Just got my SVS SB12-NSD sub today, my thoughts so far... - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 88 Old 03-22-2012, 02:20 PM
rydogg_sc2's Avatar
Saying a PB or PC12-NSD is for smaller rooms is laughable and uninformed. That Audioholics review has it large room certified for 3000-5000 cubic feet. Some people need to put other products down to feel better about their own purchases. Sad...
rydogg_sc2 is offline
post #62 of 88 Old 03-22-2012, 02:47 PM
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
It has nothing to do with that mate. Many people will be happy with a sony subwoofer while others need a svs, hsu, you name it.
Same thing with room size and performance. Many will be happy with it in such a big room and other will need duals or a Captivator or who knows. You cannot just say one random number because it does not apply to everyone.
There is no right or wrong here, just different requirements and needs.
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #63 of 88 Old 03-22-2012, 03:47 PM
rydogg_sc2's Avatar
My comment was not directed at you personally more the attitude that is somewhat prevalent around here and all over internet forums to be honest regardless of the subject.
I do think there is a certain level of definiteness that can be accepted. Someone saying they have a sealed 1500-2000 cubic foot room often gets the Submersive/Captivator or bust opinion thrown around when really it is going to be overkill for everyone except those who want to sustain hearing damage or anger their neighbors on purpose. Just because a piece of equipment can reach higher spl measurements at a given frequency does not make it the most appropriate tool for the job in all instances.
To play the devil's advocate if everyone's expectations are so different then the correct answer for every person is buy a bunch of them and keep your favorite. Spend as much money as you can afford to (even though that does not make sense frequently) and never look back.
post #64 of 88 Old 03-22-2012, 03:51 PM
Quoted: 94 Post(s)
Liked: 63
Agree
Go Pens!!!
Aguante Boca!!!
post #65 of 88 Old 03-22-2012, 04:36 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
SB12 is an excellent sub for what it is but not the ideal choice if you crave the deepest extension and slam for movies...
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #66 of 88 Old 03-22-2012, 06:30 PM
jchong's Avatar
Liked: 32
Actually I agree with that approach. Since many manufacturers have a trial period, it is possible to buy a bunch of subs and test them to find your favorite and return the rest. You might have to cover return shipping though.
Also agree with your second statement.
jchong is offline
post #67 of 88 Old 03-22-2012, 07:09 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Originally Posted by marc10 View Post
How would the svs SB-12nsd compare with the Rythmik F12SE in a small room? Would they both do a good job for movies and music?
Not sure how they would compare directly in the same room but I bet they would both do a fine job. I was very happy with the SB12 in a small room (mainly music) as well as Rythmiks for HT in a larger room (different model-E15). You probably can't go wrong either way.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #68 of 88 Old 03-23-2012, 09:04 PM - Thread Starter
avspace's Avatar
So I played around with my setup, dropped in some stands and 5.1 speaker setup, ran some calibrations, did some adjustments, then threw a lot of heavy LFE blurays to see what would happen. While the SB12 supplied bass, it just didn't quite slam as much as I wanted. For music, the SB12 is excellent, fast and responsive, runs circles around my old STF-2, very musical, but if you want slam for movies, there's only so much as a sealed sub can do apparently, unless you opt for the more expensive SB13 Plus or something like the HSU ULS-15, which I hear can really pull some deep output, according the numbers.
I suppose it was my fault that I'm in a position to return it, I really wanted to believe that a sealed sub would be enough in my room for my tastes, for some people the SB12 will be fine. After having a HSU STF-2 in my room and feeling pretty satisfied for over a year, I'm hoping a PB12 will take things up to a higher level with deeper output and even more slam with movies. I am at least glad that I had a chance to try out a sealed sub, and a fine sub at that.
So I decided for sure to get the PB12-NSD, I don't give a hoot if the box is big and unsightly, I just want my movies to slam and rattle the walls. I'm going to talk to SVS tomorrow about doing a return for my SB12 so I can order the PB12 instead.
BTW, one weird thing I noticed was that there is a subwoofer thump when a bluray switches into encoded surround playback. This sometimes happens 2 or 3 times during title intro. I never noticed this problem on my other Pioneer receiver, I don't know if its this new receiver(Pioneer 1121-K) or the sub, I checked the sub cable(Premium one from monoprice) its seems to be plugged in fine. What gives???
avspace is offline
post #69 of 88 Old 03-24-2012, 06:18 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Quick question. If i add a second sub ot should increase the dbs at ALL hz levels correct?
