Klipsch RW 12d front cover vibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-26-2012, 06:54 PM - Thread Starter
Kirk M's Avatar
Hello
I purchased a brand new Klipsch RW 12d subwoofer on sale for only $299.99 The sub is great and shakes things up when playing music and movies. However, there is a slight vibration noise coming from the hard plastic cover directly under the speaker and grill. This is the plastic molding that holds the Klipsch emblem. It only vibrates/crackles at certain frequencies.
I have noticed if I push in or up on the plastic the vibration goes away. I'm guessing that this plastic cover is for cosmetic purposes.
Has anyone ever removed this cover before? I was thinking about re-seating it so see if that helped. I could return it, but it seems like a very small issue that could happen again on a replacement.
any comments will be much appreciated.
Kirk M is offline
post #2 of 3 Old 02-26-2012, 06:59 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
I believe I saw in the Klipsch forums where someone had shoved a piece of folded paper behind it to stop it.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 3 Old 02-26-2012, 08:02 PM
tvuong's Avatar
Quoted: 1554 Post(s)
Liked: 885
Originally Posted by Kirk M View Post
Hello
It is the subwoofer port (not cosmetic) that vibrates. You can stick your hand inside this port. Lots of folks having this same proplem. Some had successfully glue it back and tight.
tvuong is offline
