Budget subwoofers discussions, opinions and questions thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 112Likes
Old 05-03-2014, 05:34 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 196
Yeah well, I'm having a tough time understanding how a larger mass can start and stop and reverse directions as fast as a smaller mass.
In the case of subwoofers though, the differences are probably not great enough for that to be a deciding factor given a stiff enough material and a larger motor, i.e. magnet and power.
charmerci is offline
Old 05-03-2014, 06:18 PM
bear123's Avatar
Quoted: 1719 Post(s)
Liked: 2528
A small woofer has to move exponentially more than a larger driver to produce the same SPL.
bear123 is offline
Old 05-03-2014, 06:38 PM
Bill Fitzmaurice's Avatar
Liked: 5011
I'm having a tough time understanding how a larger mass can start and stop and reverse directions as fast as a smaller mass..
It can when the motive force is a few magnitudes of order higher than the mass being propelled, rendering inertia too slight to effectively influence the result. That is the case with moving coil drivers. And, as noted by bear123, a larger cone doesn't have to move as far for the same SPL as a smaller driver. Since it doesn't have to travel as far it also doesn't have to travel as fast to go from the excursion peak to peak. And then there's also the matter of electrical to acoustical efficiency, which is higher with a larger cone than a smaller cone, even when both use the exact same motor. There is only one advantage to a smaller cone in and of itself, and that's the angle of dispersion, which decreases as frequency increases because the wavelengths produced become progressively smaller compared to the size of the cone. That must be compensated for by making the cone smaller as the band width produced goes higher in frequency, That is the primary reason why tweeters are smaller than midranges, which are smaller than midbasses, which are smaller than subwoofers.
Bill Fitzmaurice is online now
Old 05-03-2014, 10:00 PM
Kezzbot's Avatar
That's very interesting, so as a rule would you suggest sticking with 12" or higher unless space is a issue?
Kezzbot is offline
Old 05-04-2014, 05:51 AM
Liked: 5011
Google 'Hoffman's Iron Law'. The only way to get high output at low frequencies with a small speaker is when that speaker has a very long excursion driver powered by a very high capacity amp. It can be done, but it greatly increases cost. In short, if you see a sub loaded with less than a twelve and it's not extremely expensive then it's not going to go either low or loud.
Old 05-04-2014, 11:26 AM
Anodyne's Avatar
I just wanted to pop in and say that I can finally testify to the benefit of a dual sub setup. Last fall, I bought a Lava LSP-12 that replaced a Dayton SUB-1200. The difference was noticeable but not significantly so. But when the Lava subs went on their final closeout, I got a second one. After a couple months of breaking it in, I'm just blown away by the difference.
I listen to a lot of acoustic and bluegrass and it's night and day with a second sub. The upright bass sounds like it's right there in the room with me. It's not a one-note sound, either, which is what I was getting from the single SUB-1200.
With movies, I get a much more immersive feel and the action scenes are so much better that even if my wife's in another room, she gets a bit upset. smile.gif
I have a large, open room and before with a single sub setup, there was really only one decent viewing spot. Now, there's not a bad spot in the room.
I was doubtful at first because I just wasn't really hearing or feeling the difference. But I also have been so busy with work that I didn't get a chance to break it quickly. Two months later and I'd never be able to go back to a single sub again.
SHORT VERSION: Everyone on a budget with a large room should get a second sub!
Anodyne is offline
Old 05-04-2014, 05:37 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 196
But did you try the Lava with the Dayton?
Old 05-04-2014, 05:51 PM
Anodyne's Avatar
No, I heeded the advice on here to not mix different brands/models of subs. I'm currently using the Dayton as part of a 2.1 setup in the bedroom. It works well enough for that application.
Anodyne is offline
Old 05-05-2014, 11:26 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2995
Just noticed that the JBL SUB150P is back in stock at Newegg for $199. Time to watch for sales on it.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 05-07-2014, 02:23 PM
smurph98gt's Avatar
Damn. It's now $129!
