New receiver/subwoofer problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 03-18-2012, 06:46 AM - Thread Starter
gogo_vs's Avatar
I had Onkyo TX-SR602 for about 6 years and decided to upgrade to Yamaha RX-A3000. I recently purchased a new TV as well and was modifying a stand for it and during that time my speakers were not perfectly in their location. When I tested it still with the Onkyo, everything sounded well especially subwoofer had really good punch and deep bass and a lot of air coming out of its port. I replaced Onkyo with Yamaha, moved speakers to their location, ran YPAO to try to get even better results (subwoofer location stayed pretty much same). To my surprise, that great punch an bass was gone and not too much air coming out from the port. Checked results in YPAO and somehow it shows that all my speakers are in reverse (W-1 warning). Double checked wiring and everything is correct. My subwoofer level was set to -10.0db. Raised it to +6.0db, but the results were not even close what I had with Onkyo.
Any suggestions?
gogo_vs is offline
post #2 of 27 Old 03-18-2012, 07:50 AM
jproy13's Avatar
Liked: 26
troubleshooting no.1 Make sure speakers are set to "small" as they are probably set to "large". Check what crossover YPAO chose and report back.
cheers
jproy13 is offline
post #3 of 27 Old 03-18-2012, 08:19 AM
Fishpoke's Avatar
If all your settings are correct, from what I can tell yamaha receivers are pretty dull on bass. Using the dynamic eq helps a good deal... I'm eyeballing an emotiva xpa-2 in the mean time
Fishpoke is offline
post #4 of 27 Old 03-18-2012, 08:43 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Any suggestions?
Did you raise it by turning down the gain on the sub and rerunning YPAO? Many people recommend setting the gain on the sub such that the room correction software determines a sub channel (trim) level between -3db and 0. This optimizes the sensitivity of the sub gain for the receiver. Then afterwards, bump up the sub channel on the receiver a few db if you need more bass.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 27 Old 03-18-2012, 08:46 AM - Thread Starter
gogo_vs's Avatar
cheers
YPAO set my front speakers to large but I changed tham to small with 40Hz crossover. All other speakers are set to small.
gogo_vs is offline
post #6 of 27 Old 03-18-2012, 08:50 AM
oztech's Avatar
Liked: 101
Have you tried setting the crossover to 60 or 70Hz and let the sub handle the chest slam of 40 and 50Hz that most mains can't compete with?
oztech is offline
post #7 of 27 Old 03-18-2012, 08:53 AM - Thread Starter
gogo_vs's Avatar
I am at work right now and I will try that when I get back home.
Should I try to reverse polarity on my speakers as well?
gogo_vs is offline
post #8 of 27 Old 03-18-2012, 08:56 AM - Thread Starter
gogo_vs's Avatar
Do you mean 60-70Hz on my front speakers? I have it set to 40Hz, but I can try to set it higher and see if it helps.
gogo_vs is offline
post #9 of 27 Old 03-18-2012, 08:59 AM
oztech's Avatar
Liked: 101
Yes your front speakers.
oztech is offline
post #10 of 27 Old 03-18-2012, 09:06 AM - Thread Starter
gogo_vs's Avatar
I hope its just matter of setting up everything correctly. I really liked the bass output from my old Onkyo.
gogo_vs is offline
post #11 of 27 Old 03-18-2012, 09:07 AM
jproy13's Avatar
Liked: 26
I'm pretty certain it's just a setting issue. The RX-A3000 should be a capable receiver.
Did you buy it new or used?
jproy13 is offline
post #12 of 27 Old 03-18-2012, 09:08 AM - Thread Starter
gogo_vs's Avatar
I have JBL-ND310II with 2x10" woofers and they are going pretty low, but I can can try to play with the crossover.
