I need just a little more bass.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 80 Old 03-16-2012, 02:04 PM - Thread Starter
rhinomike's Avatar
Quoted: 34 Post(s)
I have a 24' x 40' multi purpose room. Half is a theater area and half is a game area...... I hired a professional that did my home theater installation. I went with the below set up.
This is what I have now.
TX-NR-609 Receiver
2 -Definitive Technology BP-8020 Tower Speaker w/8" Sub
1 - Definitive Technology CS-8040HD Center Channel Speaker
2 - Definitive Technology Surround Speakers w/built in back box
All in all it sounds pretty good. I am happy for what I spent. However I want a little more bass. He suggested 1 subwoofer placed right behind my seat..... This is what he thinks that I need. What do you guys think? Is this a good sub? I am not looking for anything over the top jsut a little more bass...
http://www.amazon.com/Definitive-Tec.../dp/B005SOZJJK
rhinomike is offline
post #2 of 80 Old 03-16-2012, 02:09 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
TX-NR-609 Receiver
What is your max budget? If your willing to spend $800 on that Def Tech, dont, there are options out there far better.
ratm is offline
post #3 of 80 Old 03-16-2012, 02:18 PM
beetlesnack's Avatar
That's how it always starts.
beetlesnack is offline
post #4 of 80 Old 03-16-2012, 02:28 PM - Thread Starter
rhinomike's Avatar
Quoted: 34 Post(s)
No budget really..... I just dont need anything crazy. I am alomst happy now. I was debating whether or not to even mess with it..... So I just want a little more....
My whole system is Def. Tech. and that is what my guy uses so I thought I would stick with that.... I was thinking a 12" sub but he tells me this is better....
post #5 of 80 Old 03-16-2012, 02:31 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Get a tactile transducer. It will add something that another subwoofer can not. I like this one:
http://crowsontech.com/go/crowsontec...opDefault.aspx
...but there are a lot of others.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #6 of 80 Old 03-16-2012, 03:00 PM
spyboy's Avatar
Liked: 47
I would consider adding the Energy S10.3 for ~$230 at newegg. Placed right behind your listening postion and you will be good to go. Nearfield placement makes all the difference.
spyboy is offline
post #7 of 80 Old 03-16-2012, 03:01 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I like and own Deftech speakers as well, but really do not recommend their subs as you can get much better bang for your buck.
I would look at offerings from HSU, SVS, Epik, and Rythmik.
With your size space, I would consider something like an HSU VTF-15H. But you may be fine with a VTF3-MK4 (if you are putting it close to your couch) which is cheaper than the Deftec sub you are considering.
ack_bk is offline
post #8 of 80 Old 03-16-2012, 03:01 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Yep, might as well do it right now or you will keep getting the upgrade bug
ack_bk is offline
post #9 of 80 Old 03-16-2012, 03:35 PM
jsgrise's Avatar
Quoted: 162 Post(s)
Liked: 57
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #10 of 80 Old 03-16-2012, 04:01 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
The infection has started There are several anti-biotics out there from Rythmik, SVS, HSU..etc..
Check out the "Official" insert subwoofer brand name here and you would see several brands with a lot of followings which should help you pick out a sub.
Your towers are substantial having its own sub. You would need a substantial sub to go with it, otherwise the addtion of a smaller sub may not impress you.
With that size of a room, I would go with two twelves or one fifteen inch subwoofer
qguy is offline
post #11 of 80 Old 03-16-2012, 04:25 PM
Auditor55's Avatar
TX-NR-609 Receiver
Do what your installer recommended. Some folks around here have unlimited budgets and because of that they will eternally have the upgrade bug. There's nothing wrong with Definitives. Some folks over do it with bass, the bass is so cooked its ridiculous. If the installer recommend another Definitive, go with that.
Auditor55 is offline
post #12 of 80 Old 03-16-2012, 06:27 PM
sputter1's Avatar
Liked: 42
On the other hand, some folks under do it and want to poopoo everyone else.
sputter1 is offline
post #13 of 80 Old 03-16-2012, 06:53 PM
dpc716's Avatar
Quoted: 13 Post(s)
Liked: 24
One thing worth clarifying is whether you're interested in improving the bass only from your seating area or if you listen from the gaming area as well.
Thats a big room for an 8 inch sub, even two.
Its cheaper in the long run to go a little "over the top" once than a series of incremental upgrades.
dpc716 is offline
post #14 of 80 Old 03-16-2012, 06:56 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Originally Posted by sputter1 View Post
on the other hand, some folks under do it and want to poopoo everyone else.
zing!!!!!
ratm is offline
post #15 of 80 Old 03-16-2012, 06:58 PM
capricorn kid's Avatar
Liked: 25
You can't over do bass....Go all out and just get a JTR Orbital Shifter and place that behind your seat !!!! That will give you that little extra bass you are looking for.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
Velodyne SMS-1
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #16 of 80 Old 03-16-2012, 07:28 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Yep. For the price of that DT SC4000, might as well get an SVS PB12-NSD and KNOW that there will be plenty of good bass
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #17 of 80 Old 03-16-2012, 07:53 PM
Hksvr4's Avatar
Quoted: 28 Post(s)
Liked: 34
Get the biggest sub you can afford.
