Axiom EP800 vs. SVS Ultra 13 vs HSU Quad drive - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 28 Old 03-07-2012, 07:30 PM - Thread Starter
stump4545's Avatar
which of these (3) subs would be best for movies?
i know this is subjective but which of these 3 sub would you pick up?
thanks for the opinions.
stump4545 is offline
post #2 of 28 Old 03-07-2012, 07:34 PM
MKtheater's Avatar
Quoted: 1757 Post(s)
Liked: 1349
You do realize that HSU quad driver means 4 subs?
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #3 of 28 Old 03-07-2012, 07:45 PM
Stylz25's Avatar
My friend has the Axiom EP800 and it's a great sub but the one problem with it is that it's not very dynamic and sometimes it takes a lot to activate the sub! Hard to explain but its true! I would go with the HSU sub!!
I'm trying to pick between the HSU VTF-15H or the Rythmik FV15?? Which one??? Argh!!!!! Lol
Stylz25 is offline
post #4 of 28 Old 03-07-2012, 08:07 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
4 HSU ULS subs!
ack_bk is offline
post #5 of 28 Old 03-07-2012, 09:18 PM
drewTT's Avatar
Quoted: 822 Post(s)
Liked: 831
Anything but axiom.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | Apple TV 4K
drewTT is offline
post #6 of 28 Old 03-07-2012, 11:52 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
Lol, this is a no-brainer, get a quad-drive!
shadyJ is offline
post #7 of 28 Old 03-08-2012, 04:37 AM - Thread Starter
stump4545's Avatar
wow, i thought i would get a lot SVS votes!
how about a custom built Salk sub with primo quality components and drivers, does HSU quad drive sub still get the vote?
post #8 of 28 Old 03-08-2012, 04:50 AM
gtpsuper24's Avatar
Liked: 100
The quad driver is recommended because he will have a very smooth freq response across all the seats and in the room, because its 4 subwoofers and not one. A really good single subwoofer will nulls and peaks, while some seats will get boomy bass others may not get much bass at all. The HSU quad drive fixes that, 1 sub on each wall.
gtpsuper24 is offline
post #9 of 28 Old 03-08-2012, 04:50 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #10 of 28 Old 03-08-2012, 04:57 AM
Kimwyn's Avatar
do you realise you are putting up 4 subs (HSU quad drive) against single sub options???? and its not even 4 "average" subs, they are very good subs.
Kimwyn is offline
post #11 of 28 Old 03-08-2012, 05:54 AM
jhan1000's Avatar
I also would go with the Hsu quad drive.
Life is good.
jhan1000 is offline
post #12 of 28 Old 03-08-2012, 06:10 AM
flickhtguru's Avatar
Liked: 111
Now if you asked about 2 - SVS PB13 Ultra compared to HSU USL15 Quad Drive your answers may be different.
IMO go for at least dual subs no matter what you decide on.
Shawn
flickhtguru is offline
post #13 of 28 Old 03-08-2012, 06:45 AM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
OP, how large is your room?
ack_bk is offline
post #14 of 28 Old 03-08-2012, 06:53 AM - Thread Starter
stump4545's Avatar
my room is about 20x15x20 with high ceilings and an open back wall to the other rooms in the house. it is not a dedicated sealed ht room so that is why i am looking for a powerful sub and i would get (2) units for sure i think.
maybe (2) quads then.
the hsu quad is not cheap at $4k.
would i be getting more bang for my buck and more performance buying a used name brand sub (like a JL or Rel) for $4k that sells new for about $8k?
2 hsu quads vs 2 used JL F212's?
post #15 of 28 Old 03-08-2012, 07:01 AM
carp's Avatar
Quoted: 2880 Post(s)
Liked: 2168
If you are willing to go over 2 grand I would look at the JTR Captivator or Seaton Submersive. Actually you could get a passive Captivator and amp for under 2 grand.
