Captivator S2 vs Orbit Shifter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 158 Old 03-13-2012, 01:37 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
JTR just launched a dual 18inch sub, the cap s2... this is priced the same as the orbit shifter.
I wonder if anyone knows which will have more output?? The specs are not out yet.
This seems like a more 'house friendly' sub compared to the OS and if it's just as good as the OS, then it's a real nice option.
coolgeek is offline
post #2 of 158 Old 03-13-2012, 02:39 AM
mojomike's Avatar
Liked: 30
Orbit Shifter = greater output.
Cap2 = deeper.
mojomike is offline
post #3 of 158 Old 03-13-2012, 08:17 AM
carlm9's Avatar
I know one lucky SOB that will have both in their system this week, and no it is not me. I am waiting for my second powered Cap to come in, poor me.
carlm9 is offline
post #4 of 158 Old 03-13-2012, 09:03 AM
MKtheater's Avatar
Quoted: 1759 Post(s)
Liked: 1357
Assuming the drivers are similar this should be easy to answer, mojomike said it right. The OS will have more output from the horn tune on up and below it's tune or loading the OS will act similar to a single sealed Cap. Since this is a double 18 sealed cap it will have at least 6 dbs more from the below the horn loading. I am assuming this because the single CapS has more output down low than the OS. I bet the OS has about 3-4 dBs more with the horn loading or 25hz and above. This assumes the same driver and I know Jeff changed that 18 to fit better in a sealed environment. Of course I am estimating here.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is offline
post #5 of 158 Old 03-14-2012, 12:23 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Let's hope Jeff will post some numbers soon...
coolgeek is offline
post #6 of 158 Old 03-14-2012, 05:25 AM
kgb540's Avatar
Location: Left of the right coast and right of the left coast.
Cap2 = deeper.
That being said, they both go very deep and play very loud! I kind of like the fact that for the same price, with the Cap S2 you get the same amp but double the drivers as the Orbit Shifter. Seems like the better deal to me, ultimate SPL not withstanding.
kgb540 is offline
post #7 of 158 Old 03-14-2012, 06:19 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Exactly my thoughts. I am also thinking that even though the OS is horn loaded, 2 drivers will still be able to match it's spl at all frequencies, unless the drivers used is far inferior. Plus, maybe cleaner bass (being sealed).
Plus, the S2 is much more 'house-friendly'
coolgeek is offline
post #8 of 158 Old 03-14-2012, 07:44 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 58
I just wish money wasn't an object. A cap S2 would look very nice across from my SubM, unless they cancelled each other out.
bhazard is offline
post #9 of 158 Old 03-14-2012, 09:25 AM
mojomike's Avatar
Liked: 30
That I would not count on at all. Do not underestimate the efficiency gained by using a horn-loaded enclosure. For example, if we compare the efficiency of the OS (97db/watt) vs. the efficiency of the standard ported Cap (91db/watt), we see it would take two standard ported Caps to match the output of one OS if both used the same power.
The single driver CapS is going to be way less efficient than a standard ported Cap, meaning something less that 91 db/watt, probably much less around 20hz. When we double the drivers in the CapS2, we are still at something much less than 94db/watt efficiency compared with the OS at 97.
I'd expect the OS to excede the CapS2 in output at all frequencies, except perhaps the very deepest where the horn loses it's advantage.. As far as which would sound better, that's a whole 'nother question.
mojomike is offline
post #10 of 158 Old 03-14-2012, 10:56 AM
Jeff Permanian's Avatar
Quoted: 830 Post(s)
Liked: 1771
The Captivator S2 has about 6db more output capability below 20hz however the Orbit Shifter has about 6db more output capability above 20hz. The difference of 6db is the same as adding a secound subwoofer.
Jeff Permanian is online now
post #11 of 158 Old 03-14-2012, 11:31 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
What about sound quality? Which one sounds better? With less distortion?
I already have dual ULS 15.. which would complement them better
coolgeek is offline
post #12 of 158 Old 03-14-2012, 11:42 AM
Quoted: 830 Post(s)
Liked: 1771
I'm sure you read the blind test results. All the JTR's were neck and neck as far as sound quality. Horns topically have less distortion.
post #13 of 158 Old 03-14-2012, 12:12 PM
MKtheater's Avatar
Liked: 1357
I was very close!
Marantz 7704
2 Outlaw 7140s
post #14 of 158 Old 03-14-2012, 05:17 PM
jedimastergrant's Avatar
Quoted: 665 Post(s)
Liked: 421
As far as the sound quality I would go with Jeff's comment that typically the horn has less distortion. You can read my subjective blind opinions on the KCGTG thread but I remember commenting that the sub did not seem to stand out and lend its own sound to the music or movie. I think that points to less distortion. And I think that we were not even close to the limits of that system and it was LOUD. Keep in mind when reading through the opinions that it was the last sub we listened to after a very long day so it took A LOT to impress us at that point. If you have the space for it and need to fill a large space and want ultra low distortion at insane SPL's I would be looking at the OS. The very very low frequency's were really really difficult for me to hear at the meet so I am not sure it is worth chasing 5 Hz.
jedimastergrant is online now
post #15 of 158 Old 03-14-2012, 07:57 PM
Sidewayz's Avatar
As opposed to chasing another 6db max above 20hz? In real world conditions I would think that the 5hz would be more of a factor day to day than the 6db you may be missing at max spl. What's the OS capable of, like 135db? If the Cap S2 can only muster a measly 129, I think the owner could still show his or her face in public when they regained conciousness . plus if the the owner vertically stands the Cap S2 it takes up a very minimal about of floor space even compared to the OS LFU. Either way, both are TREMENDOUS performers.
Sidewayz is offline
post #16 of 158 Old 03-14-2012, 08:33 PM
Quoted: 665 Post(s)
Liked: 421
Yeah, I am sure the Cap S2 has PLENTY of output. I should qualify my previous preference statement by saying IF I could not have it all and had to choose, I would make sure I had awesome 20Hz and up performance first. Has the OP given the cubic footage? Be sure to ask Jeff about integration with your existing subs.
post #17 of 158 Old 03-14-2012, 08:47 PM
steveklein's Avatar
i want to read more about the captivator s2 but can't seem to find any information on jtrspeakers.com about it.
steveklein is offline
post #18 of 158 Old 03-14-2012, 08:58 PM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
Jeff hasn't updated the products link with the Cap S or Cap S2 yet. There's a little info in the JTR forum
-Kevin
JVC DLA-X550R projector/GIK Acoustic room treatments
Screen Innovations Black Diamond Zero Edge 1.4 110" 16:9
Marantz AV7702mkii pre-pro/Wyred4Sound 5-channel amp
Oppo BDP-105
JTR 3TX LCRs/Single8 HT-LP surrounds/2 RA Gamma21 master/slave pairs
KevinH is offline
post #19 of 158 Old 03-15-2012, 08:31 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Hey, thanks for the input... it's great to hear from someone who's actually listened to the OS... But if I remembered correctly, you were listening to the Cap S not the S2 so that may be a factor as well.
This might be a dumb question: Why would a horn loaded sub be cleaner than a sealed sub? Logically wouldn't any speakers with ports create noise, even if it's a little? Also, if the OS is tuned to 20hz, would that mean that at 20hz, it's extra loud, but at other frequencies, it's not as loud? Wouldn't that mean it's not a flat response?
Actually I am not looking at 5hz, but more like down to 10hz like my USL does. Subs that goes down to 10hz will give you a deeper feel (depth)... And this translates to 'a great feeling' to both music and movies.
BTW: 6db is quite a lot. This would mean in order to get that in the S2, you would need 2 of them. This may be what i need to give me that kick in the chest feeling when watching explosions in movies.
Oh, can anyone take a wild guess as to how many Epik Empires (each with dual 15 inch drivers) to equate the output of the OS?
coolgeek is offline
post #20 of 158 Old 03-15-2012, 09:36 AM
carp's Avatar
Quoted: 2886 Post(s)
Liked: 2172
Oh boy, this is truly a wild guess.
I think it takes 2 SVS Ultras to = a Cap. 2 Powered Caps don't quite = an Orbit Shifter (according to Jeff The Caps would be close above 60 hz bit the OS's pull away below that) but let's say they are close enough.
So, it would take 4 Ultras to = an OS?!?! (boy, that doesn't seem right!!)
I'm guessing it would take 2 Empires to = an Ultra???
So 8 Empires = OS?
Just tell me to shut up, there is no way that's right...
carp is online now
post #21 of 158 Old 03-15-2012, 10:03 AM
mojomike's Avatar
Liked: 30
So 8 Empires = OS?
What makes it more difficult to compare this way is that some subs really excel at certain frequencies. For example, the Ultra is very strong around tuning, so in that area it has the output of two Empires there. However, one Empire will actually excede the output of one Ultra in the upper range from about 50hz and up making an exact ratio difficult to predict in the full range.
mojomike is offline
post #22 of 158 Old 03-15-2012, 10:10 AM
Sidewayz's Avatar
I realize that, but 129ish db is no joke either and neither of those figures (129 or 135) would essentially NEVER come into play in even the most extreme listening session and absolutely never down very very deep. if you listened to anything that loud for any amount of time over a quick "check it out" session, you are going to have major hearing problems which will render all your audio gear pointless.
I guess my point was any advantage the Cap S2 may have over the OS in the ability to play waaaaay down low would be more useful (to me anyhow) than the OS advantage over the Cap S2 in ever so important area of deafening yourself (which the Cap S2 can do quite well anyhow).
Plus, like I said, for the same price you get a smaller footprint, same 4K watt amp, and (2) high quality 18" drivers instead of (1) HQ driver, a larger footprint and more BB plywood. I know where my money would go.
Sidewayz is offline
post #23 of 158 Old 03-15-2012, 10:10 AM
carp's Avatar
Liked: 2172
Gotcha, makes sense.
That's what is impressing me so much with the Sumbersive so far, it seems to have both - big chest thump for music like the Empire, and tons of low freq output too like the Ultra. I'm not sure what it's weaknesses are.
carp is online now
post #24 of 158 Old 03-15-2012, 10:12 AM
carp's Avatar
Liked: 2172
Ahhh, but I love those quick "check it out" sessions!!
carp is online now
post #25 of 158 Old 03-15-2012, 10:16 AM
Sidewayz's Avatar
ahhh, but i love those quick "check it out" sessions!!
what? ........me too
Sidewayz is offline
post #26 of 158 Old 03-15-2012, 10:16 AM
mbw23air's Avatar
Quoted: 199 Post(s)
Liked: 170
It's weakness is that it sounds so good it makes you want to buy another....and another....and another....even though you probably don't need it.
I only have 1 and would like another but currently can't afford it.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #27 of 158 Old 03-15-2012, 10:44 AM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
I was about to say at least my the Empire excels where it matters most(based on where most music/movie frequencies resides)..............then I realized this is AVS
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #28 of 158 Old 03-15-2012, 11:03 AM - Thread Starter
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Great points! Now I am back to 'can't make up my mind about the 2' when I finally buy em.
I am thinking i can only afford 1 of them. Say, if I bought the S2, and then realize I don't get enough chest thumping, I may be disappointed. But if I got the OS, then don't get enough low freq, I may also be disappointed! Hrumph!!
coolgeek is offline
post #29 of 158 Old 03-15-2012, 11:16 AM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2717
You won't dissappinted about not getting the low frequencies with the orbit shifter. To think so is avs nonsense. Nobody could even tell in our blind test which sub was ported or sealed and the ported subs were set at 15 and 16hz and we demoed the most prestigious ulf demo material currently known with some of the best sealed and ported commercial/ID products that you can purchase.
The orbit shifter has solid fr down to 9 or 10hz right? A full half octave to octave below what you can actually hear.
I think you can safely put that fear of missing something to rest.
Archaea is offline
post #30 of 158 Old 03-15-2012, 11:16 AM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
I definitely wouldn't over think it. You are going to get major chest thump and great low frequency with either of those two products. I know it's hard not to hem and haw back and forth.....it's exciting. And you'll even wonder "what if" whichever way you end up going. But with either of those two products?..........fugetaboutit!........both will give you want you want in spades.
-Kevin
Oppo BDP-105
KevinH is offline