With that being on sale, I figured I should finally try and figure out what I should do sub-wise... I'm trying to keep it under $200 if possible.
Room is about 15' wide, by 32' long, and ~10-11' high. We use about half the room as our main TV/Movie/video gaming area, with some occasional loud music playing thrown in. The sub I have is a little rinky dink 8" Yamaha that worked fine in my apartment, but is severely lacking in this much larger space.
https://i.imgur.com/iHa7T1I.jpg
https://i.imgur.com/sSshicE.jpg
(linked for size!)
As you can see.. the room isn't sealed.. like at all. On the other side of the room is an even bigger arch.
The main issues I have, are a) I only have bookshelf speakers, so mid-bass is fairly lacking. They're the Cambridge Audio s30s, and while they do a decent job, theres only so much they can do.. and b) Sub placement.. it's basically limited to either side of that little media console.
With all that being said.. a 10" or 12" sub seems reasonable. 10" might fit in that space better, and not walk all over those little bookshelf speakers.. but you know.. bigger is better.
With that JBL being $129, I'm seriously considering it. Other than that.. my other idea was the Dayton Sub-1200, also $129, but with $15 shipping vs Neweggs $2 shipping.
On the pricier end of the range, is the BIC F-12 or V1220. I'm not against those, I just wonder if they'll really bring anything different to the party for that stupid room, that's worth the extra ~$70 or so.
smurph98gt is offline
Old 05-07-2014, 02:27 PM
Bond 007's Avatar
Quoted: 2420 Post(s)
Liked: 1940
You definitely need 2 subs. I suggest 2 of the JBL 150s.
Licence to Kill
Bond 007 is online now
Old 05-07-2014, 04:43 PM
phillyd32's Avatar
Quoted: 36 Post(s)
I am looking for a subwoofer to pair with my Audioengine A5+.
Criteria:
  • 8-10" (could go bigger)
  • 100% for music
  • STRICT $450 budget
  • My room will be small, carpeted. 8-9' ceilings with about a 12x16 room. Mostly nearfield listening.
  • I really want good extension and accuracy. I listen to a lot of music with detailed bass.
  • I either need high pass crossover for my speakers or $40 to get crossover filters for my speakers.
Source: HTPC, Marantz TT42P
Display: ISF Calibrated Panasonic TC-55AS680U
Audio: Pioneer Elite SC-85 | Music Angel SDXE M9 | Klipsch KG5.2 w/Crites upgrades
phillyd32 is offline
Old 05-07-2014, 05:06 PM
Bond 007's Avatar
Liked: 1940
Criteria:
  • 8-10"
  • 100% for music
  • STRICT $450 budget SHIPPED
Get this quickly before someone else does.
http://www.svsound.com/specials/outlet-specials/sb-1000-outlet-ba_3#.U2rKUc7D_bU
phillyd32 likes this.
Licence to Kill
Old 05-07-2014, 05:27 PM
smurph98gt's Avatar
Ahh.. 2 just won't cut it due to the limited space. If you had to go with one, which way would you go?
e: I could potentially downsize the media cabinet, it's modular.. and end up with a little more room, but that needs to pass the wife factor as well. frown.gif Suppose I did do that, is there anything special I need? My receiver only has the one sub output.
Old 05-07-2014, 05:38 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Y cable from Radio Shack, et C.
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
Old 05-07-2014, 05:55 PM
phillyd32's Avatar
Quoted: 36 Post(s)
Might not have the money for a couple weeks. Backup options?
Old 05-07-2014, 06:13 PM
batpig's Avatar
Quoted: 3604 Post(s)
Liked: 3453
If you want a compact sub that is powerful, accurate and musical for $500 or less that is THE option.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 05-07-2014, 06:14 PM
phillyd32's Avatar
Quoted: 36 Post(s)
I didn't say powerful OR compact.
Old 05-07-2014, 06:29 PM
Bond 007's Avatar
Liked: 1940
When you get the money go to the SVS website and see if you can get the sb1000 at that price. Even if you have to spend $500 you wont regret it.