My subwoofer is Cadence CSX15-MarkII
gogo_vs is offline
post #13 of 27 Old 03-18-2012, 09:16 AM - Thread Starter
gogo_vs's Avatar
It was purchased as an open box 10 days ago from Best Buy, but I did the factory reset.
gogo_vs is offline
post #14 of 27 Old 03-18-2012, 09:29 AM
oztech's Avatar
Liked: 101
While they are rated to go down to 37Hz I seriously doubt they are flat to that more like -3db down at that frequency which could mean a roll off started at 50 or 47 Hz don't actually know without proper graphing and to the ear anything below 100Hz starts to sound pretty low.
oztech is offline
post #15 of 27 Old 03-18-2012, 10:00 AM - Thread Starter
gogo_vs's Avatar
Thank you guys for the help. I will try to play with it when I get home.
gogo_vs is offline
post #16 of 27 Old 03-18-2012, 10:23 AM
cel4145's Avatar
Liked: 2990
+1
Here is Sound and Vision Magazine's review of the CSX-12 Mark II and there is a frequency response graph. It's likely that the 15" would have some kind of similar roll off.
cel4145 is offline
post #17 of 27 Old 03-18-2012, 10:44 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Your ONKYO didn't really have "bass output". Not in regards to the subwoofer's output, anyway. Seems like a setting issue. Barring a problem with the AVR, there is no reason you shouldn't be able to get similar or identical performance with the same sub.
What crossover were you applying to your front speakers with the ONKYO?
You should figure out the reverse polarity issue. Did you move things around relative to the way it was setup before?
You didn't change the subwoofer distance setting from what YPAO found, did you?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #18 of 27 Old 03-18-2012, 10:58 AM - Thread Starter
gogo_vs's Avatar
+1
I was't expecting much from the 15" version since there is not too many reviews, but it really surprised me. Really nice deep bass. I felt the punch in my chest and it wasn't even that loud with my old Onkyo. I was just surprised that I couldn't replicate same effect so far with much better Yamaha.
gogo_vs is offline
post #19 of 27 Old 03-18-2012, 11:05 AM - Thread Starter
gogo_vs's Avatar
I would have to double check. The Onkyo doesn't have too many setting options, but it has crossover, level, etc.
Everything stayed in the same position.
No, I didn't. I was only playing with level/gain.
gogo_vs is offline
post #20 of 27 Old 03-18-2012, 11:17 AM
cel4145's Avatar
Liked: 2990
You mentioned that the sub is pretty much the same location, but how far did you move it? Sometimes just a couple of feet right or left along a wall can affect the sub response.
cel4145 is offline
post #21 of 27 Old 03-18-2012, 11:28 AM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 803
Here is a pretty good link on setting the subwoofer/LFE.
http://www.audioholics.com/tweaks/ge...st-performance
THX recommends crossing everything over at 80Hz and that's a good place to start if your speakers and sub will allow it. I'd personally cross it over as high as you can without noticing localization (I obviously didn't follow all the advice in the link). I cross my system over at 90Hz even though all my speakers are rated to play <40Hz because my SubM does a great job with these frequencies and I don't notice localization.
jjackkrash is offline
post #22 of 27 Old 03-18-2012, 01:58 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
You don't know what crossover you were applying previously? This would be important to know as any difference will be....... well................... different.
post #23 of 27 Old 03-18-2012, 05:17 PM - Thread Starter
gogo_vs's Avatar
I would say no more than 2 feet.
gogo_vs is offline
post #24 of 27 Old 03-18-2012, 05:20 PM - Thread Starter
gogo_vs's Avatar
I will try that. I didn't know that when you are playing with front speakers croosover it afects subwoofer's crossover to make sure you have full band.
gogo_vs is offline
post #25 of 27 Old 03-18-2012, 05:27 PM - Thread Starter
gogo_vs's Avatar
When I was setting everything up, I didn't know much about crossovers,etc.
It was at least 6 years ago. I think I didn't even touch crossovers, only gain.
gogo_vs is offline
post #26 of 27 Old 03-18-2012, 05:29 PM - Thread Starter
gogo_vs's Avatar
I found a review from last year:
Review
gogo_vs is offline
post #27 of 27 Old 03-19-2012, 03:33 PM - Thread Starter
gogo_vs's Avatar
Thank you guys for your help. I re-ran YPAO multiple times until I had 0db on the subwoofer, changed my fronts to small and set crossover on all 7 speakers to 80Hz and my subwoofer is pounding again.
Do I have to be worry about reverse polarity on my speakers? (all of them are reversed per YPAO).
gogo_vs is offline
