on sale at 250 and klipsch sub 12 is 200 at frys. I do not know the difference b/w 12hg. Dayton Sub 1200 is going to be on sale in a week or so at 110.
paulks is offline
post #2616 of 3530 Old 02-14-2014, 05:19 AM
brodi6's Avatar
At Amazon?
brodi6 is offline
post #2617 of 3530 Old 02-14-2014, 06:00 AM
paulks's Avatar
Originally Posted by brodi6 View Post
At Amazon?
at Part Express but not sure at Amazon.
paulks is offline
post #2618 of 3530 Old 02-14-2014, 07:02 AM
sjr809's Avatar
Got mine from Parts Express. Ordered on Christmas Day eve and came in about a week which might be quicker now since not holiday crush. Double boxed to boot!
sjr809 is offline
post #2619 of 3530 Old 02-14-2014, 07:07 AM
Gratefulvol's Avatar
I'm looking for some help with deciding on a new sub. Right now the budget will not allow for a high end sub so here is what I am thinking. Right now the Pioneer MK2 is on sale for $99. Would 2 of these, 2 of the Dayton 1200, or a single Bic f12 sound better? The room is 15x12. The subs will be paired with the Pioneer Andrew Jones line of speakers, not sure about a receiver yet.
Any input is welcome!
Gratefulvol is offline
post #2620 of 3530 Old 02-14-2014, 07:55 AM
paulks's Avatar
I used Pioneer sw8mk2 in a living room sized 12*13. It sounded smooth and natural but not loud enough even if I am not looking for room shaking experience. The next subwoofer was Prosub 1000 of Definitive Technology. I got this for 360 and it was powerful and loud enough with 20% gain. If you are not care about low extension, it sounds great. I returned this one, too, and looking for a new sub among Outlaw M8, Klipsch Sub 12 and Dayton Sub 1200. It is not a easy decision to me cause I never listen to any of them in person.
paulks is offline
post #2621 of 3530 Old 02-14-2014, 02:47 PM - Thread Starter
JimWilson's Avatar
Quoted: 1267 Post(s)
Liked: 1564
I'd steer clear of the Pioneer; the price is certainly enticing, but output and depth will be lacking. The F12 will probably be able to extend a bit deeper than the SUB-1200, but a pair of the latter will allow you to even out room modes or give better total output (depending upon how you place them). If dual SUB-1200's are a possibility, price wise, what about a single SUB-1500 instead? I suspect that would be the best of both worlds.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #2622 of 3530 Old 02-20-2014, 05:45 AM
paulks's Avatar
NX-BAS-500 seems to be in stock.
paulks is offline
post #2623 of 3530 Old 02-20-2014, 05:57 AM
Bond 007's Avatar
Liked: 1907
Interesting that none of the authorized dealers have it in stock. I checked all 4. You can get it at this third party seller but NXG may not honor the warranty.
http://www.amazon.com/gp/product/B008FSTU4G/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A2R0FX412W1BDT
Licence to Kill
Bond 007 is offline
post #2624 of 3530 Old 02-20-2014, 08:12 AM
paulks's Avatar
This is from authorized dealer. It says 65 in stock.
http://www.hififorless.com/showProduct.php?productid=598992
paulks is offline
post #2625 of 3530 Old 02-20-2014, 08:14 AM
Bond 007's Avatar
Liked: 1907
Good deal. They must have just added that to their site.
Licence to Kill
Bond 007 is offline
post #2626 of 3530 Old 02-20-2014, 08:14 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
caloyzki is offline
post #2627 of 3530 Old 02-20-2014, 08:16 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Originally Posted by caloyzki View Post
I wouldn't do that, the LV12R is much more accurate and extends a lot lower. You will probably lose a little output, but more than make up for it with sound quality. Plus you always have the option of adding a second LV12R down the road.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #2628 of 3530 Old 02-20-2014, 08:17 AM
Bond 007's Avatar
Liked: 1907
Dont you mean return?
Licence to Kill
Bond 007 is offline
post #2629 of 3530 Old 02-20-2014, 08:19 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
i still havent get the LV12R since i ordered it. it was return to sender. due to the delivery problems and delayed, and i was away. Brian decided to return the sub. but i will stick with LV12R. hopefully i will get by end of feb.
caloyzki is offline
post #2630 of 3530 Old 02-20-2014, 08:30 AM
Bond 007's Avatar
Liked: 1907
+1
caloyzki likes this.
Licence to Kill
Bond 007 is offline
post #2631 of 3530 Old 02-20-2014, 08:43 AM
Bond 007's Avatar
Liked: 1907
Bond 007 is offline
post #2632 of 3530 Old 02-20-2014, 09:40 AM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Time to recalibrate the sarcasm detector.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #2633 of 3530 Old 02-21-2014, 04:40 PM
Mals's Avatar
Hi guys. I am looking for a budget sub (I wanted under $150, the BIC F12 was on sale for $130 before I started doing this.. I would just buy that if it were still that price)>
I am using this for a PC 2.1 setup, really want to spend under $150 on a sub. so maybe (edit) *Dayton Sub 1200, but I'd love some input on where to go.
The room is a typical 12~15x12~15 with one of those Nook Windows.. it's filled with a couch and a computer but otherwise isn't that big..and I don't need anything too fancy. I am upgrading from a Klipsch Promedia 4.1 system that the sub finally ripped on so I need replacement.
My current equip:
Bookshelves: http://www.amazon.com/gp/product/B008NCD2LG/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
Receiver: http://www.amazon.com/gp/product/B00B981F38/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Mals is offline
post #2634 of 3530 Old 02-21-2014, 04:49 PM
Bond 007's Avatar
Liked: 1907
Dayton SUB-1200
Licence to Kill
Bond 007 is offline
post #2635 of 3530 Old 02-21-2014, 04:54 PM
Mals's Avatar
Dayton SUB-1200
haha sorry, my mistake.. too many AV names in my head and Friday afternoons gettin to me. Dayton 1200!
Mals is offline
post #2636 of 3530 Old 02-21-2014, 04:59 PM
Mals's Avatar
Originally Posted by cel4145 View Post
Lava LSP12 for $170 is back!
This goes to a broken link :( the Lava for $170 would be an immediate fix for me.
Mals is offline
post #2637 of 3530 Old 02-21-2014, 05:03 PM
Bond 007's Avatar
Liked: 1907
Originally Posted by Mals View Post
This goes to a broken link frown.gif the Lava for $170 would be an immediate fix for me.
I dont think its available anymore.
Licence to Kill
Bond 007 is offline
post #2638 of 3530 Old 02-21-2014, 05:13 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
Somebody in the Lava thread reported picking up a brand new LSP12 on ebay for 135.00.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #2639 of 3530 Old 02-21-2014, 05:19 PM
Mals's Avatar
Interesting.. not sure if breaking rules.. but this is the same one from what I remember my research saying.
http://www.ebay.com/itm/TruAudio-Lava-12-Subwoofer-250-watt-LSP12-/271408009155?pt=Speakers_Subwoofers&hash=item3f312d8fc3
"All must go.. new.. factory warranties still exist".. etc?
Mals is offline
post #2640 of 3530 Old 02-21-2014, 05:27 PM
Bond 007's Avatar
Liked: 1907
Originally Posted by JimWilson View Post
The Lava LSP-12 is actually a Truaudio PS-12, but they don't list a weight either so it's hard to know if what Amazon quoted is accurate. It's probably heavier than that though.
Not sure what it all amounts to but heres some info from Jim regarding the Lava.
Licence to Kill
Bond 007 is offline
