Is crossover at 60hz a waist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 03-19-2012, 12:56 PM - Thread Starter
bbruins2's Avatar
I have 2 vtf 15h subs being run with a HK AVR 3600 receiver.My main speakers are Boston Acoustic VR3's which I believe are full range.I have my speakers set to small and my main speaker crossover set to 60hz.I am more concerned about 2 channel music than movies.It just seems that the subs are not working hard enough.Does this make sense?
I also posted this on the HSU forum but no reply yet.
bbruins2 is offline
post #2 of 26 Old 03-19-2012, 01:08 PM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 803
I cross mine over at 90Hz, 80Hz is the recommended starting point. One school of thought is to cross them over as high as you can until you start to get localization, or, alternatively, where you can get the best frequency response if you have measuring equipment.
jjackkrash is offline
post #3 of 26 Old 03-19-2012, 01:21 PM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
I have the same fronts but cross mine at 80. However, my denon 2809 has an advance crossover setup for 2-channel music. I set my VR3's at 60 in that setting. I love my Empire sub but prefer music with 60. Research your receiver to see if you have those separate settings.
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #4 of 26 Old 03-19-2012, 02:22 PM
Kini62's Avatar
Quoted: 1414 Post(s)
Liked: 1296
Set your speakers to large and sub to on. The double bass thing and see how that sounds.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #5 of 26 Old 03-19-2012, 02:50 PM
Legairre's Avatar
Quoted: 470 Post(s)
Liked: 270
My fronts go down to 32Hz and I cross at 60Hz.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #6 of 26 Old 03-19-2012, 03:12 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
A WASTE of what? Your speakers' potential or your subs' potential? In reality, whether you use a 40Hz, 60Hz, 80Hz, or even a higher crossover, it is still probably a WASTE of neither.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #7 of 26 Old 03-19-2012, 03:37 PM - Thread Starter
bbruins2's Avatar
I was thinking I was wasting my subs as I am only sending 60hz and less.
bbruins2 is offline
post #8 of 26 Old 03-19-2012, 03:41 PM - Thread Starter
bbruins2's Avatar
Thanks for all the informative responses.I will do some more experimenting with some of the info given as I don't think I'm getting quite the oomph from my subs with music.
bbruins2 is offline
post #9 of 26 Old 03-19-2012, 04:27 PM
mannoiaj's Avatar
mannoiaj is offline
post #10 of 26 Old 03-19-2012, 04:58 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Got a 2 channel setup and my sub is crossed over at 35 -40 hz and its not a waste. My Fronts are good up to 38 hz.
you could always up the gain to make them work harder
qguy is offline
post #11 of 26 Old 03-19-2012, 05:07 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
Down to 38Hz.
eljaycanuck is offline
post #12 of 26 Old 03-19-2012, 05:52 PM
capecodorthopod's Avatar
Even though your mains are rated well below 80 hz I'd still try 80 or higher. Just because your mains can reproduce 60 hz (and lower) doesn't mean you should cross over down there.
Think of headroom. Your VTF-15's can produce a 60 hz signal at much higher SPL with lower distortion than your mains. I have powered towers and cross them @ 80 or higher.
You'll be surprised how much better your mains sound (at all frequencies) when relieved of the burden of producing lower frequencies with smaller drivers.
Tim
capecodorthopod is offline
post #13 of 26 Old 03-19-2012, 06:25 PM
Oliver Deplace's Avatar
Liked: 33
Try turning off one of the subs. Does it sound better/louder? If it does, then you have placement/phase issues.
Oliver Deplace is offline
post #14 of 26 Old 03-19-2012, 09:23 PM
SbWillie's Avatar
SbWillie is offline
post #15 of 26 Old 03-19-2012, 09:44 PM - Thread Starter
bbruins2's Avatar
I will try this tomorrow.Thanks
bbruins2 is offline
post #16 of 26 Old 03-20-2012, 12:14 AM
the Son's Avatar
For music, I personally set my crossover higher when the mains are driven by a receiver. The lower you go, more power is required. The mains will be happier with a higher crossover (it's actually the receiver that will be happier). I'd say you probably aren't wasting anything, but you're more likely to clip the mains at higher volumes with a lower crossover point.
the Son is offline
post #17 of 26 Old 03-20-2012, 08:57 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
I use 80hz, it allows me enough room to tune my subs and remove deep bass from my mains so they are free'd up to do "main" work
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #18 of 26 Old 03-20-2012, 09:52 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Originally Posted by mannoiaj View Post
This is a waist
http://www.ehow.com/how_2307504_measure-waist.html
That ain't no waist!
This is a waist:
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #19 of 26 Old 03-20-2012, 10:31 AM
desertdome's Avatar
Quoted: 1119 Post(s)
Liked: 1222
Here is a 60 Hz waist:
High Impact AV
desertdome is online now
post #20 of 26 Old 03-20-2012, 10:53 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
^^^ lmao!!
wth718 is offline
post #21 of 26 Old 03-20-2012, 01:58 PM
dr_hsu's Avatar
Quoted: 24 Post(s)
Liked: 73
Sorry. I was very busy yesterday but I have answered on the Hsu forum. I recommended crossing over at 80 Hz. Even if the main speakers can go lower, running them lower reduces the receiver's amplifeir power available to handle the mids and highs. Especially when one has TWO 15Hs, you have dynamic range to spare, in spades! So, crossover higher. I would not go above 80 Hz just because one would start to localize the subwoofers.
dr_hsu is offline
post #22 of 26 Old 03-20-2012, 02:02 PM
dr_hsu's Avatar
Quoted: 24 Post(s)
Liked: 73
Receiver's amplifier power. If you have a powerful subwoofer system like two 15Hs, and just a receiver's amplifier driving the main speakers, you have an unbalanced headroom, much more in the bass than the mids and highs. Crossing over lower would rob the dynamic range available for the mids and highs since the limited amplifier power available from the receiver will be used to handle some bass as well.
dr_hsu is offline
post #23 of 26 Old 03-20-2012, 02:14 PM
spyboy's Avatar
Liked: 47
To add to what Dr. Hsu said, by using an 80Hz crossover in the receiver, the power demands on the receiver are reduced by 66%.
TL5 likes this.
spyboy is offline
post #24 of 26 Old 03-20-2012, 04:04 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
post #25 of 26 Old 03-20-2012, 04:07 PM
speavler's Avatar
Quoted: 12 Post(s)
Liked: 26
trust your ears. i've never liked anything much over 60Hz. male vocals seem to get colored. my current speakers are rated to 20-something Hz, but get nowhere near that. with my old von schweikerts i used closer to 40Hz.
speavler is offline
post #26 of 26 Old 03-20-2012, 05:59 PM - Thread Starter
bbruins2's Avatar
You don't need to be sorry.I saw your recommendations in the HSU forum and very much appreciate it.I have reset to 80HZ and made some other adjustments as well.I also noticed I had 1 sub with the crossover set to in.OOPS .I am much happier now.Thanks to you and everyone else who replied.
bbruins2 is offline