Hksvr4 is offline
post #18 of 80 Old 03-16-2012, 08:19 PM
oztech's Avatar
Liked: 101
To me 8inch subs are great for small dorm rooms and computer desk unless you plan on running a wall full of them its hard to get any tactical feel.
oztech is offline
post #19 of 80 Old 03-17-2012, 09:26 AM
beezar's Avatar
I've never really been a fan of bass, thinking it was not really important and that people who would crank up the bass were obnoxious. So I got a budget 10" sub a few years ago which was ok.
Decided to upgrade recently just for "a little more bass", and decided to take the plunge as everyone kept telling me how important it was to get the biggest sub I could afford.
So I got a SVS PB12+. Spent way too much money, but I do not regret it at all. Not one bit. I don't crank it up usually, but a good sub is completely worth it. Didn't have any idea of what I was missing. Listen to these folks...
beezar is offline
post #20 of 80 Old 03-17-2012, 09:34 AM
oztech's Avatar
Liked: 101
First thing i did when I got my new sub was go back and listen to my music collection and to my surprise even the old stuff had bass info my last sub did not handle well so yeah its worth it.
oztech is offline
post #21 of 80 Old 03-17-2012, 12:37 PM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
I do installs from time to time. When it comes to subs i just bring one over and hook it up, if it works for them they can buy it. I do the same with Harmony remotes, when they have at least four remotes.
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #22 of 80 Old 03-17-2012, 08:49 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
Bad advice is bad. You would have to be out of your mind to spend $800 on that sub . You can do way better for that price and don't underestimate what a good sub can do for you. It has nothing to do with being a bass head, but my sub was probably the best investment I have put into my home theater and I'm sure a lot of people here would agree.
Life is hard, be harder.
Saints is offline
post #23 of 80 Old 03-18-2012, 11:49 AM
cel4145's Avatar
Liked: 2987
Especially for the size of the OPs room. An additional 8" sub is hardly going to make any difference at all, whereas one of the better 12" ID subs such as the HSU VTF-3 MK4, Outlaw Audio LFM-1 EX, or the SVS PB12-NSD would be a much, much better choice.
And Saints is right. This not about being a "bass head." One of those subs will work much better for HT and gaming use. Clean bass.
post #24 of 80 Old 03-18-2012, 03:21 PM
Auditor55's Avatar
Unless you have his credit card or checkbook, how in heck do you know how much he's spending?
I have serious concerns if a limited thing like a sub was the best investment in your systems. Also, you site Home Theater, what about music, do you listen to music?
post #25 of 80 Old 03-18-2012, 03:25 PM
Auditor55's Avatar
Yes you can over do bass. There's more to music than just bass. What audiophile or music listener in there right mind wants over exaggerated bass, ala a teengage car stereo systems, drowning out all other frequencies.
post #26 of 80 Old 03-18-2012, 03:26 PM
Auditor55's Avatar
What if you don't have the room for it?
post #27 of 80 Old 03-18-2012, 03:27 PM
pokekevin's Avatar
Liked: 102
personal prefs man personal prefs
as for the OP, an 8 sub will not make you happy in that room...I've tried using an 8 before in a larger room...sucked
pokekevin is offline
post #28 of 80 Old 03-18-2012, 03:30 PM
pokekevin's Avatar
Liked: 102
Room is pretty big, I think he can make room once he hears the difference
post #29 of 80 Old 03-18-2012, 03:48 PM
cel4145's Avatar
Liked: 2987
I'm bored a the moment. I'll address the trolling LOL
Seems a pretty reasonable guess that a professional installer is not offering some fantastic deal on that sub. Certainly a good ballpark figure to work with without more info from the OP.
Not relevant to this thread. The OP already mentioned his room is half HT/half gaming.
Not relevant to this thread (same as above) because this is not about music listening. Besides, capricorn kid mentioned a JTR sub, not a sub with some crappy car stereo setup (and with emoticons, I might add, that indicated playfulness with the suggestion).
The OP has a 24x40 room for HT and gaming. Like Kevin said, quite likely he can handle a pretty big sub in that room. LOL
Now how about going away until you have something meaningful and useful to add to the discussion? Don't corrupt this thread, too, like you have others. Go restart one of those threads you already wrecked.
post #30 of 80 Old 03-18-2012, 04:11 PM
jparr's Avatar
Add bass traps. Night and day.
jparr is offline
