Help me decide between PB12-nsd or VTF-3 MK4 - AVS Forum | Home Theater Discussions And Reviews
Old 03-11-2012, 02:23 PM - Thread Starter
Serolf's Avatar
I know there are several threads between these two but I still can't make up my mind. I'm currently only running two front towers and realize that I really need a subwoofer. Budget is no more than $800. Audioholics and other sites have very positive reviews on the pb12-nsd. I have'nt been able to find any reviews on the VTF-3 MK4 but I see that it is very well regarded in here and other sites. My living room is 11x12 with 9' ceiling and it opens to a hallway which is 7x13 with 12' ceiling. I guess my usage will be 50/50 music and movies. I would like a lot of earth shattering bass. Which will shake my living room shake the most?
Serolf is offline
Old 03-11-2012, 03:13 PM
oztech's Avatar
Liked: 101
They are close in price the PB is 66lbs. the VTF is 90lbs they are close dimensionally with the VTF being 3inches deeper and the PB uses one 4inch flared port the VTF uses
two 4inch flared ports. The PB uses a 400w amp the VTF uses a 350w amp with 1400w short term. The advertised extension is 18Hz for the PB and 16Hz for the VTF.
You can't go wrong with either while IMO you have more tuning options with the VTF.
oztech is offline
Old 03-11-2012, 03:33 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
If there's one or the other you're leaning toward, then get that one. Neither would be a bad choice, IMO. I've not heard the SVS, but it gets great props 'round these parts, and I'll vouch for the HSU. Big smiles.
You'll find lots of fans of both here, for good reason. Just don't 'settle' and then wonder 'what if....' . Better, and cheaper in the long run, to buy the right tool the first time.
Hope it helps
Joe
mods, can we have a 'dislike' button ?
wlhungdude is offline
Old 03-11-2012, 04:38 PM
warpdrive's Avatar
Liked: 48
Both subs should shake your room roughly equally, so like the above post, I advise just choosing based on other factors. The VTF does offer a few more options as far as configuration so that would allow you to tinker a bit more with its sound output.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
Old 03-12-2012, 05:35 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
In your circumstances, I would go with the VTF. I must admit to being pretty biased, being a VTF owner, but I think the VTF would have a substantial output advantage against the PB12. Take a look at Audioholic's subwoofer comparison tables, and compare the Outlaw LFM-1 EX with the measurements for the PB12 NSD. You'll see the Outlaw has a pretty large headroom lead over the PB12. The LFM-1 EX is basically the same as the VTF3, the difference is the VTF3 has deeper extension, less chances of chuffing, and more configurability. I think the PB12 would have less distortion at 20 hz, and stronger limiter protection, but I don't think these subs are equal in clean output capability as is often suggested.
shadyJ is offline
Old 03-12-2012, 05:54 AM
SaviorMachine's Avatar
Liked: 90
Shady raises a valid point; in two metrics (maximum output at most frequencies and group delay), the LFM-1 EX (let's just consider low extension mode) scores higher than the PB12-NSD, according to Audioholics' recent reviews.
On the other hand, they both have strong ouptput well below 20Hz, and the PB12-NSD performs at nearly all frequencies with lower distortion (at many frequencies, the PB12 produces half the harmonic distortion, or less than half) and better linearity (click the charts to return to the Measurements and Analysis page of each review). In fact the NSD's frequency response is something of an anomaly--there are more expensive, more powerful subs out there that don't really approach its flatness and most exceed its THD numbers (more THD is worse). As mentioned, the PB12-NSD's DSP limiter keeps it in check: it's very hard to bottom out the driver, or to overwork the amplifier, or to get it to misbehave in general; some people call it "bullet-proof." Plus, they give you a five year warranty on everything, amplifier included. This is not at all typical for internet direct subwoofers.
I'm biased too--I own the cylinder version of the NSD--so, predictably I argue that there's a lot more to a great sub than maximum output OP: you did ask which sub would provide the stronger response in your space, so the answer has got to be the VTF-3. I just want you to know that there's more to consider.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
Old 03-12-2012, 06:58 AM
Quoted: 46 Post(s)
Liked: 61
FWIW I was playing some dubstep at reference levels this weekend with my PC12-NSD with absolutely no distortion. I looked around and everyone in the room had a huge grin.. That little cylinder rocks in a small to medium room.
