Could someone explain these graphs to me please? SVS Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 03-04-2012, 11:04 PM - Thread Starter
raehza's Avatar
I have a PB12-NSD.
I am considering my choice for a future upgrade and I am looking at the PB12 Plus and PB13 Ultra.
I read the reviews on all 3 on the Audioholic website but have a question about their graphs.
PB12-NSD :
PB12-Plus Scroll down to the CEA readings
http://www.audioholics.com/reviews/s...2-measurements
PB13-Ultra
http://www.audioholics.com/reviews/s...iew_fullscreen
What I gather from this is that the Ultra is obviously louder than the PB12-NSD and only a slight amount louder than the PB12-Plus (probably not even really noticeably louder, I may be wrong). Am I correct with this assumption?
If that's it, I just can't fathom why the PB12-Plus is about $600,- more and the PB13 around $1200,-. The Plus has a driver the same size as the NSD.
I for example want a bigger sub soon because I want to feel the bass more and the rumble. How is it even remotely viable to spend nearly double the money on a Subwoofer that is marginally louder and has the same size driver (PB12-Plus) or 1 inch larger (Ultra).
How is it even possible to produce power POWERFUL base and not just louder base.
What I am trying to find out is if A) I understand the graphs correctly and B) If I am correct with my assumption that a same size driver can't possibly make that much of a difference in output.
Ray
Projector: AE7000
Screen: 5x12 Wilson Art Laminate Designer White
Receiver: Denon 2112Ci
Fronts: DefTech 8020ST
Center: DefTech 8040HD
Side Surround: DefTech SR 8040 BPs
Rear Surround: DefTech PM 1000s
Subwoofers: 2x HSU VTF 15H's
raehza is offline
post #2 of 30 Old 03-04-2012, 11:22 PM
omegaslast's Avatar
If you dont think 3db is noticeably louder then you may be deaf
Whats your current sub... get two PB12NSD and then put them in different corners of the room. Dont just buy one big sub and expect it to sound great no matter where you sit (it wont)
omegaslast is offline
post #3 of 30 Old 03-04-2012, 11:27 PM - Thread Starter
raehza's Avatar
Ok, fine. 3 db is noticeably louder, but at what volume level? Is that at 0 Decibels (reference level)?
I understand that everyone priorities are different and certain amounts of money matter differently to different people, but all these things aside, if $600,- buys you 3 db more, that would be quiet funny.
Ray
EDIT: Omega, just saw you edited your post a bit. My concern is that I would want a sub that pumps more air and hits harder. I can't imagine that a PB12-Plus or even a PB13 Ultra can be worth that much money more for just being louder alone. The drivers are all about the same size with the 13 being an inch bigger. At the end of the day, a driver can only pump as much as its physically capable, no?
On the other hand, I used to have BIC F12 which also has a 12 inch driver and my PB12-NSD is destroying the BIC in terms of output. I don't see what can possibly make such a difference in driver quality. They both have their physical limitations of being 12 inch subs.
Projector: AE7000
raehza is offline
post #4 of 30 Old 03-04-2012, 11:31 PM
omegaslast's Avatar
Ray
Doubling cone area and keeping power levels the same gets you 3db
doubling power and doubling cone area gets you 6db
You can read this forum and gather a lot of info, or maybe the DIY forum
My advice is not to buy SVS at all, buy two rythmik FV15HP and you will probably never need to buy a sub again
post #5 of 30 Old 03-04-2012, 11:32 PM
omegaslast's Avatar
Ray
Displacement is measured in liters
sd (cone area) x xmax x (2/1000)
Good luck getting those parameters from retail subwoofer manufacturers.
post #6 of 30 Old 03-04-2012, 11:33 PM - Thread Starter
raehza's Avatar
If it were for me, I would get the Rhythmiks or even better Submersives or if crazy enough the Captivators, but I have a SVS sub and I have 1 year to upgrade with them. Otherwise I'd have to sell the PB12-NSD and I don't know how much I would be able to get for it.....
Projector: AE7000
raehza is offline
post #7 of 30 Old 03-04-2012, 11:41 PM
ironhead1230's Avatar
Liked: 48
I have a PB12-NSD.
