EQ'ing a sub - noob questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-15-2012, 09:36 AM - Thread Starter
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
Hi - I've got a 7.1 setup (front heights, not rear surrounds) in a 19 x 22 room. Yamaha RX-A800 receiver - I understand YPAO does NOT EQ the sub? Sub is a Velodyne DLS-5000r.
First question - what is EQ'ing the sub?
Q2 - do I need to/should I EQ?
Q3 - since YPAO doesn't do it, I assume I would need to purchase either the SVS or Velodyne system that does it for you. Which is better? Is either worth it when you only have one sub?
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
post #2 of 11 Old 03-15-2012, 09:47 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
All subwoofers in a listening room benefit greatly from equalization. Typically, the results aren't subtle, and the ability enjoy the system increases significantly.
This is an outstanding paper on subs and the most important aspect, the room.
Here is another decent tutorial.
Here is a fantastic series of links, many of which a superb papers you'll likely find very interesting.
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #3 of 11 Old 03-15-2012, 10:53 AM
Moderator
rboster's Avatar
Quoted: 1236 Post(s)
Liked: 1363
If you go to the advance search engine, use the title search only and limit search words to one at a time....eq, calibrate etc. and make sure you highlight this forum from the list to the right....
you'll find all your questions covered in previous threads:
Here's one of them http://www.avsforum.com/avs-vb/showt...0&highlight=eq
For Sale JVC DLA-X750R/RS500 Projector includes two lamps
http://www.avsforum.com/forum/252-fr...l#post54970964
rboster is offline
post #4 of 11 Old 03-15-2012, 11:14 AM
Brad Horstkotte's Avatar
Liked: 73
Behringer feedback destroyers, although designed for pro audio really, work well for EQing subs since they contain parametric equalization functionality - and they can be had second hand for not much money - like $50-$100. In order to EQ though, you also need some way to measure response so you know where to EQ and how much - that means either a mic and REW software (or similar), or an SPL meter, test tones, a spreadsheet, and a lot of patience.
Brad Horstkotte is offline
post #5 of 11 Old 03-15-2012, 05:37 PM
elee532's Avatar
Quoted: 92 Post(s)
Pardon me for jumping in... can the OmniMic be used along with the Behringer or is REW the only option? Thanks for helping me understand.
elee532 is offline
post #6 of 11 Old 03-15-2012, 07:35 PM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
OmniMic does not generate filter profiles.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #7 of 11 Old 03-16-2012, 07:59 AM
elee532's Avatar
Quoted: 92 Post(s)
Please excuse my ignorace Kal... is that a "yes" or "no" to my question? Thanks.
elee532 is offline
post #8 of 11 Old 03-16-2012, 08:04 AM
Liked: 73
Yes, OmniMic could be used - what Kal was pointing out I believe is that REW can measure, but you can also use it to simulate what effect specific parametric EQ settings should do to your response, and then if you have a MIDI connection between your computer and the Feedback Destroyer, you can send those filter settings to the Behringer. OmniMic can measure, but it can't do the application of the EQ, you'd have to do that by hand, and then remeasure.
post #9 of 11 Old 03-16-2012, 11:27 AM
Quoted: 802 Post(s)
Liked: 567
AFAIK, Omnimic does not generate correction filters, so you would have to calculate them from the measurements.
Kal Rubinson
post #10 of 11 Old 03-16-2012, 04:01 PM
elee532's Avatar
Quoted: 92 Post(s)
Thank you both for clarifying! Hope you don't mind one more follow-up... So, how difficult is it to manually configure the settings?
elee532 is offline
post #11 of 11 Old 03-16-2012, 04:09 PM
Quoted: 802 Post(s)
Liked: 567
Another option is the AntiMode 8033. Very compentent autoEQ for a sub.
Kal Rubinson