If you are set on duals and don't want to go much over 2 grand forget that idea.
carp is online now
post #16 of 28 Old 03-08-2012, 07:08 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
You are totally confused.
The HSU Quad Drive is not a SINGLE sub, it's FOUR separate ULS-15 subs sold together. Each ULS-15 is a SINGLE 15" sub
If you bought 2 Hsu Quads, you will be receiving 8 separate subs (in 8 separate boxes)
Look at this post. This has a picture of the Quad Drive. The FOUR black boxes is the quad drive http://www.hometheatershack.com/foru...tml#post180860
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #17 of 28 Old 03-08-2012, 07:09 AM
ratm's Avatar
Quoted: 41 Post(s)
Liked: 39
+1 ^^^^^^^
You either did zero homework, or have a crapload of money to throw away.
ratm is offline
post #18 of 28 Old 03-08-2012, 07:30 AM
oztech's Avatar
Liked: 101
I have to admit some dark side of me would love to hear 8 of those .
oztech is offline
post #19 of 28 Old 03-08-2012, 07:35 AM
shadyJ's Avatar
Liked: 1352
You would have to set them up carefully to avoid cancellation problems. That would be great though, an octo-drive!
shadyJ is offline
post #20 of 28 Old 03-08-2012, 07:40 AM - Thread Starter
stump4545's Avatar
ohhh... my fault.
so let me rephrase:
svs ultra 13 vs axiom ep800 vs. custom Salk Audio sub built with primo driver and parts vs used name brand sub like JL audio F212's?
either way i will buy (2) subs for my large room?
post #21 of 28 Old 03-08-2012, 08:08 AM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
ohhh... my fault.
so let me rephrase:
Let's try this. What is your budget?
2 SVS 13 Ultras will run you close to $4k.
If you have $4K and want multiple subs, I agree with Carp. You should be looking at the JTR Captivator and Seaton Submerssive. Those would be at the very top of my list.
ack_bk is offline
post #22 of 28 Old 03-08-2012, 08:15 AM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Hey Warp, I have been in that room and heard that system.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #23 of 28 Old 03-08-2012, 08:57 AM
Aus1095's Avatar
Originally Posted by ratm View Post
+1 ^^^^^^^
I wish I had money to throw a way....
Quad hsu but you should get caps they would be the best!
Aus1095 is offline
post #24 of 28 Old 03-08-2012, 09:57 AM - Thread Starter
stump4545's Avatar
so would id still be the way to go or should i be looking at buying used name brand speakers for most bang for buck?
jtr and seaton recommended over svs? really
i will check them out.
thanks for the leeds.
post #25 of 28 Old 03-08-2012, 10:07 AM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
Possibly worth considering: dual ChaseHT VS-18.1 subs:
- two ported 18" passive enclosures @ $845/ea., shipped
- Dayton Audio SA1000* @ $400 (I think the amp - which delivers 475W to each sub - gets shipped free w/ the enclosures)
(*You can purchase the Dayton or use your own sub amp.)
There's good buzz on those subs both on this forum site and on the CHT forum site.
Just my 2¢...
ereed likes this.
eljaycanuck is offline
post #26 of 28 Old 04-01-2012, 10:22 AM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
Being a former SvS Ultra owner and now a Seaton SubMersive owner.......SubMersive all the way!
Hmmm, how can I compare them...........If Bea Arthur is considered hot, the SubM would be like Megan Fox walking in the room!
Crabalocker is offline
post #27 of 28 Old 04-01-2012, 05:28 PM
capecodorthopod's Avatar
It looks like you're willing to spend enough to get you into a pair of Seaton Submersives or JTR Captivators. Both are legendary for their ability to cure the most refractory cases of upgraditis.
They are definitely on another level than the subs in the thread title (even though they range from respectable to excellent). Good luck.
Tim
capecodorthopod is offline
post #28 of 28 Old 04-04-2012, 07:30 PM
Bone215's Avatar
it is not fair......
deeper than the deepest ocean
Bone215 is offline