PB12-NSD :
PB13-Ultra
Ray
Don't forget, the PB12-nsd and ultra were tested by Josh Ricci and the PB12-plus was tested by Paul Apollino. They tested with different equipment at different locations so their results could be different by a couple of db. I would probably just assume the PB12-plus is between the results of the nsd and ultra, measured by Ricci. Whether or not the performance difference is worth it is a personal decision. Remember, while a 3db increase may not seem like a lot, it is not easy to accomplish. Doubling amp power results in a max increase of 3db and an increase of 3db requires twice the cone excursion.
Just because two drivers are the same diameter, does not mean their performance will be anywhere near the same. Just look at the pictures and description on the SVS site of the nsd and plus drivers. The plus driver has a larger motor, voice coil, dual spiders and more excursion. All of that can result in large difference in performance. The ultra driver is not only larger in diameter, but also has a more linear motor, better voice coil and probably more excursion.
-Mike
ironhead1230 is offline
post #8 of 30 Old 03-04-2012, 11:41 PM
omegaslast's Avatar
Getting one big bad subwoofer doesnt do much, it leaves you with a bunch of peaks and nulls in your sub response that sound bad. I used to believe that its better just to have one really good sub than two or more good ones, but once you have two subs you will realize how foolish that sounds.
As i said above, when you add another 12NSD its like adding 6db to those numbers, which is a lot. However, you also get the added benefit of smoothing out peaks and nulls, which is a plus.
post #9 of 30 Old 03-04-2012, 11:46 PM - Thread Starter
raehza's Avatar
Thanks for the responses so far.
I don't know whether I should spend nearly 2 grand for 2 PB12-NSDs or 1x PB13 Ultra if my goal is to have more powerful bass instead of just louder bass....
Ray
Projector: AE7000
raehza is offline
post #10 of 30 Old 03-04-2012, 11:52 PM
omegaslast's Avatar
Ray
These words dont make sense, powerful and loud describe the same thing.. perhaps you mean you want bass that has more extension?
Just because svs has an upgrade policy doesnt necessarily mean you should use it. I think the FV15HP performs better than the 12-plus, so buy that, put it in 1 port mode, be happy with a little more extension, and keep the NSD. problem solved
post #11 of 30 Old 03-04-2012, 11:56 PM
Liked: 48
This really depends on the room and if you want a smoother response across multiple seats. I have a fairly smooth response at the main LP with just a single sub and no room treatments. However, for full disclosure, I am planning on getting a second sub to even out the response throughout the entire room.
Again this is very room and location dependent. See here.
-Mike
post #12 of 30 Old 03-05-2012, 06:20 AM
oztech's Avatar
Liked: 101
Ray
Maybe you should call SVS and see what they recommend for what you expect the Ultra will no doubt beat the NSD in every way both extension and output not to mention weight and size of the box if you have the budget I doubt you would regret it after all it is a top notch sub in any book.
oztech is offline
post #13 of 30 Old 03-05-2012, 06:31 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Driver size is just one factor. Compare the weights and size of the enclosure which adds to the production cost and shipping cost.
qguy is offline
post #14 of 30 Old 03-05-2012, 06:39 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
I have a PB12-NSD.
PB12-NSD :
PB13-Ultra
Ray
If you look at the testing you maynotice that max output is not the only thing tested. WHile the PB12 is impressive, the PB13 retains its native frequency response much louder. While at some point the PB12 simply stops getting louder below 30 Hz, while higher frequencies goe up with increased input, the PB13 does not compress until 110 dB in the deep bass, which with room gain is likely to let you play at reference without any compression at all.
JHAz is offline
post #15 of 30 Old 03-05-2012, 07:16 AM
SaviorMachine's Avatar
Liked: 90
The Plus and Ultra also use more advanced amplifier electronics than the NSD, and they have variable tuning modes that allow them to descend comfortably to much deeper extension (per AH measurements, in 15Hz mode, the PB13-Ultra can push almost 90dB at 12.5Hz, outdoors). Their drivers are also simply *better* than the NSD, so their sound quality is likely notably better (they produce less harmonic distortion and exhibit substantially less group delay, two easily measured values that directly relate to the quality of a subwoofer's sound). In other words, output isn't everything. If I had money to burn, I'd definitely trade my PC12-NSD up to the PC12-Plus to get the deeper extension, output control features and better driver; I wouldn't be inclined to run it any louder, though.