Licence to Kill
Old 05-07-2014, 07:59 PM - Thread Starter
JimWilson's Avatar
Quoted: 1342 Post(s)
Liked: 1720
A room that's a good 4800 ft^3 will swallow that little JBL whole. My guess is you wouldn't really hear enough of a difference from what you have now to warrant spending the money. The room is simply too large for either of those subwoofers. About the only one I can think of that hits your price point is the Dayton SUB-1500, but I don't imagine it falls within the size restrictions you have.
smurph98gt and phillyd32 like this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
Old 05-07-2014, 08:09 PM
cel4145's Avatar
Liked: 2995
Wow. That's the deal of the day. Too bad that they aren't stackable like cube shaped subs since you only have a spot for one (co-locating two works great).
cel4145 is offline
Old 05-07-2014, 08:13 PM
Bond 007's Avatar
Liked: 1940
http://www.amazon.com/Mediabridge-ULTRA-RCA-Y-Adapter-Inches/dp/B005DL2OVE/ref=sr_1_5?s=electronics&ie=UTF8&qid=1399518735&sr=1-5&keywords=subwoofer+y+cable
smurph98gt likes this.
Licence to Kill
Old 05-07-2014, 08:16 PM
smurph98gt's Avatar
Funnily enough, I had previously been looking around at the different 15" options, and it was seeing the SUB-1500 today that sent me down this rabbit hole of subwoofer choices (again....). I was seriously considering it, but I read some reviews about how it would just dominate anything less than a large bookshelf.
The funny thing about that SUB-1500, is that it's only about 2" wider than that JBL. If you think that it would work out decently with my Cambridge S30s, I might just have to jump on it. biggrin.gif
Old 05-07-2014, 08:39 PM - Thread Starter
JimWilson's Avatar
Liked: 1720
I would contend otherwise myself; a properly configured and tuned subwoofer shouldn't dominate the S30's. While I've never heard them myself, I do have first hand experience with the SX-50 (which is probably not too different). I suspect the S30's would integrate with the SUB-1500 pretty well.
Old 05-07-2014, 09:19 PM
Bond 007's Avatar
Liked: 1940
I agree with Jim about the 1500 and S30s. If you can only get 1 sub get the 1500.
And then another 1500 later.
Licence to Kill
Old 05-08-2014, 04:30 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1321
Based on your stipulations, that seems to be what you are going for... A small room with a sub in nearfield probably means you don't have space for a giant ported behemoth. Also to get "good extension and accuracy" you need to have a capable sub. $500 is the starting point for good bass in my opinion, and that SB-1000 recommendation is excellent. Usually you can get a B-stock one for $450, but even at $500 new it is an excellent sub. It also has an 80Hz high-pass filter so you can integrate it well without a receiver.
The HSU VTF-1 MK2 is another good choice, it will have higher output being ported, and likely better low end output, but with shipping it comes to $500. The nice thing is you get some more tuning options with it, and using the port plugs, you can cater the bass to your liking. It doesn't have a high pass filter but the crossover slope is steeper making it pretty effective.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 05-08-2014, 07:08 AM
cel4145's Avatar
Liked: 2995
I'd probably go for the PB-1000 over the VTF-1 MK2 for a ported sub. I've heard that those $40 crossover filters can be kind of crappy. I don't think I'd want to use them as high pass filters.
cel4145 is offline
Old 05-08-2014, 11:05 AM
phillyd32's Avatar
Quoted: 36 Post(s)
Thanks for the suggestion, I think if I had more knowledge about my tastes in bass, or if I was using it for more things than music, this would be a better option than the SVS.
Thanks for all of the suggestions everyone! +thumbs up.
Old 05-08-2014, 01:21 PM
smurph98gt's Avatar
Dayton SUB-1500 ordered! Should be here next week!!
Thanks for the input guys, I can't wait to hook this bad boy up!
Old 05-08-2014, 01:47 PM
Bond 007's Avatar
Liked: 1940
Congrats! Let us know what you think.
Licence to Kill