I am curious about adding another sb12
Brian Fineberg is offline
post #70 of 88 Old 03-24-2012, 11:54 AM
Auditor55's Avatar
What is it?
Auditor55 is offline
post #71 of 88 Old 03-24-2012, 12:11 PM
kesando's Avatar
Liked: 31
Originally Posted by Auditor55 View Post
What is it?
A small sealed sub that will work great for music in a small, mid size room or for both movies and music in a small sealed room.
kesando is offline
post #72 of 88 Old 03-24-2012, 12:15 PM
speavler's Avatar
Quoted: 12 Post(s)
Liked: 26
I finally got a chance to crank her up a little bit last evening. Being a CPA with 2 kids, by the time I get home this time of year, everyone is asleep and I'm limited to some quiet listening. I got to play about 4 tracks of Paul Simon's greatest hits cd - the 2nd cd with the Graceland era heavy bass lines. The output was more than enough for me. I actually dialed back the gain a couple of notches. My family room is 18X25X8, but it's a tri-level house that is pretty much completely open with high ceilings in the formal living and dining rooms.
What I think I'm missing right now is EQ and acoustic treatments. Regarding the EQ, i'm considering the antimode or possibly holding out for a used SVS EQ1. However, I do have a marantz av7005 i use for HT which has Audyssey XT. I'm wondering if i can route my preamp's 2nd line out through the av7005 and use its EQ for the sub for my 2 channel listening.
speavler is offline
post #73 of 88 Old 03-24-2012, 12:17 PM
Auditor55's Avatar
That's great.
post #74 of 88 Old 03-24-2012, 12:31 PM - Thread Starter
avspace's Avatar
That is correct, it should also even out the response of your sub in your room helping out with filling null voids and giving you a overall punchier sound, you may even get a slightly deeper output due to the combined db output. Having dual SB12's might actually be what I'm craving with movies, but my budget is only good for one sub right now and I'm opting for the PB12.
What is it?
SB12-NSD is a sealed sub from SVS, it is great with music and okay with movies, but if you want serious slam, you have to go ported with something like the PB12-NSD.
Yeah the music performance on this sub is excellent for 2 channel systems, it is clean, fast and responsive to little detailed changes. That is one thing that I will miss when I return it is how it sounds with music.
avspace is offline
post #75 of 88 Old 03-24-2012, 07:34 PM
kesando's Avatar
Liked: 31
I here you. Even my stacked dual SB12nsds cannot match the low end of my single PB12plus, yet they sound great together in my room. I wouldn't worry too much about losing music performance with the PB12nsd. It seems to have improved a bit from the older PB12nsds with the new driver and sledge amps. I suspect it will sound close down to its tuning point below where the SB12 can reach.
kesando is offline
post #76 of 88 Old 03-24-2012, 07:58 PM - Thread Starter
avspace's Avatar
I did my final head scratching about getting the PB12-NSD, I was checking out the HSU VTF-3.4 but the box and weight is just too huge to fit in my room, plus the added cost of shipping and taxes would make it more than the PB12. So PB12-NSD it is for sure.
Anyone have any bad experience from purchasing an SVS Outlet special? I've never been one to buy outlet specials(or b stock) as I worry about getting abused equipment, but from what I hear, these new SVS subs have limiters built in that make bottoming out impossible. So apart from someone dropping the sub, I think it should be fine.....anyone happy with a b-stock purchase from SVS?
avspace is offline
post #77 of 88 Old 03-24-2012, 10:07 PM
rydogg_sc2's Avatar
I have heard good things about SVS outlet products but the PB12-NSD in the outlet shop is currently not available if that matters for you. You end up saving around 5% in the end so it is up to you if the peace of mind in knowing you are the first to have powered up the product is worth around $40.
post #78 of 88 Old 03-25-2012, 12:14 AM - Thread Starter
avspace's Avatar
I'll just go for a new sub then, that should eliminate my chances of having to return the sub if something is wrong because someone else did something funky to it.
avspace is offline
post #79 of 88 Old 03-14-2013, 10:14 AM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
I got my SB13-plus about a year ago from the outlet. It looked brand new when it came to my house. And yes, it has enough power and goes low enough to make me very happy.