Moreover, in the links you added to the original post, the PB13-Ultra's numbers in 15Hz mode are being compared to the PB12-Plus' 20Hz mode. The proper comparison between the two subs is when they are in matching modes, 15Hz vs 15Hz, and 20Hz vs 20Hz. Audioholics' PB12-Plus review didn't include any mode other than 20Hz mode, so here's the fairer comparison:
PB12-Plus in 20Hz mode (you want to see the "RMS @ 2 meter" column)
PB13-Ultra in 20Hz mode
In the challenging places of the spectrum (everywhere under 40Hz) the Ultra is at least 3dB louder. Yes, that's a highly audible and tangible difference at these output levels.
It's also worth noting, as others have, that the enclosure itself and larger driver assembly add significantly to the costs of both manufacture and shipment. Personally, I prefer the cylinder versions of all the SVSound subs--comparing price to performance, in my opinion they offer a better value, and I can move them without having to radio for backup.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #16 of 30 Old 03-05-2012, 07:20 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You also need to keep in mind that the above measurements are done outdoords with no room gain factored. It is possible to get another 6db based on room gain alone, but as others mentioned, it comes down to your room and what you are trying to do.
ack_bk is offline
post #17 of 30 Old 03-05-2012, 07:22 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
No one has asked this yet: how big is your room? The room can affect the in-room response more than anything, so if your room is gigantic I could see why you'd be wanting more.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #18 of 30 Old 03-05-2012, 07:25 AM
Liked: 90
My understanding is that it's hard to get both of those at the same time. Co-location of two identical subs can yield up to +6dB in a room, but it doesn't do anything to solve the peaks-and-nulls problem; distribution across a room can do a lot to solve the peaks-and-nulls problem, but then the maximum output increase tends more toward +3dB.
post #19 of 30 Old 03-05-2012, 07:48 AM
Archaea's Avatar
Quoted: 2844 Post(s)
Liked: 2427
Care to try out your theory?
How about one of my captivators against two of your rythmiks?
You pick optimal placement for your pair and I just drop one cap in one of your two places for the comparison.
I would typically agree with you that 2 subs are usually better than 1, but if that 1 is in such a different class - the story changes dramatically.
Because I can't find an equivalent excursion video for the caps, and I'm not sure I want to do this to my own drivers - - -
Check out the excursion video linked here on the Elemental Designs 13av2 driver
That ED driver is is rated for 28.5mm xmax each way
The Captivator driver is rated for 30mm xmax each way
With that 30mm of xmax you can do things like this -
YET, you can still keep excellent sound quality at typical and even crazy listening levels as evidenced by the fact the Caps place at or near the top in listening auditions at all the subwoofer meets.
The other thing to keep in mind is that every 3dB is 50% more spl, every 6dB is a doubling of spl. So since the scale is doubling - as you approach the thresholds of human 'pain' levels 50% more spl is a WHOLE lot more noticeable.
This scaling factor is why if a woman screams at 125dB, two women don't scream at 250dB (250dB is the spl of an atomic bomb - - http://www.makeitlouder.com/Decibel%20Level%20Chart.txt) -- rather two women together might hit ~128 dB - unless they are co-located - but that kind of topic belongs to another forum.
As to why the BIC F12 didn't compete with the SVS -- I'd wager it got close in SPL levels, but that SPL level's high water mark on the BIC F12 is not flat in regards to frequency response. My friend has a couple BIC V1220 subs (pretty equivalent to the BIC F12) and they hit 121dB in his room peaks, but that 121dB peak sounds a lot different than my Captivator pair at 121dB, because the BIC's fall off hard at about 33hz and produce basically nothing at 20hz. The 50hz - 70hz sound that the BIC's produce in abundance, is the type of bass you feel in your body, chest etc. The 15-25hz bass is the type of bass you feel in your chair, your house, your walls, your floor, and the eerie sensation that makes you involuntarily grin ear to ear.
Archaea is online now
post #20 of 30 Old 03-05-2012, 08:21 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I actually found the opposite to be true for me. I preferred the one big bad sub to two lesser ones. It was actually a noticeable difference. I can always add a second big bad sub down the road
ack_bk is offline
post #21 of 30 Old 03-05-2012, 08:22 AM - Thread Starter
raehza's Avatar
Woah, thanks for the input.
My SUb will soon be placed into the Basement. The Basement is about 4000 - 4500 cf. So rather large. Has doors that lead into smaller rooms that have our boilers etc in it. The room is tiled and no room treatment at all except the little corner I'll be using for my home theater. That part has a thing carpet laying there.
So yea, 1 PB12-NSD will have a hard time giving me the wow factor. Question is whether I get more rumble and thunder from 1 PB12-Plus or Ultra or 2x PB12-NSD's.
Loud = the amount of Bass? Sorry that this may sound stupid but I never thought that was the case. My old BIC F12 would get VERY loud too, to the point where Audyssey kept throttling it down but in no way shape or form would it shake the room like the PB12-NSD is doing right now. I don't think loudness = pressure power/rumble/ or w/e you'd call this.
Ray
Projector: AE7000
raehza is offline
post #22 of 30 Old 03-05-2012, 08:31 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
That's because its frequency response curve is far from flat. Check out the BIC F12's big brother, the PL-200 in this table. See how it's 14db higher at 50hz from 25hz? So at a given volume setting on your receiver, the loudness for the BIC F12 will be coming from the upper bass range, and the lower bass range has relatively low output in comparison--which is where the room shaking effects are coming from. And Audyssey can't adjust for that much difference in response to flatten the curve. Whereas your SVS (scroll down the table) will potentially put out much more solidly across the frequency range.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #23 of 30 Old 03-05-2012, 08:39 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
My advice would be to call SVS and discuss your room and needs as well. If you have the budget, I would say get the Ultra and don't look back.
ack_bk is offline
post #24 of 30 Old 03-05-2012, 09:23 AM
MikeBiker's Avatar
Quoted: 12 Post(s)
That is the philosophy that I am following. I bought the best sub that my budget allowed and I will be adding another equivalent sub when my budget again allows me to do so. I have no complaints about the sound I am getting from the one sub now and I'm sure that adding another will make things even better.
MikeBiker is offline
post #25 of 30 Old 03-05-2012, 09:26 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I am considering the HSU Mid bass module with nearfield placement. That combined with the VTF-15H seem like a really powerful combo of my large room.
ack_bk is offline
post #26 of 30 Old 03-06-2012, 04:47 AM
omegaslast's Avatar
Got any graphs of one captivator running? Feel free to EQ it too, though the OP probably isnt going to go that far. Captivator is one of the few subs id feel safe EQing because i trust the amp to have gobs of power (although its already DSPed... which leads me to believe i might be double boosting). When you boost your nulls by +3db the amp better have the headroom, because if you push it to reference and the amp starts clipping you just ruined the movie for yourself.
I dont have any rythmiks, i am a DIY guy. For $2500 (the cost of ONE captivator) i could have two RE XXX18, an LG clone amp, and have far more extension than two captivators could ever hope to have (the RE XXX almost doubles your xmax, and id have two of them), plus far smoother room response.
post #27 of 30 Old 03-06-2012, 04:51 AM
omegaslast's Avatar
Do you have a picture of your bass FR?
Of course a bigger sub will probably provide more extension and it will provide more output, the question is how many nulls/peaks do you have unaddressed in your room. I dont like having one 40hz explosion go off with a whimper because its in a null, and another 60hz one rattle all my doors because its in a peak, it leads to an inconsistent bass experience.
post #28 of 30 Old 03-06-2012, 06:48 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Ray
I agree with ack_bk: Call SVS and discuss your situation with them. A second NSD will certainly give you more headroom and rumble (more envelopment too), but the PB12-PLUS or PB13-ULTRA will most definitely give you that extra punch and shaking that you're looking for. The Rythmik FV15HP is also something you should consider.
Nuance is offline
post #29 of 30 Old 03-06-2012, 07:32 AM
Archaea's Avatar
Liked: 2427
RE XXX 18 looks to be a $1000 dollar driver --- are we talking about the same thing? Throw a clone amp on there you are up to $2800, buy a couple cabs and you are up to low mid $3000 range.
http://www.woofersetc.com/p-4922-xxx...subwoofer.aspx
Suddenly we are at the same pricepoint since I have the Cap Pro Pair (passive) and an inexpensive amp. (The passive cap pro has the same driver as the powered cap) I chose the passive because I don't think the powered caps need 4,000 watts each (2011 model) and I'm a budget conscious shopper. The passive caps sell for $1500 each, but if you peek into JTR Forums you'll see he offers a slight discount for multiples and on occasion has a sale or two (year end, overstock, etc) At any rate the cap at this price with a mated cab made of birch wood is the best deal going for the non DIY'er.
I'll leave it to others with more knowledge to tell me if the RE XXX18 is a better driver than the LMS-5400. I was under the impression that the LMS-5400 is about the best driver there is for DIY, and from everything I've read the Captivator driver gives up very little in both performance and sound quality to the LMS-5400. One guy who owned both a sealed LMS-5400 setup and a Captivator setup in the captivator thread said he could take either or and wouldn't care - where the LMS had a bit more at the bottom end, the captivator had a bit more at the top end. Apparently nothing in the two driver's differences was very vast. It looks like the rms watts on the XXX18 is 2000 and the Cap driver is 4000. Watts aren't much of a judge of a subwoofer, but it does show the Cap driver is capable. The RE 18 XXX does quote some crazy xmax numbers --- 54mm of xmax each way? The cap only has 30mm each way - which is still phenominal and the same as the LMS-5400. The cap has gathered many comments in the three subwoofer shootouts I've been at for very strong accuracy! I wonder how that XXX 18 driver rates in that arena? Just out of curiousity I'd gladly put the caps up against a DIY project like you recommend -- I have no qualm about hearing a better sub - so far though, IMO - I haven't.
I don't have any graphs of just one (since I have two), but I easily could make one and with the DSP built into one of my Inuke amps I could make that single Captivator response flatter than a pancake in the main listening area --- and have done so with my pair! Here are some links for reference.
My first play throughs with the Inuke amp's DSP - including parametric EQ setting screenprints. -- no smoothing.
http://www.avsforum.com/avs-vb/showt...4#post21301454
20hz vs. 15hz tune
http://www.avsforum.com/avs-vb/showt...0#post21372760
Inuke vs. EP4000 on cap pro pair.
http://www.avsforum.com/avs-vb/showthread.php?t=1375633
As far as "clipping" running my experience - not with the INuke DSP3000 at least - It shut off and powere cycled due to overload on three occassions during the 2012 KC Blind meet and nobody heard any bad noises - the only comment were things like "strange lack of bass on the Black Hawk Down Clip" etc - precisously when the amp turned off. I believe this is because the cap drivers are rated for 7,200 watt peak and even at full clip/short the INuke amp can't produce that much power, so the Inuke is incapable of making the caps make a bad noise even at full clip/short/protect mode.
I'm currently playing with a Crown XLS 5000 amp and the mic2200 again. It's a beasty amp, I wish I could use the Inuke DSP on the XLS amp.
At any rate - I'll leave this thread be, as it's about SVS products. They make good products. I've been the prior owner of a couple SVS PB13 Ultras and enjoyed them before I upgraded to the captivator pros -- Ill leave it at that.
post #30 of 30 Old 03-06-2012, 09:13 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Sorry don't have them. What I did do was place both lesser subs in as many optimal places as I could and use Audyssey and an SPL meter. The problem was the size of my room (think 5K cubic sq ft when you factor in the open adjoining room and hallways). The only time I could get close to what I wanted was when the eD A2-300 was nearfield. Unfortunately, a big black ugly box with a bedliner finish is not going to pass the WAF test so I had to move it to either the back wall or side wall. The PA-150 was corner loaded on the front wall in the sweet spot (subcrawl) of my basement. The PA-150 is actually a very capable sub in the 50-80hz range, but starts runs out of steam quickly. The A2-300, even in the sweet spot, just was overwhelmed by the room. I tried placing the two subs in about 6 different locations total, but it became immediately apparent as soon as I hooked up the HSU VTF-15H in the sweet spot with a couple different Audyssey sweeps that it was what my room needed. I have since added the PA-150 back into the mix but not sure I will keep it, but I would take one VTF-15H vs the two lesser subs 10 times out of 10. It was a very big improvement in LFE for movies which is what I use my room for.
I would love to add a second VTF-15H down the road.
ack_bk is offline