Mike
wmwilker is offline
Old 03-12-2012, 10:49 AM
shadyJ's Avatar
Liked: 1350
Lower distortion is always a good thing, but as long as its inaudible I would argue higher SPL counts for more. For the frequencies the subs cover, distortion would have to be enormously high just to be humanly detectable at all. Neither sub reaches this point until pushed to their operational limits at low frequencies. With the Outlaw sub specifically, I wonder how much port noise contributes to the distortion measurements. In the deep frequencies at high playback, it isn't too hard to induce port noise. The VTF3 itself needs much more of a push before the ports start hiccuping, and you need to be at crazy high volumes for that to occur.
shadyJ is offline
Old 03-12-2012, 10:58 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Both these subwoofers are so good at this price point that you could just flip a coin and be happy with whichever you chose by chance. Pay attention to the pros and cons mentioned by the posts above and use that to decide. Otherwise just ask the wife which is "prettier" and let her chose. They'll both rock in your room.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
Old 03-12-2012, 11:03 AM
spyboy's Avatar
Liked: 47
Getting back to the OP's original 2 choices, the PB-2NSD and the HSU VTF-3.4, I think the difference is in the variable tuning. Between these two subs, only the VTF-3.4 offers 16Hz tuning mode.
Who knows which tuning you might prefer, but only the VTF 3.4 offers the option of 16Hz tuning. The PB-12NSD is tuned to 20 Hz, IIRC. With its 4 inch ports the VTF-3.4 the 16Hz tuning option is actually quite viable.
spyboy is offline
Old 03-12-2012, 11:30 AM
Liked: 90
Hahaha. Wow.
To the OP: somebody above said that either of these subs will probably make you happy, and he's probably right. I just advise that you consider as many factors as possible before you fill out any order forms; also, keep your wits about you. This is a public forum, after all, from which you are seeking advice about competing products.
Old 03-12-2012, 12:01 PM
warpdrive's Avatar
Liked: 48
Both sub are comparably spec'ed, so in terms of output, they are in the same league. Arguing that one is hugely superior due to a few dB of output or ultra low distortion is like arguing whether your car gets to 60 in 4.5 or 4.8 seconds, it's not going to be a huge determining factor in the overall enjoyment of your sub, they are both very strong performers which outclass 98% of the competition
For other factors: I do like the Hsu's tuning feature and optional Rosenut finish, but at the same time, I like to see the driver moving in and out in a front facing sub, that's fun to me. Certainly the SVS also has really unbeatable written customer satisfaction policy (their "bill of rights") which may sway your decision as well
Old 03-12-2012, 12:06 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Can't really lose with this choice. I have owned both Hsu and SVS gear and customer service is top notch at both companies..
HSU gives you a few more tuning options, but if you don't care about that, then it should not be a factor.
ack_bk is offline
Old 03-12-2012, 12:08 PM
Liked: 90
+10
For other factors: I do like the Hsu's tuning feature and optional Rosenut finish, but at the same time, I like to see the driver moving in and out a front facing sub, that's fun to me. Certainly the SVS also has really unbeatable written customer satisfaction policy (their "bill of rights") which may sway your decision as well
Exactly. As for me, the cylinder form and light weight of the PC12-NSD made it a shoo-in. I'm a single man living in an apartment. I need all my floor space, I like a sexy-looking subwoofer, and I don't want no 90lb behemoth that'll make me pop a hernia whenever I want to switch up my living room. Since buying it I've switched up my living room at least three times. That's three hernias my PC12 saved me. I could have chosen an additional 3dB at an output range that I'll never reach... what? I like walking straight, thank you very much.
Old 03-12-2012, 01:32 PM
shadyJ's Avatar
Liked: 1350
I agree, higher harmonic distortion is a problem where lower harmonic distortion wouldn't be nearly as objectionable. If you look at Ricci's graphs, you'll see that both subs suffer from just a bit of fourth order harmonic distortion. I don't really know what that would sound like exactly, but I am familiar with the sound of the LFM-1 EX and I can say it sounds clean to very loud levels. I don't believe distortion is problem with any of these subs. The only odd noise I get from the Outlaw is chuffing, and I can only get that to happen in very deep bass played back at high levels. But that is not an issue with the VTF3.
shadyJ is offline
Old 03-12-2012, 03:16 PM
E-A-G-L-E-S's Avatar
Can't go wrong in my opinion. I chose between these two just a month ago. I chose the PB12 and cannot get it to make an unwanted sound in my room. If I had another $250 at the time I would have opted for the VTF-15H. I am very happy with what my $769 got me though.
E-A-G-L-E-S is offline
Hsu Vtf2 Mk4