I was a little nervous tho bc when I spoke to Ed Mullen he said I would need 3 of my subs to equal the deep bass power of the PB12-plus. I still went for it bc it wasn't small at 95 lbs. just not humongous like the pb12-plus.
In the end it was a very good value and I have had no problems with it.
lsdec is offline
post #80 of 88 Old 05-30-2013, 06:26 AM
archiguy's Avatar
Quoted: 3414 Post(s)
Liked: 3278
I have a smallish dedicated front-projection theater room, about 245 s.f., 1900 c.f. Seven seats and one 12" riser. I'm considering the SB12-NSD. Figured I'd get a pair of them and put them in the corners of the room under the L/R fronts. Don't really have room for a bigger size sub(s) as it would start to crowd the screen. Hope two of the SB12's will give me all the low-end I need for HT in that room as well a nice tightness for tunes. I do want the subs to "pressurize" the room, whatever that means.
Any opinions or thoughts on that plan?
archiguy is online now
post #81 of 88 Old 05-30-2013, 07:30 AM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
Seriously, though, the room is relatively small, so:
- dual SB12-NSDs should have no trouble pressurizing it; and
- there should be sufficient room gain to permit the subs to dig usably down to 20Hz or lower.
eljaycanuck is offline
post #82 of 88 Old 05-30-2013, 07:47 AM
BeeMan458's Avatar
Liked: 813
I love what the SB-12 NSD's are capable of but in a Home Theater, to get what you want, in my opinion, you'll need three SB-12 NSD's so as to smooth out the room response to as many of the seated listening positions as possible and give you plenty of headroom for that chest thumping impact bass you want everybody who visits, to experience.
Also, after all the effort and expense you've put into your Home Theater, if you haven't already, acquire room measuring/EQ capability so as to accurately place your subs and get the best out of them.
Start with two SB-12 NSD's, acquired room measuring capability and then if measurements show additional effort in the form of bass traps or an additional sub is needed, add what ever, as needed.
Those are my thoughts and is my opinion.
BeeMan458 is offline
post #83 of 88 Old 11-30-2013, 07:14 AM
go2mac's Avatar
Interesting, I am being offered for this sub at $418 second hand.
Marantz 1504
Monitor Audio BX5, BX Center, BX1
go2mac is offline
post #84 of 88 Old 09-11-2016, 02:47 PM
tn001d's Avatar
Quoted: 43 Post(s)
My sub inst working anymore. It was hardly used since being purchased in 12/2010. It was in a bedroom system. I recently moved and now using it as a main system sub. I have determined its not the amp, and its the woofer. Cant believe this since its in mint condition. SVS wants me to pay $250 for a new woofer.
Not sure what to do. For less money, I cant get a Polk 505 sub (amazing sub) for $200
tn001d is offline
post #85 of 88 Old 09-11-2016, 03:22 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Hmm... that's a tough one(not regarding the Polk, I'd pass on that). Essentially, you now have to pay $250 to have a working, mint condition SB-12 NSD. If it has enough output to meet your needs(in other words, you don't want a lot of output for movies), I'd say it would be hard to beat. If nothing else, it will make for a good quality music sub for a small room or a system with low output requirements. If you want a powerful sub though, I'd consider looking elsewhere.
What is your intended use i.e room size, primary use, listening levels etc?
bear123 is online now
post #86 of 88 Old 09-30-2016, 01:54 PM
tn001d's Avatar
Quoted: 43 Post(s)
I ended up returning the replacement woofer, and just getting a new SB-2000. Not sure what i am going to do with my SB12-NSD. The amp and enclosure are perfect still.
tn001d is offline
post #87 of 88 Old 09-30-2016, 04:53 PM
bear123's Avatar
Liked: 2511
I'd get this and drop it in: ($59)
http://www.parts-express.com/dayton-...oofer--295-032
I am guessing you would pick up a lot of output in the mid and upper bass regions and, coupled with the SB-2000, will have a lot more combined output down low. I'd say you will gain 4-6 dB down bottom and 6-10 up top(SB2000+ modded SB12 vs just the SB12)
djreef likes this.
post #88 of 88 Old 10-18-2016, 09:38 AM
tn001d's Avatar
Quoted: 43 Post(s)
I listed it in the classified section for sale about 2 weeks ago. Check out the listing
tn001d is offline
Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer
